Question about GE Spacemaker JVM1640SJ Microwave Oven
Sparks when in use
When cooking, my microwave sparks where the plastic hinges hold the racks in my oven. The problem is sporadic, but I fear that a fire could start if I leave my oven unattended.
Any suggestions on what the problem could be? My microwave model is not on the recall list although the problem is the same.
  • OldAsDirt Feb 04, 2008
    If I'm understanding this correctly, I believe I'm having the same or a similar problem. It's not the hinges, it's one of the hooks on which the rack rests, specifically the left rear hook. If I use the Microwave without the rack, or with the rack resting on the bottom, there are no sparks. If I place the rack on the hooks (where it is supposed to be) there are sparks.
  • 833 Answers
Sonja, I'm not sure what hinges you're speaking about. If you are referring to the bumpers on the ends of the wire racks that are used for convection...move the racks away from the wall. Generally, you should not have anything metal in the unit when it is just microwaving....they are for convection use. You will not start a fire but you will shorten the life of the magnetron if you continue to allow the sparking condition.
Posted on Dec 17, 2007
Sparks when cooking
Make sure no metal item (forks-spoons or oven rack) is touching the outer wall of the microwave. That will cause sparks. If all that is OK then there is usually a metal fan type blade in the microwave top called a stirrer blade that may be out of place and rubbing the cavity causing sparks. Try to pin point the spark area so you know where to look for the problem. Sparks usually mean metal is touching metal somewhere.
Mar 29, 2015 | Whirlpool MH7135XE Microwave Oven
JVM 250vwoo1
Pry off plastic tab. Clean up burn marks with sand paper and touchup paint. Order a new rack clip. Also clean any burn residue off rack.
MOST IMPORTANT: After the repair, do not put the rack back in unless you are cooking on it. Running the microwave with nothing on the rack is what causes this to happen.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Sep 05, 2014 | GE Microwave Ovens
Is there a generic replacement rack for microwave/convection oven jvm1490bd003 ? i can not believe GE wants 60-70$ for a simple rack!! robbery :(
Every oven has a different size and shape rack, which is why they have to charge so much. You could try Ebay, they go for around $25 there.
See if this one will fit
Used GE Microwave WB48X10013 AP2031271 Cooking Rack
Apr 16, 2014 | GE JVM1490 Convection/Microwave Oven
When using the oven tonight, i saw sparks coming from the plasic clip on the right that holds the rack up. i tried again later and still hearing crackling/sparks. is it possible to replace that...
Yes it is possible to replace the plastic clips. However thats not the problem. The problem is exposed metal under the plastic clip. Remove the clip and you will see it. You need to sand it down so that it is smooth, then use ceramic paint to cover up the exposed metal. You should check under all 4 clips to be safe. Clips are a little tricky to get out, just insert a screwdriver on either side and pry gently.
Mar 01, 2011 | KitchenAid KHMS155L Microwave Oven
Put A foil pan in it to warm and now has a burning smell and makes a noise, not heating. assume we blew something Sharp R-7A85
Never, never, never, never, never put anything metal in a microwave oven! No metal, no pot or pan, no silverware, no plate with metal trim ... nothing! No "Jiffy Pop" (comes in a metal container). Use ONLY microwave safe containers. Some claim there are health concerns (dangers) to using anything plastic in a microwave. The claim is the chemicals in the plastic which were not meant to be consumed are consumed as they are burned out of the plastic into the food. These chemicals are know to some to be cancer causing. I am not making this claim ... only passing on what I have heard about plastics. For myself, I don't use plastic or paper (fire hazard) in the microwave. For one thing, I don't like the taste of food that has been prepared or reheated in a microwave in a plastic container - particularly coffee.
Having said that ... here is what is going on. You probably reflected microwave back into the magnatron and ... well ... cooked it. In my area, such damage is not economically repairable. The tech wants $100.00 to look at it, magnatrons are typically $50 to $100 or more. There could also be other damaged parts ... repair bill could be more than a replacement oven.
If you find a oven that comes with a rack, here is how that works. You will observe that the rack sits with flat feet on a carousel which is typically out of the range of the microwave OR has been built to reflect the waves in a manner that they will not damage the magnatron. Typically, a rack will be made of very small round stock that will not reflect much in any single direction ... besides that, you would have food on the rack that would absorbe most of the energy anyway.
If you replace this oven, please ensure you review all the warnings and instructions that will accompaly your new oven ... even the seemingly silly stuff like "dont use the microwave in your bath tub to heat the water".
I believe your oven is cooked. I'm sorry you are having this trouble and I hope my comments have helped you to arrive at a workable solution to your problem.
Thank you for your interest in FixYa.com
If you are pleased, the courtesy of a positive vote and response will be appreciated by this volunteer effort on my part.
Oct 03, 2010 | Sharp R-7A85 Microwave Oven
I have a GE Profile convection/microwave oven, Model No JVM1790 BKC01. One of the plastic clips that holds the oven rack in place caught fire. Location of clip is top front right hand corner next to the...
Most rack support problems I have seen are from food splatter or grease getting around the support and even seeping behind it. Once it starts burining it must be replaced. It is really important to keep the area around them clean and dry and free from food splatter. A Microwave cannot tell what is on a plate or on the wall or rack support, and every food particle cooks each time the unit is run, until it turns to a carbon deposit and starts to attract the microwave energy and starts to ARC to that point.
Then it burns up the part it is arcing to. Have to replace support and scrub the area and inside of the cavity perfectly clean.
Oct 25, 2017 | GE JVM1790 Convection / Microwave Oven
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Micowave sparks a fire
I had the same exact problem. My clips arced when I ran the unit and I also observed flames which was quite unsetteling. A work around for me, since I don't use the rack was I took it out then removed the clips. All that was required to remove the clips was a pair of plyers grabing each cliip at their base. I pulled firmly and there is alittle resistance but with a firm pull straight out they'll pop out.
But I have to say if you use rack your probably looking for a new mircowave.
Dec 27, 2008 | Whirlpool MH1150XMQ Microwave Oven
Rack in microwave
You should not have any metals in the oven when the microwave is on. If you are just doing convection cooking, the metal rack should be in so that what you are cooking is raised up so the hot air can surround what you are cooking.
Apr 04, 2008 | Kenmore 63672 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
604 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
