Question about LG WM-1480FHD Front Load Washer
Faulty door catch on my LG washer?
How can I release the door catch from inside my LG washer to open the door.
I have had the same problem for a week now. Until I find a spare part I slide a scraper to push the catch open. That just works.
Posted on Jan 30, 2008
Unable to open door
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jul 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
Door will not open
Thank you !!
Jul 01, 2010 | Hotpoint Ultima WF860 Front Load Washer
Door will not open
Thank you !!
Jun 26, 2010 | Hotpoint Aquarius WD640 Front Load...
My machine has the door lock light on and wont start, the door is locked as i have to press the release to open it!
Thank you !!
Jun 26, 2010 | Hotpoint Aquarius WD63 Front Load...
Door handles slack feels like springs dropped so cant open door
You can release the catch from inside just keep trying and thern you need to replace the door catch itself this is a simple job
Jun 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
UNABLE TO OPEN DOOR AFTER WASH
Apr 08, 2010 | Hotpoint Aquarius WD640 Front Load...
Lg washing machine wm-1460fhd door locked wont open
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Jun 10, 2009 | LG WM-1480FHD Front Load Washer
Washer stopped midcyle-error code do, then FL
The door interlock could be faulty. The only way to open the door if the door interlock is faulty is to remove the top of the machine, after turning it off at the wall and pulling the plug out of the socket, and locate the door interlock from the inside. There should be a metal "slide" which can moved back to release the door catch. The interlock could be warped from getting hot, which will make the slide almost impossible to move. Remove screws holding the interlock from the front panel and from the inside pry the interlock from the catch. Replace interlock.
Oct 21, 2007 | Maytag Neptune MAH5500B Front Load Washer
LG 1480fhd
Try first to unplug the power cable and see if it allow you to open the door. In case it will not help, you have to raise the top of the washer to get to the switch and release it manually (The switch is inside the washing machine main housing near the door frame). Good luck
Sep 03, 2007 | LG WM-1480FHD Front Load Washer
Faulty on off button
the only way you can open the door is by switching off the washer open the lid feel down the front off the inside of the washer to were your door catch goes to you will find a catch you can release to open the door
Dec 11, 2006 | Candy AQW130 Front Load Washer / Dryer
LG WM-1480FHD Front Load Washer Logo
204 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
