Question about Kitchen Ranges
Problem codes for self-cleaning ranges
When I set my range to self clean I heard a beep and when I checked stove the digital display showed a code of E2 F3. I stopped procedure then set range to self clean again and within a few minutes again heard a beep and this time the display showed E1 F5. This time I stopped procedure and waited approx. 15 minutes then tried again to clean oven and it worked with no further codes. My question is whether or not you know what these codes mean and if I need to worry about them since the range worked fine thereafter.
My stove is a Kenmore self-cleaning range
Serial # 1MME274320 Model # C 880 672239H3
  • 1 more comment
  • stephanie fields Jun 29, 2008
    i am turning my oven to bake a chicken it get up to 80 degrees and start beeping an f5 code what does this mean
  • Anonymous Feb 27, 2009
    I also try to self clean and then the E1 -F5- error comes on. I think the door is not latching. Is there something I can do to repair on my own?
  • Anonymous Mar 16, 2009
    the oven door is latched shut so we cant un lock it is there something that we can do to fix it with out hirring some one
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Posted on Mar 26, 2010
  • 126 Answers
E2 f3 oven to hot
e1 f5 check door / latch switch
if its working now dont worry
Posted on Dec 10, 2007
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
Magic chef self cleaning stove showing code f2
Hay wendy , tech sheet says to replace oven temperature sensor , ( make sure the fans are running properly ,good luck APPLIANCES R EN
Mar 07, 2013 | Magic Chef 31000 Gas Kitchen Range
F1 llight on, oven locked, stove beeps every few seconds
My stove did the same thing after I cleaned it. I had to have the sensor replaced. That is what the F1 code is.
John
Oct 01, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Stove door locked and continues to beep and flash code F9
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$%^^%$
Mar 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Amana stove stuck in 'lock' mode, door won't open
try hitting cancel is it displaying any error codes like e2 f3 try turning the breaker for five seconds then back on
Dec 28, 2007 | Whirlpool RF378 Electric Kitchen Range
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
1,695 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
