Question about Gigabyte GA-8I945P-G Motherboard
MOTHERBOARD GIGABYTE 915
THE MOSFET BESIDE PROCESSOR IS OVERHEATING AND THEMOTHERBOARD WORK BUT AFTER 1 HOUR I NOT WORK
  • 1 more comment
  • AOPEN Dec 08, 2007
    no problem with fan
  • AOPEN Dec 20, 2007
    the problem still found
  • Anonymous Jan 16, 2009
    eternet cable unpluged
  • 44 Answers
Check your power supply - it could be providing too much current. There could also be a faulty VRM on the board, but there is nothing you can do about that.
A little thermal epoxy and ramsinks (video card ram modules sized heatsinks) might help.
Posted on Dec 18, 2007
I have a Acer AX1200-U1510A AM2+ Motherboard and i would like to upgrade the processor, ihave 4 gigs of mem and a 1 gig Gigabyte Gt 610 graphics card. I only have a 240 watt power supply what processo
Should work with a processor of the same socket type. I'd seriously upgrade the psu myself. Personally I'd upgrade the motherboard and processor to a quad core, and get the fastest ram, look at ebuyer.com, you can buy a bundle upgrade package for less than you may think. :)
Sep 04, 2012 | Acer Computers & Internet
GIGABYTE.COM
GA-M61SME-S2L motherboard?
1) http://www.cpuid.com/news/58-cpu_z_gigabyte_g1_edition.html
It's CPU-Z from CPUID.com, but made especially for Gigabyte motherboards.
This way when you change a parameter in Voltages, or system bus clock, (FSB), you can see the changes in real time.
2) EasyTune 5 from Gigabyte,
http://gigabyte.com/MicroSite/121/tech_20041125_px_et5.htm
That is just the features, and G.U.I. shown. (Graphics User Interface) The actual download website is below at the bottom link I listed,
http://www.filecluster.com/Drivers/Firmware-Bios/Download-Gigabyte-EasyTune.html
http://www.filecluster.com/downloads/Gigabyte-EasyTune.html
The above is the actual download page.
Where it states 7-Zip info, go to the right, and click on the blue - External Mirror 1 - (Has a green Down Arrow to the right of it.
After you click a small window will come up on the right -
Opening motherboard_utility_gbttools_gbt_et5pro.exe
Click on Save File. Observe the top of the small window that comes up on the left. In the wording at the top of the window tells you where the file will download to.
Go to where it states, then DOUBLE-click right on the file name,
(motherboard_utility_gbttools_gbt_et5pro.exe )
Now follow the directions, and install EasyTune 5.
This is Gigabyte Support, and the download page for the motherboard manual,
http://ee.gigabyte.com/products/page/mb/ga-m61sme-s2l_20/download/manual
REMEMBER;
1) Take -> BABY steps. Change a parameter in small increments.
Change the parameter in one small increment, then let the system (Computer) run for 24 hours. This is a 24 hour burn in test. Pretty accurate, but do not 'stamp it in stone'.
2) You can only overclock so far. Overclocking creates heat. After some time the air cooling you are using, is not going to be adequate.
3) You can only overclock so far because you will be changing the FSB for the Processor. This also changes it for the Ram Memory, and expansion slots.
Ram Memory typically operates at half of the Processor's FSB.
Change the Processor FSB too much, and ram memory will not work.
Neither will the expansion slots. Their frequency rate is determined off of the Processor FSB also.
4) Overclock too much at first, and you risk burning up the motherboard chipset, and Processor, and Ram Memory.
Regards,
joecoolvette
[Read up on all the overclocking articles you can. This may also help you ]
Aug 21, 2012 | IO Shield Gigabyte I/o Ga-m61sme-s2...
I have a gigabyte m85m-us2h motherboard with a athlon 2x4 630 processor with a 460 watt coolermaster power .and 2gig of ddr2 ram. put windows 7 32bit on and computer went fine for 1 day shut it down and...
THAT IS THE CODE FOR MEMORY OR MOTHERBOARD ERROR.
TEST YOUR RAM STICKS ONE AT A TIME, UNTIL YOU FIND ONE THAT WORKS. IF IT DOWS NOT WORK WITH ANY SINGLE RAM STICK, THEN YOUR MOTHERBOARD IS THE PROBLEM
Nov 23, 2010 | Intel Motherboard
Overheating intel 915 2.8ghz processor 50degrees
The overheating problem (ie. thermal shutdown) is most likely caused by a faulty CPU fan or dust clogging the CPU fan and heatsink.
Check the BIOS CPU fan speed could be set too low, check the fan speed/temperature setting.
If this problem is not fixed, then the CPU will eventually fail.
Check the fan to see if it spins freely, if not then replace the faulty fan.
If the fan and heatsink are cligged with dust, loosen and remove the dust and use a can of compress air to blow away the dust.
Sep 22, 2010 | Intel Pentium D 915, 2.8 GHz (BX80553915)...
Overheating problem
have you controlled in windows task manager for programs that is overloading processor and ram? if not press ctr+alt+del go to processes and in the end of windows look fo processor loading, is given in%. do this when your computer is seem to go in shut down ,,a little before (ex after 2 hours).
if you find somethin there , aprocess that is overloading your cpu kill process imediatly presing end process button. if you didn't find something there , have you cleaned your old thermal paste from cpu before aplying a new one? have you inserted cpu cooler in his right place if yes , try to change your processor because is it damaged due of ecsess of heating per wat that it can. prove with another processor , if the problem persist then put acooler to the chipset that dont have a cooler if problem persist you must change a MB.
another question have you suficcient watage in your power supply to cover all your devices you have in your pc?
Apr 07, 2009 | Intel D915GAG Socket 775 Motherboard -...
No display
replace your motherboard
Jan 27, 2007 | Gigabyte GA-8VD667 Motherboard
Gigabyte GA-8I945P-G Motherboard Logo
273 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
