Question about Toshiba Portege 3490CT Notebook
Rebuild I'm trying to rebuild a Toshiba 3490CT. I dont have a CD drive nor a FDD. How can I reinstall Windows without these?
  • redmaestro Dec 05, 2007
    There must be a way! If have tried via a USB flash drive but that didn't work. Is there an accessory I can source? Will a PCMCIA CD do it?
I have that laptop, and i haved the same problem.
This is the procedure i take, it is a little hard, but for me works:
You need: a Floppy Usb Drive, and a Dos Win98 bootable floppy disk (google Boot98se.exe). A copy of Windows XP. A desktop computer (may be needed).
First, you need to format the laptop's hard disk and copy msdos system files (MSDOS command: format C: /q /s). Then copy the I386 folder to hard disk and run C:\I386\Winnt.exe from the msdos system you installed. And then just finish the installation of XP.
I hope this solves your problem. Sorry for my bad english.
Posted on Mar 10, 2009
    Scholar:
  • 181 Answers
A PCMCIA CD drive will work, but only some models. Toshiba makes one, and it would be your best bet.
Posted on Dec 11, 2007
Toshiba satellite c55t-b5230 so now when I turn on black screen shows up saying"" reboot and select proper boot device or insert boot media in selected boot device and press a key"" can u help
its sounds like its not booting from its harddrive,it may be trying to boot from a dvd or cd device.when it ask you to select pick your harddrive,or if you have two harddrives pick your main one with your windows on it.
Apr 04, 2015 | Toshiba Computers & Internet
Trying to install windows 7 from usb stick in to toshiba 3490ct. i doesn't work. In bios i can not find usb priorty. what to do?
Hi there!
You can look for removable device, this is equivalent to USB.
Hope this helps.
Thanks
Apr 11, 2011 | Computers & Internet
Network adapters missing after recent rebuild
to re install the driver go to wwww.toshiba.ca
go to support
then click mobile computing
then click drivers and go through the prosses and search for the networking driver
Mar 02, 2010 | Toshiba Satellite M55-S135 Notebook
Picture is scrambled until it warms up. Can play DVD without any issues, but all other video inputs are scrambled for 30 - 40 minutes.
unit has a bad hyper module,NLA thru toshiba.try contacting tristate module or pts to see if they still rebuild them.toshiba part-23786198,MVPU13,PD0264A
you mite have to search to web a bit to find one if they dont rebuild them anymore.
Sep 29, 2009 | Toshiba 42H81 42" Rear Projection...
Media drive not found my laptop is toshiba sat a45 s150. after turning it off unsuccessfully, a blue screen error was displayed. if long pressed the power button to shut it down. after opening it again,...
Most likely the boot sector is corrupt.Try to boot by starting the Computer and hitting F8, or F12 you need to get to your start windows splash screen.Then try Start Windows from Last Known Good Configuration.If that don't work try Safe Mode.If none work you will need to recreate your .boot file, or try recovery fron CD.It gets complicated explaining how to rebuild your boot sector,If you have access to internet search "how to rebuild boot sector Windows XP".There are programs you can download and then load/run to rebuild boot.This has happened to me or someone I know and it is a pain to fix.You need some knowledge of how boot loads and how to repair.Try to get someone you know to help you.The problem was caused by the shut down.I think you ment XP can't Boot.Good Luck
Sep 11, 2009 | Toshiba Satellite A45-S150 Notebook
Portege 3490ct laptop how to remove hard drive tx much for help
my toshiba portege 3490CT is not working. i think the hard disk is damaged. i don't know what to do before a month there was a chance to see the option to select the boot option but now it is not working like that.
it totally can't start.
can you help me please?
Jun 08, 2009 | Toshiba Portege 3490CT Notebook
Error message when starting up: <Windowsroot>\system 32\hal.dll. Please reinstall a copy of the above file.
This issue happens if boot files are corrupted .. you need to have the Operating System Cd to resolve this problem . Considering you have windows xp you need to have the installation cd for windows xp .
you need to use bootcfg command to resolve the issue.
Go to bios and change the boot sequence to boot from the cd, if you are not able to boot from the cd. and then boot using windows xp cd .
Then push R to go to recovery console and use the below command
Boot to Recovery Console and rebuild the BOOT.INI file with the BOOTCFG /REBUILD
command.
May 09, 2009 | Microsoft Windows XP Media Center Edition...
Hi, i have windows xp home sp3 and turned my laptop on to get the ntldr is missing error, i have tried absolutley everything like using the windows install cd and the recovery cmd and have tried commands...
This file may be corrupted or deleted,u need to reinstall the OS ,it is the better way to stop viewing this error messages.it is rare case to handle this error without reinstalling the OS.
Aug 16, 2008 | Computers & Internet
My screen wont display icons
insert your WIN OS installation CD - But select recovery.
Attempt to rebuild windows...
This sounds like hard drive issue - sometimes a rebuild will temporarily get around this - but I would strongly recommend once running to do a surface / scan disk...
Aug 15, 2008 | Toshiba Satellite 5005-S504 Notebook
Toshiba Portege 3490CT Notebook Logo
240 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
