Question about Palm Treo 650 Handheld
Palm treo screen freeze
When turned on, screen shows a target with instructions to "use stylus to tap center of target". Nothing happens. soft and hard reset were both done yet nothing happens.
is this locked or what?
  • pegchile May 20, 2008
    Screen is frozen. I kept getting the target each time the power went on. I would tap and eventually would get back to the basic screen. That occurred for several days. Now, my screen is really wacky. If I press "cancel" it shows the number 3. None of the screen taps relate to what they are to correspond with...such as "done" may move to "contacts."
    Help! Any suggestions for fixing this on my Treo 650? Is it time to move on to another product? Pen and paper perhaps? This is my 3rd Treo 650. Each one has had problems.
  • Shahid Aghyas
    Shahid Aghyas May 20, 2008
    My palm treo 650 stylus is not working properly, when i callibration of pin the stylus cann't follow tap point on screen what problem with Treo (Screen problem or another. plz send me a detail to solve this problem. my ID shahid_aghyas@yahoo.com
  • 3 Answers
The same thing happened to mine. run a credit card (or something similar) around the edge of the screen because there might be something caught underneath. this SHOULD work!
Posted on Oct 29, 2008
Check to see if any buttons or keys are stuck down.
If not, then you may have a damaged screen or cable that needs repair
Posted on Feb 22, 2008
Get a Blackberry and forget this inferior technology. That's what i did and i have never looked back!
Posted on May 14, 2008
Palm zire stylus not working
Try doing a soft reset on the pda, this will usually resolve the issue. Then reperform the aliginment task.
Jun 10, 2012 | Palm Zire Mono M150 Handheld
Palm treo 750 only shows the Palm screen on startup and nothing more
check soft ware at first , then hard ware solution by cleaning the board , be sure that keyboard is clean enough.....
Apr 20, 2011 | Palm Treo 750 Smartphone
My Palm Zire M150 touch screen is badly misaligned. How do I reset the alignment?
the screen says use stylus to tap center of target ...i do that and it goes to upper left corner i tap and it goes lower right corner and back and forth between the to corners?
Mar 01, 2011 | Palm Zire Mono M150 Handheld
My palm Vx asks me to tap center of target but doesn't respond
If there is no response anywhere at any time then you probably have to replace the digitizer. Also if you have a plastic protector sheet take that off and try it.
Mar 01, 2010 | Palm Vx Handheld
My Z22 touchscreen does not respond to the stylus
This shows the OS is corrupted. Try to flash the device
Jul 25, 2009 | Palm Z22 Handheld
Zire won't come on
You need to follow the procedure to calibrate the digitizer.
If the screen does not respond to the stylus, then the digitizer is defective and needs to be replaced.
Best regards,
Feb 11, 2009 | Palm Zire 71 Handheld
Palm 700P stylus problems
it sounds like it could be a warrenty issue, if you have restoreed the device and its still not working then you would need to get it repaired or replaced
Jun 11, 2008 | Palm Treo 700p Smartphone
Cannot save received pictures
When you download the picture to the phone it shows up as an icon with a description at the bottom of the screen. Tap on the icon with your stylus and that is where you will find the save choices.
Dec 24, 2007 | Palm Treo 755p Smartphone
Palm vx hand held
the stylus is that little pokey stick that comes with the Palm.  Use it to tap the X on the screen.  It is an alignment program for the touch-screen.
Oct 13, 2007 | Palm Vx Handheld
Pls help me for power on fail
If your Treo loops or freezes during a soft reset, a system reset may help. Performing a system reset allows you to get out of an endless loop in order to uninstall a third-party application causing the looping: 1. Press the Battery Door Release button and slide the battery door downward to remove it from your Treo. 2. While pressing and holding Up , use the tip of the stylus to gently press the reset button on the back of your Treo. 3. When the Palm Powered logo appears, release Up . 4. Delete the third-party application that you suspect is causing the problem. 5. Perform a soft reset. The wireless features of your phone are not available until you complete this step. Good luck!
Nov 23, 2005 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
421 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
