Question about Sony Ericsson W700i Cellular Phone
How to increase memory for sms
How to display sms of w700i on computer or how to increase memory for w700i
  • 20 more comments
  • Anonymous Jan 06, 2008
    hw 2 inc sms space in w700i
  • Anonymous Jan 12, 2008
    please help me to increase the sms memory for SEw700i....!!!1
  • Anonymous Jan 16, 2008
    how to increase memory for sms in w700i?
  • ankzkool Mar 07, 2008
  • depk Mar 15, 2008
    how to increase memory for sms?
  • Anonymous Mar 17, 2008
    how to sms memory
  • Anonymous Apr 02, 2008
    go to message setting but no found the way to solve this problem
  • Anonymous May 03, 2008
    how to increase sms memory of sony ericsson w700i
  • Anonymous May 07, 2008
    read phone sms on computer
  • Anonymous May 22, 2008
    W700I SMS MEMORY FULL
  • rajataggar Sep 13, 2008
    i wan to increase my sms memory of W700i
  • aks_12289 Sep 17, 2008
    when i open "sent messages", phone becomes too slow...How to solve it..??
  • chweet_me Sep 19, 2008
    i am only able to keep 175 msgs hardly on my phone could u tell me how do i increase the space for sms on my cellphone .. i am using W700i sony erricsson
  • anurag11 Sep 20, 2008
    i only get 178 msgs on my w700i. so hw to increase the memory capacity of my cell???
  • shirkya Sep 25, 2008
    i have to increse my messege memory
    how can i do this???????
  • SAFI JAIN
    SAFI JAIN Sep 29, 2008
    i hav to increase my msg limit...it is of 210 msges now..i want dis vll not use phone memory but memory card memory...plz suggest something as soon as possible....
  • ineedyou Dec 31, 2008
    hw would i connect my ph to XS++ i.e via a USB cable or ny other.
    n do i need 2 install ny software 4 this??
  • emranrulz Jan 24, 2009
    pls tell me how to increas memory for sms and can i see my sms in computer
  • Anonymous Jan 25, 2009
    how to increase sms memory in w700i??????
  • Anonymous May 03, 2009
    how can i increase the message memory space of my cell sony ericsson w700i???????????????????
  • gakarot May 11, 2010
    how to display sms of w700i on computer or how to increase memory for w700i
  • aks_12289 May 11, 2010
    How to increase the message memory of my cell phone...?
I only get 178 msgs on my w700i. so hw to increase the memory capacity of my cell???
Posted on Sep 30, 2008
  • quartz_watch Sep 30, 2008
    i only get 178 msgs on my w700i. so hw to increase the memory capacity of my cell??? how to transfer sms to memory card
Use MyPhoneExplorer Software to display sms on Computer
Posted on Feb 15, 2009
Hello sir ,,, iam using W700i model of sony , it has... Answer This... hav to increase my msg limit...it is of 250 msges now..i want dis vll not use phone memory but memory card memory...plz suggest something as soon as possible....
Posted on Nov 01, 2008
To increase the everlasting SMS inbox storage memory....
These are the prime requisites to increase SMS storage----
1.USB flash Drivers
2.XS++
3.FAR manager with SEFP
Lets start…
1) [only for CID49]::Firstly, we need to patch our MAIN firmware to make it compatible with FAR and SEFP. For this remove SIM and connect your phone with XS++ [as we do in flashing,with the 'c' key pressed](or any other flashing program that you use), and check to -"Flash MAIN Firmware". Click ‘…’[path] and browse to the FAR folder and then to Plugins folder. Select the file according to your phone model, in my case, ‘k750w800_r2e_dcu.49r.ssw’ (for K750/W800/W700 CID49) . Now hit flash . 5 flashblocks will be loaded in 5 seconds!!!). Now our MAIN is patched.
2) [for CID36 and CID49 both]::Close XS++, unplug fone and re-insert battery to refresh. Now open FAR manager program. Press F11 and then select SEFP plugin. in the following screen select… Device:DCU60, Speed: 921600 ,Boot Script: According to fone model (k750_w800_CID49 or k750_w800_CID36) Do it carefully!!! … Now Hit --Enter The MATRIX!!!Connect your fone when asked with the "c"button pressed,,after detection release "c" button.after a few seconds, a screen will show you two folders, FLASH and FS. Note that the window is divided into two… the left side represents your phone contents. The right side represents your PC's hard drive contents… currently inside FAR manager folder.
