Question about HP VECTRA VL PC Desktop
Wavy or distorted monitor
The screen looks like it has a waistline on one side. is it my monitor or the whole computer problem? it looks like this when i turned it on a while ago.
how do trouble shoot or repair it back to normal? thanks
Hi Tech_PC
i havent thanked u for your response yet. ur suggestion helped.
thank u
Posted on Jul 07, 2008
  • 67 Answers
Wavy or distorted issues only arise if electronics or anything that has magnets in it is near it or on the CRT ( the really huge monitors) so try moving it elsewhere ( In this case you can hire someone with the "magic wand " to zapp the colours back)(general tv repairer.If its an LCD (flat and small screen) it may be dying as the transistors are wearing out ( They usually last for 4 yrs) The only thing you can do is replace the circuit board or the panel . If you have another pc or laptop try to connect it to the monitor and if the pictures are perfect ,its your graphics card .
The best solution to this is to move the screen to another place without electronics or to connect it to a laptop or pc to see if its ok. If the symptoms persist i recommend you to buy another perferably dell screens 19" Lcd as they are cheap and provide good quality.
Sorry for the huge legnth of this Hope it helps :)
Posted on Dec 09, 2007
  • Tech_PC Dec 09, 2007
    P.S sorry about the structure of this writing
LCD Monitor screen distorted on left side of screen
While i may be a resolution issue as suggested by the three previous posters... your monitor may be defective.
without knowing the following it is all a bit of guesswork.. model of monitor, video card, operating system version... etc...
generally, if its a resolution or aspect ratio issue, the screen will look wrong across the whole screen... to me it sounds like a monitor fault, rather than a aspect ratio issue or resolution issue.
I'd try it in another system/laptop. if it works fine there, then it probably is an issue with the graphics card, or the driver for it, in the original system.
if it looks wrong in more than 1 system, i'd have a look, using the buttons on the monitor itself, and try to reset the monitor to factory defaults, and the see if it has an auto adjustment feature, and if so, use that, and see if that improves things....
If it looks the same on two systems, and you have set the screen to factory defaults, and played with the on screen display settings via the buttons on the monitor itself, ie auto adjust, etc.. then I'd guess you have a faulty monitor...
it'd help if you could post a pic of the the issue to tell more easily.
hope this info helps.
May 17, 2012 | HP w1907 LCD Monitor
I am at work right now looking for solution to my monitor at home. The screen is so wavy that I cannot read the text very good. My 5 year old plays on the computer a lot. And all of a sudden the other...
Connect the monitor to a different computer (laptop or desktop), to see if the problem "follows" the monitor.
Connect a different monitor to your computer, to see if the video-card in your computer is generating the "wavy" display.
Move any "power-bars" and PC Speakers *FAR* away from the monitor, to eliminate electrical interference.
Oct 22, 2010 | E-Machines eMachines Monitor E15T4
Whole screen pink and edges distorted green its on my dell insiron 6400 laptop
check the connctions on your monitor. I had this problem on my monitor for 2 months and it started shortly after I cleaned my desk so I thought maybe I had accidentally pressed a button. I found out later that a wobbly connection to the monitor gave faulty connection info to the screen so I just touched it today and it went magically white. Please try it before attempting anything else!
May 13, 2010 | ASUS VW222U Monitor
Page will not fill whole screen
you haven't mentioned much about ur monitor but generally adjusting the screen resolution to different setting should resolve the problem
while also there are screen setting buttons on the monitor to adjust the size of the screen and others
hope this helped
pls rate the solution
Jun 28, 2009 | Dell Computers & Internet
Wavy distortion on bottom of screen
Hi and welcome to FixYa,
Depending on the length of time the monitor has been used, this would often indicate a power supply problem, more specifically a low main B+. Since you are familiar with electronic components & circuitry, you might want to check the big filter capacitor right after the bridge diode on the hotside, likewise the capacitor after the single diode on the secondary side and or the capacitor along the + rail going to the FBT/HOT.
Good luck and thank you for using FixYa.
Feb 02, 2009 | ViewSonic A90f+ 19" CRT Monitor
Screen appears squeezed from left and right sides
Sounds like the video card settings are over-riding the monitor settings. Go to display settings in control panel, and try the one that says "recommended". The other thing I have found out is sometimes the monitors start doing strange things before giving out completely.
Nov 30, 2017 | Dell E771a 17" CRT Monitor
Monitor has dark wavy lines on edges
Well... sure it fixable, but it is going to cost you a bundles... Since you own this monitor for about 10 yrs. It's time for you to give yourself a new LCD monitor for the Holidays... :) Have nice day!
Oct 13, 2008 | HP Computers & Internet
Monitor flickering and adjustment buttons locked
If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down ... This may also cause a flickering affect.
Distorted or skewed image on monitor. Issue: Distorted or skewed image on monitor.
Cause: This issue can occur from any of the below possibilities.
  1. Windows issue.
  2. Loose or defective cable.
  3. Refresh rate issue
  4. Interference.
  5. Bad monitor.
Solution: Windows Issue If your monitor has a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please see document CH000121 for software or setting related issues.
Loose or defective cable You may receive a distorted image when the cable is loose or defective. Disconnect the video cable going from the back of the computer and verify that no pins are bent, burnt or broken. Once verified re-connect the monitor cable.
Refresh rate issue If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down or across the monitor slowly or fast. This may also cause a flickering affect. Additional information about how to change the refresh rate can be found on document CH000558.
Interference A distorted image can be caused by magnetic or other types of interference. Verify no speakers, fans or other magnetic devices are close to the monitor.
Bad Monitor If the above possibilities have been checked it is likely that the monitor is bad. To verify this it is recommended that the monitor be temporarily disconnected and then connected to another computer. This can be a friends computer, a work computer, and/or a computer at a service center. You can also help verify a defective monitor by connecting another monitor to your computer. Note: Connecting your possibly defective monitor to another computer will in no way harm the other computer.
Good Luck/Please dont for get to Rate.Thank You.
Jan 17, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Hp Pavilion Monitor
Monitor was working then I downloaded a game and got the warning message to change the resolution. I changed it and now my monitor is stuck in black. What can I do now?
Dec 03, 2007 | HP Pavilion F1703 17" LCD Monitor
Screen image display distortion
What you are reporting is a problem in the pincushion circuit in the horizontal section of your CRT monitor. Usually this is from an electrolytic capacitor that is no longer willing to play nice with all the other components.
It is repairable, but get an estimate first. If the repair bill appears to be around $100, you would be better off to put a few more dollars with that and buy an LCD TFT monitor.
If you are quoted $25 or $30, it is probably worth having repaired. Just keep in mind that these older CRT monitors have age on their components, and once repaired, it will still be an old monitor.
Only you can decide which choice is right for you. At least now you have a few facts to help make the decision.
I hope this helps.
Nov 06, 2007 | Apple Multiple Scan 1705 Monitor
HP VECTRA VL PC Desktop Logo
131 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
