Question about Konica Minolta magicolor 2400 Laser Printer
Konica Magicolor2400W printer
When I turn the printer on and it tries to take paper, if makes an awful clunking noise. can't see anything trapped. Any advise?
Check the tray is inserted correctly. I picked ours up once and it pushed the paper feed tray up to high. It cause this exact problem.
Posted on Dec 30, 2007
  • Gary Hall
    Gary Hall Feb 11, 2014
    If it is a loud rapid clicking noise ratta tat tat I can just about guarantee that your "Waste Toner" container is FULL! I had the exact same problem, changed it out, and it stopped immediately
Pump motor stalls in my HP printer
When an inkjet printer is making "awful noises" it means that there is either a paper jam or the carriage can't move properly. Remove all paper and check for a paper jam - if this is not the problem, turn off the printer and see if you can move the print cartridge carrier by hand. If it is hard to move, clean the shiny carriage rod with a cloth and put just a drop of light oil on it. Move the carriage back and forth and clean it again - repeat until it moves easily and add a final drop of oil to the rod.
Oct 14, 2014 | HP Photosmart C7280 All-in-One Printer
Clunking noise when turning steering wheel going slow around corner
A lot of these Chrysler Town and Country vans had issues with the front stabilizer bar end links, usually you wont feel them move if you try to move them by hand, but they will make an awful noise clunk noise when turning or going over bumps slowly, i would suggest replacing the end links and that should take car of your clunking issue. Also the front lower control arm bushings separate as well and can cause this noise as well.... but i would replace the end links as a first step and go from there.... Hope this helps..
Sep 27, 2012 | 2003 Chrysler Town & Country
H p deskjet 3051a
Hi
Check through the paper path for any obstructions and manually remove them.
Check the cartridges and make sure nothing's trapped here [stuck papers].
Ensure there's no dry or damaged cartridges
Clear any print queues.
Disconnect the printer from power and from the PC.
Connect again after a while.
Try printing now.
Feb 29, 2012 | HP Office Equipment & Supplies
HP Photosmart C6280 All-in-One making weird noises
this is hope, i had this problem once. what it was was a small piece of paper that was caught in the rollers. i know you said this, but check again, I am almost positive this is your problem
lastly, check the black cartridge, take it out make sure nothing is stuck to the ink dispensary for clear printing
hope this helps and good luck
Apr 29, 2010 | Office Equipment & Supplies
Makes clunking noise and wont print 1quarter of
scanner lamp is not working. can i buy replacement lamp.
Mar 08, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Printer noise
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 25, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Misfeed detected. Correctly position the bypass tray. I have a BizhubC451 printer, and it makes a loud awful sound when I try to load paper into what I think is the bypass tray. HELP!
When you install paper in bypass tray you must touch the bypass button and tell it what size paper and type of paper you are using or it will jam everytime, let me know if this helps, e-mail me at dave.herron@att.net
Nov 18, 2009 | Konica Minolta Office Equipment & Supplies
Hp 4700n
Have you would try a different paper cassette.
Usually that clunking noise is associated with gears not mashing.
Is the lifter lifting the platform or not?
There might be something above the paper tray, maybe even the paper input assembly preventing the paper platform from reaching the top.
Check these and let me know what happens.
Oct 03, 2008 | HP LaserJet 4700N Printer
Konica Magicolor2400W driver for OS systm.
Dear vchiu28,
Here is the Konica Magicolor2400w website: http://printer.konicaminolta.com/support/index_ds.html. Just copy and paste the link onto another webpage. You will find a link for drivers and just click there to find the appropriate one for you:)
Feb 06, 2008 | Apple iBook Mac Notebook
Konica Minolta magicolor 2400 Laser Printer Logo
124 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
