2000 Audi A4 Logo
Posted on Aug 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A warning light is signaling in the dash board and it makes a loud beeping sound; connot make out what the signal is because the light in the dash board is not all lit; need to see a manual to figure out what the signal is
L.K.Computers Ltd
Level 2:
  • Expert 73 Answers
  • Posted on Aug 30, 2009
L.K.Computers Ltd
Expert
Level 2:
Answers
73
Questions
0
Helped
23708
Points
168
First chek level of ,water cooling system,water in washer windows,oil level,breake pads, beake fluid
2005 Toyota Sienna turn signal indicating beeping very loud.
Theres ablackbox under steering that control sound. Open it n turn off. A partsplace can help u
1helpful
2answers
2017 Kia Sportage. Turn signals blink inside and outside, but no turn signal sound in cabin? What's causing this?
apparently it comes from the sound system speakers.
https://www.google.com/search?q=2017+kia+sportage+replace+turn+signal+sound+generator
no sound coming from blinkers and door chimes
CarGurus.ca https://www.cargurus.ca > Cars > Discussion-t66999_d...
This speaker carries all the dash sounds such as seat belt warning, turn signals, reverse cross traffic, welcome sound, etc.
14 answers · 13 votes: Following. My daughter just told me her 2018 Kia Sportage is doing the same thing. Local ...
1helpful
2005 jeep wrangler when i turn lights on beeping starts
did you RTM read the operators guide yet,
it tells you why all beeps beep and what lamps flash, (warning) and why. did you?
you turn on, the head lights, (what about 1st click , parking lights"?)
and does the dash cluster, show warnings of any kind?
if a door is ajar the system will think, you are exiting veh. with lights on and tell you, buy beeping ,etc.
but on my jeep it says on the dash DOOR, or on EVICs, (not yours)
the newer car even tells what door IS AJAR.
mine on shows , "DOOR"
the operator guide will say, check all doors for ajar, and get warning clear before driving....etc.
if you lost the guide here it is for free
http://justgivemethedamnmanual.com/jeep/jeep-wrangler-owners-manuals/
click the 05 link
ignore beeps, there are just too many .. i look at the cluster and learn to read it..
my newer jeep 08 can produce 1000s of errors,,,,, possible.
in fact the intent it to beep to tell the driver to look at the cluster
for in depth, causes.
see chapter starting on page 136'
once sound it makes is Check gauges chime. so check them.
and headlamps left on
and door ajar.
page 63
NOTE: If the driver's door is left open, and the headlights
or parking lights are left on, the "High Beam
Indicator Light" will flash and a chime will sound.
Lights-On Reminder
If the headlights or parking lights are on after the ignition
is turned off, a chime will sound when the driver's door
its a crude system, and evolved to complex in 2007.
"DOOR" or RF-door , on mine.
or
NOTE: A tone will chime if the turn signals are left on
for more than 1 mile (2 km).
search manual for
"chime will sound"
'02 Rendevous beeping randomly, no lights or trouble indicatiors on. Beeps when parked, beeps while driving, no rhyme or reason apparant. sometimes goes 10 or 15 minutes without beeping, other times beeps...
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the left front speaker. The radio receives audible warning requests via the class 2 serial data line from the IPC or body control module (BCM). If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime--200 pulses per minute
Medium rate chime--150 pulses per minute
Slow rate chime--50 pulses per minute
Single chime
Is the sound heard different from typical Audible Warnings ?
Fasten Safety Belt Warning
The radio activates the fasten safety belt audible warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, slow rate and duration (5 pulses). The fasten safety belt warning sounds and the fasten safety belt indicator illuminates when the following occurs:
• The ignition switch transitions to ON.
• The inflatable restraint sensing and diagnostic module (SDM) detects that the driver's seat belt is not buckled, signal is low. The IPC receives a class 2 message from the SDM indicating the driver's seat belt status.
If the seat belt is buckled when the ignition is turned on, the chime does not sound. If the seat belt is buckled while the chime is sounding, the chime stops. If the seat belt is unbuckled after the initial transition to ON, the chime does not sound.
Headlamps On Warning
The radio activates the headlamps on warning as requested by the body control module (BCM). The BCM sends a class 2 message to the radio indicating the chime frequency, fast rate and duration, continuous. The headlamps on warning sounds when the following occurs:
• The ignition is OFF.
• The BCM determines that the driver's door is open, signal is low.
• The BCM determines that the headlamp switch is in the park or head position.
Key-In-Ignition Warning
The radio activates the key-in-ignition audible warning as requested by the BCM. The BCM sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The key-in-ignition warning sounds when the following occurs:
• The ignition switch is OFF.
• The body control module (BCM) determines that the driver's door is open, signal is low.
• The BCM determines that the key-in-ignition switch is closed, signal is low.
Turn Signal Reminder
The radio activates the turn signal warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The turn signal warning sounds when the following occurs:
• The ignition switch is in the RUN position.
• The turn signal switch is in either turn position, sensing, within 1 second, an open to B+ transition in the turn signal control circuit, left or right turn.
• The vehicle has traveled a distance of 1.2 km (¾ mi) by counting pulses on the vehicle speed input circuit.
The IPC turns OFF the turn signal reminder when either the ignition switch is turned to the OFF position, or the turn signal switch returns to the OFF position, sensing, within 1 second, no transitions from open to B+ in either of the turn signal control circuits, left turn or right turn.
Additional Chimes
The following chimes will turn ON when an associated indicator/message turns ON in the IPC/DIC:
• ABS indicator
• AWD Disable indicator
• Battery/Charge indicator
• Brake indicator
• Change Engine Oil indicator
• Door Ajar indicator
• Hot Coolant Temp indicator
• Low Brake Fluid indicator
• Low Fuel indicator
• Low Oil Level indicator
• Low Oil Pressure indicator
• Low Tire Pressure indicator/reset
• Low Washer Fluid indicator
• MIL (Service Engine Soon) indicator
• Oil Life Reset
• Park Lamp Out indicator
• Rear Hatch Ajar indicator
• Service Traction System indicator
• Service Vehicle Soon indicator
• TRAC OFF indicator
For a description of an indicator refer to Indicator/Warning Message Description and Operation .
For diagnosis of an indicator refer to Symptoms - Instrument Panel, Gages and Console .
Did the Mechanic check for DTC'S - diagnostic trouble codes in the BCM or insturment cluster ? Did you try a Buick dealer ?
1helpful
2answers
Beeps while driving
My van did this aswell, you must have a power sliding door, when it is not latched properly this warning goes off but it won't say on your message center "door ajar". Stop and reopen the door and close it again no more bell. good luck.
10helpful
2answers
After flat tire, tire pressure warning will not go out even after making sure pressure is at 44psi. How do I reset dash?
44PSI?? is that what your car recommends...
1. check and make sure that your tires are inflated to the correct pressure
2. turn the ignition switch to the ON position. If the low tire pressure warning light comes on, push and hold the tire pressure warning reset switch (think the switch is in the glovebox, but not sure) until the warning light turns off and then release the switch.
3. now press and hold the tire pressure warning reset switch until the low tire pressure warning light blinks three times.
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you an Audi Expert? Answer questions, earn points and help others
