Question about SimpleTech Pininfarina 80GB External USB 2.0 SP-UE25/80 (SPUE2580) Hard Drive
Simpletech pininfarina problem
I bought an 80 gig portable hard drive a few months ago, and NOW it's not registering on my computer as a known device.
I know that the hard drive hasn't crashed, because every so often it will register, but only for about five minutes at a time.
my thoughts? it's a short.... but I'm not sure how to go about diagnosing this.
any suggestions?
  • 4 Answers
I have a SimpleTech 250g that suddenly stopped working. After going through all the various drivers and power supply checks, I opened the case and found that the disk drive was barely touching the IDE connector. I loosened the drive mount and slid it back onto the connector. Now it works well.
WD
Posted on Apr 22, 2008
It appears that this is happening a lot with external drives. Inside most of them is just a regular internal drive. In my case I simply removed the drive from the external enclosure (a SimpleTech 160 Gig) and installed it in my PC, where it works like a charm. Most people who have this problem go out and buy a replacement generic external drive enclosure for about $30.00.
Jp
Posted on Feb 10, 2008
Hi! I have a 250GB Simpletech pininfarina. I stored my PC stuff on the drive, but would like to now store information from my MAC. What do I need to do to get this working with my MacBook Pro? Jeffrey
hi balkanhope
Save information on a separate hd and wait for folowing operations to be successfull : format your Pininfarina in FAT 32 . Copy data back to Pininfarina . Connect Pininfarina to Mac and proceed further on .
Best regards ,
fanaudi .
Aug 18, 2011 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
I pug in my simpletech pininfarina 320 GB and muy computer doesn't recognise
I had the same problem some time ago. Have a look at these tips on how to fix external hard disk problems, maybe it helps you too.
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Dec 28, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
My windows 7 64bit pc is not reading hard drive
my simpletech bought 3-4 yrs ago is not being recognised on my windows 7 HP all in one screen and hard drives. How can i find the problem to fix hard drive issues..Thanks. CM CURRIER
Dec 12, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
External no longer recognized
Right click My Computer, Properties, then click on Device Manager.
Select Disk Drives then on tab menu Action, Add legacy hardware. Go through the setup and use CD's that came with Hard Drive otherwise search company site for drivers.
Oct 05, 2009 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
Opening SimpleTech 80 GB Pininfarina Portable HD Case
Screwdriver no. Knife blade possibly. Pry with the knife blade flat against the seam. Work s-l-o-w-l-y.
Nov 24, 2017 | SimpleTech Pininfarina 80GB External USB...
SimpleTech 80 GB Portable HD Won't Read
It sounds like a problem with the board inside the case,- the actual hard drive is probably OK. Opening the case will void any warranty but there may not be much left anyway. There should be 4 screws in the bottom of the drive,- front 2 may be hidden under a sticker. Try installing the drive in your new case or an empty drive bay inside your computer. I have had external hard drive cases fail before and the actual hard drive was ok.
Jan 23, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Computer doesn't detect
This is the best solution, unplug the device carefully, pick it up slowly, go to your room and stick it up your ***.....
May 30, 2008 | SimpleTech Pininfarina 80GB External USB...
SimpleTech 320GB Hard Drive- unable to detect the device
I had a similar problem with a SimpleTech 250g Pininfarina USB drive.
I went through the drivers, the power supply, the USB cables, and the various
computers, USB cards and Operating systems.
Finally I opened the case and found the disk drive was mounted too far
forward, causing the IDE connector to barely touch. I loosened the mount screws,
slid the drive back towards the connector, tightened everything down and it works.
Mar 15, 2008 | SimpleTech Pininfarina 80GB External USB...
Access
It sounds like you may have a problem with either your USB port or the cable that you are using.
Try plugging in another device into the USB port.  If that works without constant pressure, try using a different USB cable for your drive.
Nov 09, 2007 | SimpleTech Pininfarina 80GB External USB...
Computers & Internet Logo
280 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Ricky Ostrom
Ricky Ostrom
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
