Question about Whirlpool WTW6600SW Top Load
DL code Hi...what does the code mean when it comes up dL? Thanks
  • dwayneluster Aug 04, 2008
    when this code is up the wisher will not spain can you help
Door Lock Error
Posted on Jan 15, 2008
Door lock
These fault codes are caused by a failure of the main control circuit board (the brain of the washer), this is the board that is behind the washer control buttons.
Feb 07, 2012 | Whirlpool GHW9150 Front Load Washer
Hi I have an HE 3t model 110 SN- CSR3704321. I am getting an error code F dl. Im pretty sure it means "door lock" because the door isnt locking....is there anything I can do? Thanks
'dl' does stand for 'door lock' indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 17, 2011 | Kenmore Elite 45986 Front Load Washer
We have a Kenmore Elite Quiet Pak 4 Washer that we have had for 5 years. It has been flashing F11 and DL back and forth for months. We had a tech come out (not sure he knew what he was talking about) and...
The symptoms are pretty specific for the F11 code on the Whirlpool Duet front loaders and clones (Kenmore Elite and KitchenAid):
If the washer starts to fill but the drum NEVER moves, your MCU is bad
If the washer runs through most of a cycle and then gives the F11 before (or during) a rinse or spin cycle, then you have the CCU relay problem.
If you are interested in having me repair your CCU for you, I offer that service on eBay (website coming soon). My username there is "jhagner"
Thanks
Aug 19, 2011 | Kenmore Front Load Washer
For about a week now, my Kenmore Elite top loading washing machine has the error code dL at the end of the cycle. There is a lot of clicking noises and then it displays the code.
Means a failed lid lock mechanism. You should replace the lid switch in the unit which will alleviate the dl error code. If you have any further questions message me back I await your reply Thanks Rick
Aug 05, 2011 | Washing Machines
Error code dl f, have tried turing power off, checking the door, and going to drain spin cycle--no spin---hit option button 4 times--- this only makes a clicking sound and then gives error code dl f
Hi
Thanks for using FixYa. Error “dlf” or "F dl"means a door latch failure. This means that you’ll need to replace the door latch assembly however before doing that you can leave the washer unplugged for 30minutes so that it resets itself. In the meantime when it’s unplugged just inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. To remove the top panel just remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If after doing this still the issue is not resolved then unfortunately you have to get the door latch replaced. Please do rate the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Sep 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not start, Shows dl F code, clicking is coming from rear of machine
Hi
Thanks
Rylee
Aug 28, 2010 | Kenmore HE2 Plus Front Load Washer
What does code F DL code mean?
Hi
Thanks for using FixYa. Error FDL means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
It has occurred due to
1. Door lock mechanism is broken or removed from door.
2. Door switch/lock unit failure. To unlock it follow the steps—
a. Unplug washer or disconnect power.
b. Check door switch/lock unit.
c. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Please do rate the solution if issue is resolved else post a comment for assistance.
Thanks
Rylee
Jul 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does f dl mean
Hello, F DL means
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
• Door Lock/Switch Assembly Failure
Ohm out the door lock solenoid and the door lock switches. This is most conveniently done at the central control board--use the wiring diagram/tech sheet to locate the proper pins to test from. Unplug the washer before starting work.
Thanks
May 19, 2010 | Washing Machines
Epic 9600 model door will not open machine will not engage code comes on screen dl f
hi there,
this code means you have a door latch error. this is why the door does not open or does not work. the machine automatically shuts down when this error happens to prevent the machine from running endlessly. call a technician to replace the door lock.
thanks
Oct 02, 2008 | Maytag Washing Machines
Whirlpool WTW6600SW Top Load Logo
132 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
