LG 32LC56 hi, iam trying to tune my LG LCD tv into the digital channels and its not picking all of them up......can u help.
  • 2 more comments
  • bobby211279 Dec 05, 2007
    it search's the channel automatically any way but misses out itv e4 etc etc
    cheers..its strange cause its the main one in the loft.
  • joannsmith4 Jan 25, 2009
    antenna hooked up  blue screen w/video1 appears no channel access . How can I get local stations?
  • Anonymous Mar 22, 2014
    lg 32lb1d tv won't auto tune
  • 231 Answers
Make sure you have a decent anntena to tv and try different positions to anntenna .Here is a link taht can be useful
Posted on Dec 05, 2007
I lost a few digital channels on an old LG LCD, tried to auto tune but could not retrieve. Followed a tip online that said to auto tune with the antenna cable which will wipe all saved channels, once...
hi your signal could be to strong, on the aerial cable the thin brad rap 4 strands around the center solid pin then retune in auto, if this does not work you may to manual tune it in, or get someone to check your aerial and you could try a firmware update on your tv hope it helps
Jun 29, 2014 | Televison & Video
Does not pick up standard channels for recording let alone digital channels
Are you trying to pick up standard analog channels (the kinds that have a fuzzy gray screen when there's no signal)? Those stopped functioning in 2009 when the nation ended the analog broadcast. You can only get digital channels now, except for a low-power broadcast station here and there. Nowadays for analog, TVs mostly pick up only radio stations.
Jan 29, 2018 | LG Televison & Video
LG M227WDP tuning problems
sounds like the memory IC to the TV has damaged. It is an IC, which stores all the cunsumer adjusted data, as digital signals, and retrives thme to the main system control IC, each time the set is switched ON.
It is an 8 solder terminal one, a small IC. Even though, its size is small, function of this part is very crtical, when the set works. This IC can be located very near to the main system control IC, and can be bought from most of the electronic spare part selling shops at your town.
The only thing you need is, to locate this component on main baord, and desolder it out, and resolder a new one in place. Somewhat skilled work indeed.
Feb 22, 2012 | LG M227WD-PZ LCD TV
LG 42LK450 flat screen.I tried auto tuning but didn't pickup channel 31. I tried manual tuning with no result. The old style TV I had prior to this could pick up channel 31 so it isn't a reception...
If your trying to receive over the air make sure the TV is not set to a Cable mode, if your on Cable your new TV is most likely a ATSC tuner (digital) and the cable company can map channels any way they want. If your old TV had the older style cable tuner, the lineup will be different.
HDTV has level thresholds, if the signal is weak you wont see anything, but the old TV would.
Without knowing much about where or what sort of TV your using, these are my best ideas.
Oct 26, 2011 | LG 42 42LK450 42 LCD TV
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Channel scan only finds 1 channel with basic cable setup on LG 42LD520
if you have a cable box just plug the cable box into a scart socket on the tv, switch the tv to the scart input and use the cable remote to change channel?Scanning for channels wont find anything because you are receiving the channels on a cable box. If you are refering to standard or digital tv signals and your not receiving any channels then either you are only scanning analogue tv and therefore wont pick up any digital tv channels, or your ariel is inadequate to receive an acceptable digital reception and will need to be upgraded. please state country you are in and what you are expecting to receive
Apr 13, 2011 | LG 42LC2D 42 in. LCD HDTV
Hi - I have a LG 42LP1D, I have tuned the digital stations, but it only starts from Channel 10. So I am missing 1 - 9
Are there Digital stations at 2-9? I'd try a rescan to find all channels it sees. If you are getting TV from over the air antennea, then it might be since the switch over the channels you might have been receiving before are not strong enough now that they are digital. Some locations are experiencing this.
Nov 23, 2009 | LG 42LP1D 42 in. LCD HDTV
LG LCD TV 37LP1D digital freeview tuning problems
Hi - I have the same problem. Also in Cornwall LG were not interested in helping because the TV was 3 1/2 years old. There was a possible fix in the end offered via LG at a cost of £180 + vat - a hardware update that might or might not work but I was not going to pay that so I now watch my LG 42 plasma via a £25 digi box from the CO OP. LG must have sold 1000's of these Tv's so when the digital switch starts in the more populated areas of the country I exect many more web postings.
Oct 31, 2009 | Televison & Video
Problem with tuning digital channel
I would believe from what you said, you have solved your problem. You will need a UHF antenna to receive the signal. Walmart or Radio Shack has a great amplified antenna that will work for you.
Mar 22, 2009 | Televison & Video
Digital channels
is the antenna a UHF/ VHF type? most of the broadcasters are broadcasting in UHF for the digital, also an antenna pre amp will help tune in those distant stations. you must point the antenna in the area of the signal. if you are able to pick up 35% of the singal or better, you will have a picture.
Feb 01, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
561 people viewed this question
Top Televison & Video Experts
