Its my first prob encounter. My 3110c battery power running low. I switch it off and go to sleep. Early morning when I wanna switch it on again, it hangs during upload for the 1st time. White Screen with Batt Power Icon only shown. I cant switch it off n none of the buttons functioning. Take out the batt and reinsert again. Switch on back n the same thing happen. Retry again w/out my sim card n memory card, still the same prob. I cant even access the Software Updater due to this problem. Thanks for any infos, suggestions, supports and comments.
mostly it depends on your usage, more the usage faster the battery drop.
In general, below are few ways you can reduce your battery drop.
1. keep screen brightness moderate or low
2. User power saver
3. dont keep your tab for charging for longer time, it reduces battery life (eg, you might keep it charging before sleep until morning)
4. Kill all background running apps when not needed
4. check your carrier signal strength, use airplane mode when there is not network
5. keep in sleep mode when you are not using (just hit lock button
Sounds like it is locked up. There should be a power switch on the back. Switch it off, leave it off for a few minutes, then turn the back power switch on again and push the front power switch. If no rear switch, pull the plug. Windows doesn't like hard power downs, but if your system won't recognize the keystrokes or mouse movement, tere is nothing else you can do.
If you use Windows 7, u might have hybrid sleep activated. This is similar to hibernate. When u choose SLEEP, your computer goes to hibernate. Sometimes this hibernate just hangs. You have to reboot computer. Try pressing the power button for several seconds (10-15). It should power off the laptop. If not, unplug the charger and remove the battery for a few minutes. Then try to start it up again.
I could not say whether the problem comes from mmc or from the set because 3110c has very weak software So firstly scan the mmc with updated antivirus.Secondly. Flash the set . Thirdly contact nearest mobile repairing center .
sometimes a very low battery will cause screen-freeze...once fully charged, remove the back cover and pull the battery out for 30 seconds and replace the batt and cover...the phone should power on.
First make sure you are using fresh lithium batteries. These cameras indicate low batteries quite early on. Rechargeables even when freshly charged are marginal.
If the problem persists remove the batteries. Set the camera switch to the off position. Set the focus switch to manual. Wait at least a minute. Then replace the batteries and switch on again.
Operating with low batteries can confuse the firmware and it may be stuck in a low-battery loop. If this is the case this should reset the camera by allowing the electronics to power-down completely.
If this does not work you wiil have to contact pentax support.
