Question about Motorola Mobility HS850 Consumer Headset
Motorola HS850- I have had two - suddenly after a couple months use they both became "static-y"
  • jenken Jan 06, 2008
    This happens to me sometimes, but I think it's just "wind" getting to the earpiece... not sure though.
    Problem Solver:
  • 9 Answers
Almost all of moto bluetooth headset get this problem. i think H680 is much better that HS850 or H700. i'm using RAZR2 V8 and almost all BT headset have static problem. So i end up with korean's and french's BT headset which have much lower static.
Posted on Jan 08, 2008
Lost instruction manual for my Hs850 headset. need to sync to different cell phone device, if possible. Blackberry curve 8520.
is on the Motorola webpage.
check there
Oct 31, 2010 | Motorola Mobility HS850 Consumer Headset
Won't pair with Motorola HS850 headset
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Sound problems
I have had the identical problem from the beginning. It happens in humid weather. Unplug the set while it's on, wait a second, plug it back in, and turn it on. Sound should be fine.
Jan 27, 2009 | Philips 32PT71B 32" TV
I can't find my instruction book for the Motorola Headset HS850.
Just google the instructions. Should get a pdf option to download ??
Nov 07, 2017 | Motorola Mobility Universal Wireless...
Motorola HS850 Headset gone silent
I bought a new HS850 and guess what, I got this hearing problem on the very first day ...phew ! I did the pairing with my Motorola A1200 phone and it worked for once, even the sound was coming in the earpiece and then I put it to charge for the first time and once done, I again started it up and it got connected with the phone and after that there was no sound in the ear piece. I was going nuts....about what could be the problem.
So i decided to delete the earlier paired profile from my phone and do the pairing again and guess what...It Worked....:) So you can try that out too....
Dec 06, 2007 | Motorola Mobility HS850 Consumer Headset
The volume button(decrease) does not work
If the button is "detached" as you say then its broken. If the headset is still under warrentee you can get a new one if not you'll need to buy one. Not fixable.
Aug 05, 2007 | Motorola Mobility HS850 Consumer Headset
here is the link to the user manual; Check pages 27 and 28, describes all the possible on/off configurations for the signal light. during a call, you can turn it off by pressing volume up and volume down at the same time. If there is no activity on your phone for 5 minutes, it should turn off. What phone are you pairing the headset with? This link gives some more simplified instructions; If you need the signal light permanently off, then it is not possible without modifying the headset - the easiest permanent way would be to paint over the signal light with a small brush and an appropriate dark coloured enamel paint. It may need 2 or 3 coats to completely block the light. This may possibly void the warranty. You could do the same thing with a piece of black pvc electrical tape cut to fit the light, if you want the option to change back later (probably also need redoing every couple of months). The warranty would not be affected with this method. Another possibility would be to open the unit up, and see where the signal light source LED is situated - don't remove it or disconnect it, but if the legs are long enough, you may be able to gently bend the LED out of the way of the little window to the outside. This would certainly void the warranty. Hope this helps, please ask again if you need more info :)
Jul 13, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola HS850 Bluetooth headset
no u need to take it to phone manufactuer
Jun 28, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
108 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
