Question about Sony SLV-N55 VHS VCR
Sony SLV N80
I have a OLD SONY SLV N80 VCR. It was workfing fins until a month ago. my two yer old put some quarters inside this unit . i just shaked the unit to make sure no foregn objects inside. that's it from that point on it doesn't power up.any help would be greatly appreciated.
DId you open up the VCR and take the quarters out?
Posted on Jul 25, 2008
Sony SLV-ED818 black and white picture
Is the TV a USA model? In which case it will use the NTSC system of colour and not the PAL one. You will need to check if the TV can be switch to PAL system for DVD or if the DVD can output it as NTSC. Or you need a convertor box.
Jan 23, 2013 | Sony SLV-ED818 VHS VCR
Have Sony VCR model SLV-N80/N70 . Cannot get it to record using Samsung TV model SLV-N80,N70.
The television has nothing to do with recording. It is only required for playback. There are a number of possibilities depending on what equipment you have. Do you have cable, satellite, antenna? Your signal source has to be connected to the VCR either through the cable connector, or RCA video jacks.
If you have straight cable, connect the cable to the "ant in" connector on the VCR. The VCRs tuner will select the channel you want to record. If you are on antenna, you will need a Digital set top box (STB) to receive any channels.
If you have a satellite, cable box or digital STB, you must go from the output of the box to the input of the VCR. You can use the standard coax cable,but I would recommend using the audio/video cables for better quality. If using coax, the VCR will have to be set to either channel 3 or 4, depending on the boxes output setting. Using A/V jacks, the VCR will be set to "Line" or "Video" input.
Feb 26, 2011 | Sony SLV-N70 VHS VCR
My sony dvd slv-300p blue light progressive scan light is on and i cant do anything ?
my sony dvd vcr combo has a progressive scan flashing light when plugged in. i put a vcr in and now it's stuck. none of the buttons seem to be working. it is making a clicking sound inside on machine. how can i get this thing to work again?
Jan 23, 2011 | Sony SLV-D300P DVD Player/VCR
DVD freezes when playing on a Sony SLV D300P DVD/VCR
That particular unit is very sensitive to scratched or dirty disks. Remove the disk and make sure there are no finger prints, peanut butter & jelly, or popcorn butter stains on the back side. If there is, gently wash the disk under warm water with a DROP of mild dish detergent, being careful not to scratch the surface. Rinse the disk well and dry with a soft, lint free cloth (like an old cotton t-shirt) again being careful to avoid scratching the disk. Replace the disk and play.
If the disk is scratched, there is little hope of fixing the scratch so the unit can read it.....
Nov 20, 2009 | Sony SLV-D350P DVD Player/VCR
Sony SLV-350P stopped working
q marca de control puedo usar, porq el original no lo tengo
Oct 11, 2009 | Sony SLV-D350P DVD Player/VCR
Sony SLV-N60 stopped playing suddenly
Sounds like you have a head-clog. You can purchase a VHS Head Cleaner at Radio Shack for $5.00. If that doesn't work repairing your VCR is not cost effective when you consider that you can purchase a new VHS/DVD combo deck for under $125.00
Aug 17, 2009 | Sony SLV-N60 VHS VCR
Sony VCR ''Eats the Tape'' Model SLV-N750. It plays and records but doesn't release tape. It does not repond after I try to run forward or back and does not advance on ''Play'' but shuts off. Is there any...
If this unit is 4-7 years old then TOSS it. As time goes by the rubber gets soft and the units timing gets whacked. Repair will be more than what it's worth , unless your emotionally attached to it ...
Please rate!
Mar 13, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony SLV-272UC VCR player It shuts itself off in 2-5 seconds
Is there a VCR tape inside the unit? If there is a mechanical issue may cause your unit to auto protect and shut down.
Oct 01, 2008 | Televison & Video
Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Dec 04, 2007 | Sony SLV-D300P DVD Player/VCR
Sony SLV-N55 VHS VCR Logo
111 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
