Question about Hitachi 43FDX15B 43" Rear Projection Television
TV Blinks on and off
My unit is 5 years old and is kept on a UPS at all times.
This started a few days ago:
TV turns on fine, works for a few minutes with no picture or sound problems and then it clicks off but the power button is stays lit.
After a few minutes "off" it turns itself back "on" - actually recycles like something is overheating. Sometimes it will do this for a half hour or so and then stay on for a long time (hours), other times it just never finds that long spell and recycles every minute or so. During all of this the picture quality and sound are normally just fine.
Today, as I was researching this problem on this site the blasted thing also started collapsing the picture from the top and bottom with the top and bottom being slightly rounded in the middle (like an oval) with a red border on the top and bottom left sides and a blue border on the top and bottom right side. Sometimes during this recycle process the picture is perfectly normal while other times its distorted.
I took off the screen back (part with the holes in it) and could see nothing obviously wrong other than it was pretty dusty. No burnt smells or blackened areas where something would have died.
Any suggestions before I have rioting among my teenagers?
Thanks,
Phil
  • ppetree Dec 11, 2007
    Thanks! I'll check in with my regular repair guy and see what he charges for fixing that...
    Also... used a can of air and blew it out, vaccumed the remaining dust out and reattached the back. At this point it's still cycling through but the picture has not collapsed since.
    Novelist:
    Champion:
  • 232 Answers
Phil, from your description it sounds like your convergence IC`s are about to fail, the intermittent off/on cycle is because as they heat up there drawing too much current, the bowed collapse tells me it`s the vertical convergence IC that`s the culprit. You need to get a tech out asap to fix this or they could short and take out the power supply as well and that`s just mooore money to fix it, hope this answers your question, BMW Rider
Posted on Dec 11, 2007
Apc xs1500 beeps 4 times
Check if the unit has a breaker on the back and reset it. The unit doesn't seem to be getting power.
Dec 03, 2012 | APC 1500VA BX1500 8 Outlet UPS UPS System
I have the exact same issue as the unsolved problem below on this page: I have a LG 42LC7D that is about 3 years old. A Problem with the LG 42LC7D-UB Television I have a LG 42LC7D that is about 3 years...
The power on problem is a cap in the power on circuit. The loss of signal for an areal is delayed. Nothing you can for DIY.It needs repair shop visit.
Feb 12, 2011 | LG 42LC7D-UB Television
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off....
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
Aug 04, 2010 | LG Televison & Video
Smart UPS 1400 - worth keeping or is it time to upgrade?
The basic design hasn't changed since day one...there maybe a few more bells and whistles now, If the unit is working fine...change the battery...and use the unit...BTW..just for your info large UPS'S are kept in service for 10-15 years or longer...hope this helps
Jun 18, 2009 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
Vizio, Model P4, manufactured in 2003 -- worked fine until 5 minutes ago
I have the same tv and the same problem. The power switch in the front flashes a bunch of times, but nothing else happens. Have you had any success in getting yours fixed?
Sep 08, 2008 | V, Inc. Vizio P4 Plasma Television
WD-62725 Need to reset to start
Good Day;
When TV will not turn on press the menu & input buttons on TV's panel, hold for 5 seconds. Count the blinks, eg; blinks 2 then pauses then blinks again. It should do this 3 times.l With that information respond back.Or the d-board is bad.
Good Luck.
Apr 21, 2008 | Mitsubishi WD-62725 62" Rear Projection...
20" Trinitron Wega
Good day.
First, Have your tv 's circuitry be resoldered. this might be a case of loose contacts particularly along the crt circuitry. the longer you operate the unit at this condition, the faster you are counting the possibility of shortening the lifespan of your tube. 9 years is quite a young age for a unit which has an average of 18years.
response is highly appreciated.
chris
Mar 29, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
SONY TV KEEPS TURNING ITSELF OFF!!
Its the BULB people! You need to change it every 3 to 5 years! I have had my sony 55" for 6 years... I had Best Buy come out 3 years ago, changed the bulb... it worked fine. Just started flasshing and shut its self off and back on again. Time for another bulb.
May 23, 2007 | Sony KV-28FX60 28" TV
Hitachi 43FDX15B 43" Rear Projection Television Logo
78 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
