Question about Brother IntelliFAX 4100 Laser Fax
PAPER JAMMED CAN NOT MAKE A COPY,HAVE A MESSAGE JAMMED PAPER.BUT NO JAMMED PAPER INSIDE.CHEKED EVERYTHING.CLEANED EVERYTHING.ALSO CAN NOT GET CONFIRMATION THAT FAX WAS SENT, DOES NOT PRINT IT. THANKS A LOT!
  • Anonymous Jan 15, 2008
    paper wont feed through
Open back door and check the fuser sensor flag as they somtimes break
Posted on Jan 04, 2008
  • 286 Answers
You have a stuck sensor.
Open the rear door and make sure there is no paper in there.
Remove your toner from the drum and make sure there are no bits of paper stuck under the toner cartridge.
l
Look inside the drum chamber for the little plastic levers that actuate the sensors. Make sure they move back and fourth freely.
Posted on Dec 30, 2007
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
I've tried printing twice and ended up with a paper jam. I cleared it, but also saw what looked like ink splatters inside the printer. I took the cartridges out and cleaned up the splatters and replaced...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Dec 06, 2010 | HP PhotoSmart C4280 Laser Printer
Paper won't feed into printer & output slot jam error message
reboot your pc.unplug cables make sure you remove papers jams located at the back of your printer
Jun 24, 2010 | Canon PIXMA MP610 InkJet Printer
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Jammed paper message
I get a Jammed paper message on the read out, I have cleaned out all the paper and pressed stop/cancel button but it still keeps saying that there is a paper jammed in it.
May 04, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Paper jam
There are several things that can cause a paper jam error, even though there is no paper stuck. The most common is that the paper pickup rollers are worn or dirty, and can't grab paper. Even though there is no paper jammed in the machine, it will show the error message. The solution is to clean the roller with alcohol and a lint-free cloth (don't use paper towels). If the roller is very worn, you will need to replace it.
Feb 04, 2007 | Canon Image Runner 1630 Copier Copier
Brother IntelliFAX 4100 Laser Fax Logo
202 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
