1998 Volvo S70 Logo
Posted on Aug 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi; how're you doing under normal situation, can a driver change the air pump & valve(related to emission problem,i guess) by oneself? thks object:a normal car(sedan)
Anonymous
Level 3:
President:
  • Master 1,489 Answers
  • Posted on Aug 29, 2009
Anonymous
Master
Level 3:
President:
Answers
1489
Questions
7
Helped
766269
Points
4966
Yes, this is a job of low-medium dificulty.
Charlie
1helpful
Hi i hava two code im ford focus 2007 p0491 and p0410 no can fix what doin
P0491 is a Secondary Air System fault Bank 1.
Bank 1 refers to the passenger side off the engine. The combination valve for secondary air injection did not preform as it should & set a fault. The valve is located under the plastic engine cover at the rear of the right cylinder head.
There is a plastic tube from the air pump to the valve that breaks, the valve sometimes fails, there is a vacuum hose that opens the valve that also sometimes fails & rarely the Air Injection Vacuum Control Solenoid Valve fails. The plastic tube unpluged/cracked or failed valve are the 2 most common failures.
If it's a vac leak it's in the small hose from the solenoid valve to the combination valve. The super charger may affect the vacuum, but I would expect to see more codes if it was really messing with things. The air injection system only runs for about 1.5 minutes on cold starts. If the plastic tube is broken you will hear what sound like a small exhaust leak.
P0410
What does that mean?
The P0410 code refers to the emissions system. The AIR pump puts air to the exhaust to lower emissions. It takes in outside air and pumps it through two one-way check valves into each bank of the exhaust.
About 90% of the time that this code is set, the one-way check valves have worn out or failed and allow water (which occurs naturally in the exhaust) back into the pump. In any cold climate, especially in climates with higher humidity, this water may be more excessive. The water partially fills the AIR pump, it can then freeze. When the PCM commands the pump on, if the pump is frozen it cannot turn, thus overloading the circuit and "popping" the fuse.
Symptoms
Possibly symptoms include:
* MIL illumination obviously
* Hesitation on acceleration
* Noise from a bad/stuck AIR pump
Causes
A code P0410 may mean that one or more of the following has happened:
* Water may have collected in the AIR pump or the vent solenoid and frozen or corroded the pump
* Blown AIR pump fuse due to freezing up
Possible Solutions
Note: There is a technical service bulletin (TSB) regarding this code for a number of GM models. The TSB calls for the replacement of the AIR pump and the installation of a new secondary injection hose.
Additionally, if you simply replace the AIR pump the problem may return again (and again). If you replace the pump, also clean out the hoses and replace the one-way check valve. In a few cases, people have put a small hole in the rubber cover on the pump which allows any water to drain out.
Also, please note that this may be covered under the emissions warranty on the vehicle. If your vehicle is out of bumper-to-bumper warranty, check if the emissions warranty is still valid!
* Replace the AIR pump AND one-way check valve
* Test and clean the AIR pump AND test and replace the one-way air check valve
* Replace the AIR pump inlet hose
* Replace the AIR pump fuse (found under the hood)
The above are the interpretation of the codes.
Let me know if you need further assistance.
Regards.
P0410 & P0491 code, what can I do to fix the problem?
this is an obd2 trouble code table, it can help you understand the meaning of code.
for p0410, you can try:
Replace the AIR pump fuse (found under the hood).
Engine light is on and codes say 410 & 491 secondary air pump
Causes
Possible SolutionsNote:
There is a technical service bulletin (TSB) regarding this code for a number of GM models. The TSB calls for the replacement of the AIR pump and the installation of a new secondary injection hose. The TSB can be found on this ACDelco site.
Additionally, if you simply replace the AIR pump the problem may return again (and again). If you replace the pump, also clean out the hoses and replace the one-way check valve. If this is on a GM model that the TSB applies to, follow those instructions in the link above. In a few cases, people have put a small hole in the rubber cover on the pump which allows any water to drain out.
3helpful
I get code P0410 secondary air injection malfunction ,also bogs down then surges
Note that this may be covered under the emissions warranty on the vehicle. If your vehicle is out of bumper-to-bumper warranty, check if the emissions warranty is still valid!
5helpful
3answers
Will a broken timing belt and water pump require replacement of engine head valves 1 and 3?
If this is 2.0 liter duel over head cam than engine damage most likely will happen if the timing belt brakes sorry about the bad news .
2helpful
2answers
Engine light on...onstar says its the secondary air emissions
this code is caused by the electric engine air injection pump, it is known as the "Secondary Air Injection System" and is part of the emission controls on your car, this is all to common a problem and requires the air injection pump assembly to be repalaced to correct the problem, then the code must be erased.
19helpful
Mazda rx8 fault code p0410 secondary air system we have a mazda rx8 2006 model, p0410 fualt code has come up, want should we looking to check, test and poss change?
The P0410 code refers to the (secondary air system) emissions system. The AIR pump puts air to the exhaust to lower emissions. It takes in outside air and pumps it through two one-way check valves into each bank of the exhaust.
  • Water may have collected in the AIR pump or the vent solenoid and frozen or corroded the pump
  • Blown AIR pump fuse due to freezing up
Possible solution:
This may be covered under the emissions warranty on the vehicle. If your vehicle is out of bumper-to-bumper warranty, check if the emissions warranty is still valid!
  • Replace the AIR pump AND one-way check valve
  • Test and clean the AIR pump AND test and replace the one-way air check valve
  • Replace the AIR pump inlet hose
  • Replace the AIR pump fuse (found under the hood)
It is really only an emissions issue and won't harm your car's engine ot drivetrain. It will however mean you won't pass emission testing if you live somewhere that tests for that like I do!
2helpful
Code po410
Possible solution:
7helpful
2000 Hyundai Accent
00-30-001 2000 ACCENT DMTL DIAGNOSIS: DTC CODES P1401, P1402 AND P1403
p1402 - dm-tl air pump motor is shorted or disconnected.
2000 model year accent is equipped with a new enhanced evaporative emission system. this new system is capable of measuring leaks as small as 0.020" diameter. the new system pressurizesthe evaporative emission system with a diagnostic module for tank leakage (dm-tl), while the previous model's system appliedengine vacuum through the purge valve to detect system leaks.
service information
vehicles that have the check engine light illuminated and have dtc p1401, p1402 and p1403 stored in the ecm should have their electrical systems diagnosed related to the appropriate dtc. these codes are not related in any way to an evaporative emission system leak. the conditions that set the diagnostic codes areas follows:
p1401 - dm-tl air pump motor current draw is higher or lower than expected (normal = 17-36 ma).
p1403 - dm-tl changeover valve is shorted or disconnected
Top Volvo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Volvo Expert? Answer questions, earn points and help others