3) [for CID36 and CID49 both]::Now double click on FS and wait for a couple of minutes till it breaks into your FileSytem. Now you are inside the phone's control centre. Before we do something u must create a backup folder for your original files (in case you need them). So on the right side (harddrive) of your screen, click anywhere and press F7 to create a new folder. Name it as ‘backup’. On the left side (fone FS) open the folder,/ifs/settings/messaging… you will see a file named pref_store.txt. Click and drag this file to the backup folder. now,select it and press F4 to edit the file. in the new screen, change '/smsdata' to '/tpa'. press F2 to save and F10 to quit the file editing.Now goto the root directory by clickin "..." where u see ur ifs,tpa,system,etc etc folders... there is a folder called smsdata with 2 folders inside --messaging and system. copy both folders of smsdata to tpa folder. this way your old sms wil not be deleted.
4) [for CID36 and CID49 both]::Now, that we are finished with our operations, we need to shutdown the loader. For this keep on clicking ‘..’ (root of folder) until it asks you to shutdown CSFS loader.Click yes and Quit FAR manager, and unplug fone. Remove and Reinsert battery to refresh.
5) [only for CID49]::The final step is to un-patch the MAIN firmware. Again, open FAR manager program, and connect fone, the same way as before. This time goto FLASH instead of FS. and now in FAR manager folder. goto Plugins folder and then to REST. You see a number of files… with prefix ‘REST_’ followed by your fone’s firmware version. Select the appropriate file of your MAIN firmware (I have a k750 flashed to w800 r1bc002 main so REST_W800_R1BC002 in my case) and drag it to anywhere on the left side. select Copy then in the new window Hit flash. Quit FAR manager and unplug your fone. The job is done!!!
Insert SIM and turn on your fone and enjoy..... ROSH
Posted on Oct 26, 2008
Use Phone Explorer Software, avalaible at www.fjsoft.com
Posted on Apr 18, 2008
Display sms of w700i on computer use my phone explorer get it here
Posted on Dec 28, 2007
Sir i have k320i how 2 increse memory spase 4 text sms
Posted on Sep 04, 2010
Hello sir ,,, iam using W700i model of sony , know in my phone walkman  sound has been decrease
Hi ,
i have Sony Erricson W700i , I have a problem in my camera mode, while i go to main menu and select camera icon it is not getting into camera view .
what shall i do , is it a problem with my hardware or software ?
Posted on Feb 16, 2009
  • naveen6009 Jan 14, 2011
    naveen6009@gmail.com w 700i camera problem help me
How to increase message memory in sony ericsson w700i
Hi jonothomask,
The Sony Ericsson W700i comes with 34 Mbytes of internal memory & the phone comes with a 256 Mbytes Memory Stick PRO Duo™ which will store approximately sixty four music tracks. The incoming messages will be stored in the internal memory only. So it cannot be extended even by the extternal memory card.
Please leave me comment, if you need further assistance
good luck with your fix.
have a nice day.
A VERY HELPFUL RATING IS APPRECIATED,
Thanks
Regards
Arul
Apr 07, 2010 | Sony Ericsson W700i Cellular Phone
Sms memory of moto razr v3i
my cell motrola v3i showing memory full in just 25 sms can u tell me ho to increase memory
Sep 13, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Increasing SMS inbox capacity of sony ericsson w700i
Problem for Sony Ericsson W700i Cellular Phone Increasing SMS inbox capacity of sony ericsson w700i
Aug 20, 2009 | Sony Ericsson W700i Cellular Phone
sry man, thts the disadvantage of old sony phones . u can copy ur messages to computer and then delete it from ur phone.
Aug 07, 2009 | Sony Ericsson W700i Cellular Phone
SMS memory in Sony Ericsson W810i
Unfortunately you cannot increase the momory size as it is default. You can save upto 200 SMS inclugind your inbox, outbox and sent items. However you can save your sms as a text in notes.
Mar 15, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Sms manager
If you want to transfer you sms and all your contacts to PC, there is a good phone manager which can be downloaded free from www.lasyk.net. Install it in PC, connect the phone and save all contacts and messages as a new user
Aug 28, 2008 | Sony Ericsson W700i Cellular Phone
Increasing memory for sms
RGUY - you can not store that many text msgs on your phone unless it's internatl memory is 1gb and up.
SUSHANK - you need to contact your service provider help desk for further assistance.
Dec 28, 2007 | Sony Ericsson W700i Cellular Phone
To Increase the capacity of memory stick
you will need to purchase the memory card from a store
Dec 05, 2007 | Sony Ericsson W700i Cellular Phone
Sony Ericsson W700i Cellular Phone Logo
2,584 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
