Question about LG 50PX4DR 50 in. Plasma TV
Power/standby light on no picture or sound
I have an LG 50px4dr which responds to remote, I can change between inputs/hdmi/av etc however I have no picture or sound, on screen menus also do not display. Can anyone help me or advise what the problem might be?
  • philengen Jan 01, 2008
    Same symptoms on an LG Plasma 50PC5D.
    Turning power off & on doesn't help.
    Removing power and restoring power doesn't help.
Had same problem engineer seen and dignosed ysus board and buffer boards £577 to repair £
Posted on Dec 11, 2007
Samsung Plasma TV has standby power but no video
Make sure your video and sound cable is working (rca, hdmi cable etc) and your source component like dvd player or settop box is working. If cable is plug into a socket AV 3 or HDMI 3 for e. g. make sure the tv is source or input is selected the same like AV 3 etc.
It is possible for the TV to switch on or off but no picture or sound. This means the input board or tv tuner is faulty in which case you need a good tv repair technician
Oct 26, 2015 | Samsung PN43E450A1FXZA PN43E450 43 720p...
Does the LG 50PX4DR have a sound card? I have pefect picture but no sound
Yes. There is an audio AV board, called the sound card in your tV.
Mar 02, 2012 | LG Televison & Video
My LG model # 37LC2D won't turn on. The green power light will blink on standby then stay green. The screen will be black. Occasionally the picture will work fine and other times it is either black or...
Hello there,
I believe the Audio/Video Inputs/Outputs could be going out .
If you are using the HDMI try the Component cables and connections or AV cables with the S-video
if you swap the cables around and the problem is still there let me know and we try a few more steps thank you and don't forget to Rate
Jan 26, 2011 | LG 37LC2D Television
Only av input is working LG 42LC7D TV
I may put money that some one did stole your internal cable from the power supply to the main board !
Don't be surprised they did it to me at LG company .
Jul 26, 2010 | LG 42LC7D-UB Television
How do i adjust the picture to fit the screen?
The wide button on your remote adjusts the picture size. Each time you press it you adjust the picture. If repeatedly pressing the wide button is not changing the picture size check you cable/satellite remote control. Look for the hdzoom# button. There may also be an aspect or format button. When you adjust this the picture size changes and between the Sony remote and the cable/satellite remote you should be able to come to a happy medium. If the picture size still isn't changing you might not be set to the correct resolution i.e. 1080i on your cable/satellite box. It might be set too low or you might be in the wrong input (av 1 av 2 hdmi 1 hdmi 2) etc.
Jul 07, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sounds like power supply capacitors.
I would get it repaired before it stops working altogether.
Nov 11, 2017 | LG L1920P 19" LCD Monitor
Grainy picture on LG 50PC5D plasma
Did you try another HDMI cable?
Did you try another DVD player?
If the above try-outs does not work for you, then the fault is most likely with the HDMI input processor area. For this the set will require service.
Jerry G.
Feb 03, 2009 | LG 50PX4DR 50 in. Plasma TV
Picture goes to a lime green fuzz and then no piture or sound!
which AV connection are you using? HDMI or the cable supplied with the PS3, If using HDMI, you have to set the PS3 visual settings to HDMI, to do this, use the cable supplied with the PS3, and have the HDMI cable plugged in. Then while using the cables supplied with the PS3, switch the settings over to HDMI, then change the TV's input selector to your HDMI and confirm the settings changes. Hope it helps take care
Oct 17, 2007 | Sony Playstation 3 (PS3) Console
LG - 42PX5D Input switching problems
I think the problem stems from the HDMI port and scart ports, i have read somewhere on a sound and vision web site that these two conflict and when HDMI is in it only sometimes blocks out the scart signal. This could be what the problem of the freezing is, as when all said and done its just a very large pc monitor; and look at the trouble they can get in!.
Jan 17, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG 50PX4DR 50 in. Plasma TV Logo
133 people viewed this question
Computer Repairing
Computer Repairing
