Question about Hoover HDC6 Electric Dryer
Drum will not turn?
The dryier will heat up, but the drum will not turn? the belt is fine. could the motor brushes be worn? how do i get access, cos the motor seems inaccessable. thanks jon w bolton
  • 4 more comments
  • big jon Dec 05, 2007
    sorry should have said its a hoover hdc6 tumble drier, thanks
    big jon, bolton
    my wife is on her own and cant afford to get an engineer, i can do a bit but would like help, not cheap pathetic comments!!! thanks u twat
  • Dogzandi Jan 30, 2008
    Hi Jon, i have the same problem and i'm afraid the solution is not a cheap one. Having got my motor out (and a sod to do!) it is a brush less or AC motor. If like mine it breaks down and overheats then it is "cooked" and uneconomical to repair. It's also £95 plus to replace so i have thrown it in the garage until a cheaper option can be found. Like me would suggest you buy another dryer. If you get any further with yours then would be glad to hear, i have a friend who runs a white goods store and asked him to keep an eye out for a second hand motor. Also trying to find out what other appliances this motor is fitted to to widen the scoop. Hope this helps
  • big jon Feb 08, 2008
    any idea on how to get the motor out? cos it seems hard to find.
    thank you
    big jon
    dear dogzandi, thanks for info any help on how i can get to the motor or take it out? please. many thanks
    Big jon
    bolton
  • big jon Feb 11, 2008
    thanks for taking the time to help, will let you know how i got on big jon
  • 46 Answers
The motor will most likely be ok, its the capacitor on the motor that normally blows,( the white/grey cylinder with 2/4 wires coming off it, about 3 inches long bolted to the motor its self. can be purchased separtely in eletronic spares shops. all u need is the (uF) number on the original part.
Posted on Feb 07, 2008
Hi big jon, the comment posted by d-mac could be true. I was told that the tell tell sign was that the capacitor casing will look distorted or blown (by heat) in my case it looked fine but must admit i have not had it tested. I concluded as my motor was red hot it was buggered! If youv'e still not got the machine apart let me know and i will see if i can remember how i did it and let you know! Hoover build these things well and unlike some others (hotpoint) they weld up the cases as opposed to screwing them together thats why its a git to get to the motor but we can't have it all your own way. I have found a cheaper motor at £75 so its looking more promising for a repair - have fun
Posted on Feb 08, 2008
  • Dogzandi Feb 08, 2008
    Ok big jon you have to take the drum out of the machine-i said it wasn't easy. To do this first remove the lid, two screws holding at back then thump the top backwards from the front and it will slide off. Locate the screws holding on the front panel and remove these. Ok the grey matter is letting me down here as i can't remember what i did next so will need to look at the machine next time i'm home. Basically you need to slide off the belt (that spins the drum) not sure if i slid this back and off the drum or grabbed and pulled it off the motor spindle first (motor is back right when viewed from the top)
    The drum sits on wheels and need to be disengaged-i think i had to remove these from their mountings (front only) Not sure here (another need to look scenerio) but you may need to do some disconnecting from the back first (under the plate) before the drum will detach. If you get this far then the drum came out the front (see the cutouts) not the top, if your with me then the motor is there and secured by 2 bolts from underneath. I pulled mine out and then rejigged so i could plug it in and turn it on (not recommended at home folks!) i had the motor turning for about 5 seconds then stop and started to overheat. Also when i did it the heater element came on so didn't keep it running for too long in case it burnt itself out with the lack of air flow over it. Ok the grey matter has exhausted itself but if you run into any spicific problems drop me a line and i will do a visual on mine to refresh (well it was a month ago when i did it!!)
    Regards
Drum seems to be hard to turn and sqeals ?
Probably the motor and belt alignment, or a loose belt. Remove the access panel to expose the drum and the motor. Check to make sure the belt is not worn, frayed, or showing cracks. You should be able to purchase replacement parts online from the OEM website by referencing the appliance model number.
Oct 20, 2014 | Dryers
Drum not spinning on my indisit dryer
If the dryer has a belt fitted it may have come off or snapped, remove the lid or look underneath and you may see a broken belt.
If not belt driven the brushes in the motor may need replacing if they ahve worn.
Dec 29, 2012 | Dryers
I have whirlpool duet wed9200sq. The dryer seems to be working fine other than the drum will not turn. It heats fine and the drum will turn by hand, the belt is fine, no warning codes or other problems.
The drum and belt may be fine but the motor may not be. Since you seem to have access to the drum and belt, you can check to see whether the motor starts. Also check to see whether the belt and tensioner device are working OK
Sep 11, 2012 | Whirlpool Dryers
Hi i just want to check to see if belt is ok, but dont know where to look, i have a drum wont turn
Its probably your motor carbon brushes. If the machine electricals work OK and it pumps water in and out then the carbon brushes have just worn out on the motor. I had the same problem with my Bosch front loader. Easy fix and you can get help visually on youtube. If you are looking for the belt to see if it has come off, undo the screws that hold the plate on the back of the washing machine to access and sight the belt. Also this will give you access to the motor if you need to change the motor carbon brushes. Hope this helps Sue
Aug 09, 2011 | Bosch Washing Machines
Dirt Devil overheating Belt Okay
the belt is probably worn , so when the spool turns it heats up and looses friction with the belt.
Jul 05, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Drum not turning
no brushes in those motors you need new one or different dryer
Mar 11, 2009 | Hotpoint Dryers
Drum not turning
If you are certain that the motor was turning, then the only things that come to mind are that:
  1. The belt is stretched or worn-Replace as there is no adjustment.
  2. The drum is stalled, either because it has seized, or there is something stuck in the drum.
  3. The motor brushes are worn, and will not cope with load of drum, check brushes.
Try running it on fast spin without the belt on , if it spins o/k, then that would indicate the motor is o/k.
Please leave a fixya rating for my solution.
Thanks.
Feb 12, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
WHDSR209D Washer
if you have a rubber smell that means that the belt is burning through. Several problems can be the case.
1 bearing of the drum ( check if it turns freely if so the bearing is ok)\
2 the belt is worn and need to be replaced.
3 carbon brushes in motor are worn
4 bearing in motor is gone
open the backside of the machine and check belt.
think that is your problem
Apr 30, 2008 | GE WBSE2090A Top Load Washer
Drum does not move
dryer...there is no way to lubricate anything...all bearings are sealed. Get in there and look around. Turn off the gas and remove the line of you can't get access... and disconnect the power. Remove the back. Chances are you'll find that the motor, drum or belt is somehow jammed. Make sure any fan is turning freely with the belt off. It is possible that the timer is bad. This would keep the motor from receiving power. To test...remove the motor belt and turn the unit on.
Dec 16, 2007 | Estate TGDS740JQ Gas Dryer
Hoover HDC6 Electric Dryer Logo
266 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
