Question about ASUS M2A-VM (0610839149438) Motherboard
Problem after installing catalyst 7.10 drivers
Hi, I have a win xp-sp2, AMD 5600+,2 gb corsair 667 with a seagate 120g SATA & a 300w SMPS. I installed the catalyst 7.10 drivers, Then I found out that my processor uses is increased (goes upto 100% sometimes) & also the M/B & processor temperature shows 40-45 degree celcius.
Before installing the catalyst it was only between 38-40 degree celcius.
So I formated & re-installed the XP-sp2 with ASUS M/B CD drivers.
then also I experiances the same problem.
Is it normal or will it harm my system?
What should be the ideal temperature?
Please help.
  • 44 Answers
The CPU should be kept under 55C.
The heating you mention is completely normal. An active processor generates more heat. Thus with the CPU usage issue you mentioned, the processor works harder and produces more heat. The heat levels you report are still very normal.
You don't state your video card, but if you are having problems with the 7.10 drivers, try older or newer ones. Also make sure you have the correct/latest motherboard drivers installed.
Finally (unrelated to posted problem), keep an eye on that PSU. If you have a power hungry video card, it maybe too much for it to handle.
Posted on Dec 18, 2007
I have Toshiba Laptop L300. It does not install xp . however it easily install Window 7
Probably because you have a SATA Hard Drive. If you want to install WIN XP, you may need to change your hard drive settings. For this go to the BIOS and change to Compatible Mode or IDE or Non SATA. The Reasons that WIN 7 install with no problems is because WIN 7 has already builtIn SATA drivers on it
Nov 18, 2010 | Toshiba Computers & Internet
Software diver
The official Catalyst software comes with the driver package from AMD (who now owns ATI) and you do not have to pay for it. If your version is asking you to pay you do not have the real thing. You can get it at
Jun 01, 2009 | Dell Computers & Internet
Ms-7061 msi motherboard will not install win xp with sata drive
The problem is that your version of XP does not have SATA drivers and therefore does not recognise your new drive. Vista does. If you Google the problem you will find many solutions on how to rectify the situation. Basically, you have to make a floppy disc with the correct drivers for your Motherboard's hard drive controller. Then, when you launch your Windows XP installer, it will ask you a question about needing to install 3rd party drivers. Yes is your answer. Tap F6 to ensure that the installer doesn't skip.Insert the floppy disc and then after the drivers are loaded, the installation will proceded normally. The other alternative is to leave your existing XP installation in place and add the new disc. Later you can clone your old disc onto the new drive and then remove your original disc.
Feb 11, 2009 | MSI : MS-7061-020 VIAKM400/A&V&L/SATA...
New hard drive not reconized, motherboard drivers
I had this problem on a computer recently. This particular motherboard may be needing the driver on the Windows XP SP2 disk. Your motherboard may have been made to use Microsoft SATA drivers. Othewise, there would have been a driver disk that came with the motherboard to let it see that SATA hard drive.
If it's a new hard drive, you have to reinstall the O/S so use a disk new enough to have SP2 included.
Jan 17, 2009 | Biostar K8VGA-M Motherboard
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
Need a full win xp installer with sata driver
which is the version of xp u have.. i think xp sp2 has the xp drivers or you can manually load the drivers when trying to install xp pressing a f6 key.. for which you must have the floppy disk with the sata drivers from the hard disk manufacturer..
Nov 06, 2008 | Microsoft Windows XP Professional With...
D845GLLY mother board unable to detect 250 GB SATA seagate hard disk
have u installed sata raid driver in Win XP ur system might not contain the driver for SATA drive pls download and install*%20XP%20Home%20Edition&lang=eng
pls rate me FIXYA if ur problem is resolved
Oct 16, 2008 | Intel D845GLLY Motherboard
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
SATA Drive
How large is the drive? Windows XP pre SP2 will not recognize a drive larger than 120G when loading from the cd. You will need to use something like Partition Magic to partition and format the drive into 100G partitions, install the OS (it may not see more than the first partition) and upgrade to SP2 and it will see the entire drive.
Jan 02, 2008 | Computers & Internet
Seagate 80 GB laptop hard drive not appearing in My Computer
i suggest u to re instal u r
remember- dont keep 2 operating system on u r hardisk man
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 26, 2007 | Seagate Momentus 5400.3 Hard Drive
ASUS M2A-VM (0610839149438) Motherboard Logo
56 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
