Question about Panasonic TC-32LX50 32 in. HD-Ready LCD Television
Broken screen Reading this post you said the guy's screen needs to be replaced, not fixed. Please tell me how I would go about getting a TV screen "replaced"... In my area nobody seems to know where or if that can be done. I have a Toshiba (Theater Wide HD) Model NO.20HLV86; the screen is 10" tall and 19.5"-20" wide-diagonally. Glass on the screen is visibly broken. Audio works fine and if you put a DVD in, it seems to work just fine (obviously without any picture). Thanks! Susie
  • chulalink Jun 13, 2008
    The screen on my flat screen tv is broken please help me fine where to fix it.
  • Panasonic Master
  • 3,828 Answers
All you can do is chase a used
or buy a replacement TV
was it covered under contents damage insurance ?
this TV has been discontinued
the design of this screen means its put together
layer by layer .sandwiched ..not just a glass cover
a screen replace can't be done
unless the Toshiba company "TV parts division " has the exact same screen to supply to your local TV repair man
Even finding circuitry boards to be supplied for that model have a slim chance
Posted on Apr 11, 2017
SOURCE:
TVtechmaniac
  • 140 Answers
SOURCE: No analog channels
Restore and update the EEPROM data using a special EEPROM data copy jig. Part# TNPX25JIG. An instruction sheet is supplied with the EEPROM jig.
Posted on Oct 03, 2007
  • 205 Answers
SOURCE: connecting Panasonic DVD to TV
What kind of cables are you using to hook up the DVD to the TV? Are they they composite, component, or S-Video? What are the connectors you're plugging both ends of the cables into labeled? Are you plugging the audio cables into the TV or directly into the sound system?
Posted on Jan 12, 2008
  • 1039 Answers
SOURCE: Panasonic Viera TV with black band on left hand side
disconnect the x and y sustain boards from the power supply. then check the flex connector to the screen and reseat them. check connections on c boards at bottom and screen connectors. reconnect the power supply only after all flex cables are reconnected or charge from supply will burn flex cables. if still preent replace correcsponding c board. if still no fix replace panel.
Posted on Apr 25, 2009
dsacco86
  • 1077 Answers
SOURCE: Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
Posted on May 29, 2009
  • 80 Answers
SOURCE: Wide vertical bands of color through the viewing area. The sound is fine
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Posted on Jun 01, 2009
My tv screen has colour patches.how i remove it. I havent degussing coil so please tell me the method for remove it.tv degussing coil coil reading 18 ohm
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 11, 2015 | Televison & Video
Flat screen got tapped now the screen is black with white lines.
I can tell you, but don't kill me as I am just the messenger,OK?
You post on Craigslist an ad that you sell an LCD TV with broken screen; you put your initial price at $50 and you sell to the highest bidder within say a week.
Then you buy a new TV.
This is your optimal course of dealing with the situation.
Trust me if you like, I see that scenario on a weekly if not daily basis.
bobby @ www.coppelltvrepair.com
May 26, 2010 | Polaroid TLA-04011C 40 in. LCD TV
How you cann repair a broken plasma tv with out replacement parts
The tv plays fine my sreen is cracked on my Sony 42inch screen can some one help me.
May 13, 2008 | Samsung HCL4715W 47" Rear Projection...
Broken screen(S)
The Plasma Display Screen for 42PC3D is listed below.
LG 42PC3D Plasma Display Panel Replacement
Apr 13, 2008 | LG 42PC3D 42 in. Plasma Television
Broken plasma and lcd screen
Typically when the picture on an LCD or plasma begins to look screwy or like a spider web.. its gone for good and needs to be replaced.
You can have them repaired using a TV Repair guy but often it costs as much as a brand new tv. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Mar 19, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
LCD TV with broken screen, good picture??
samsung.com says it has to be repaired by local dealer. get quote first. probably cheaper to just buy a new one.
Jan 08, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
LCD display cracked
id put my **** in my *** and cough out a nut
1600$ i could pay a ***** 16 time to but a nut and lick
my booty hole
Dec 01, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Broken plasma screen
It is to expense to replace, I have talked to Daewoo parts and it cost about 2000 dollars for the panel. Better off finding another broken tv, that does not have a broken display panel and fixing yourself.
Nov 18, 2007 | Daewoo DSP4210GM 42 in. Plasma Television
Tv damage
My mothers 42' flat screen TV got knocked over. Now there is a large crack on the inside corner. What would it cost to get it fixed. Please contact me at [email protected]
Aug 27, 2007 | LG 42PX3DCV 42 in. Plasma EDTV
Panasonic TC-32LX50 32 in. HD-Ready LCD Television Logo
397 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
