Question about Dynamic MX91 Handheld Blender
Mx91 Dynamic Blender Bearing failure
Is this worth repairing with a new bearing and seal assembly
    Scholar:
  • 127 Answers
Since the blender costs over $600, yes.
Posted on Jul 10, 2009
Replace ball bearing
Part of the blade assembly or drive socket assembly?...
check here:
Amazon com vitamix wrench assembly Home Kitchen
Jan 30, 2014 | Vitamix Blenders
Can you repack the blade bearing on Vitamix Blenders?
On the Vitamix blender models we have here in NZ it is not possible to repack the bearings, you just purchase a new blade assembly complete with bearings and the driving clutch.
Nov 11, 2013 | Vitamix Super 5000 Work Top Blender
Vitamix TNC 60 oz container leaks when in use. how to replace seal and or bearings?
If it is not the HUGE blade retaining ring under the beaker a bit loose then you will be buying new parts to repair it. The only other possibilities are beaker cracked and leaking (new beaker) or bearings & seals worn (new blade & bearing assembly)
Oct 21, 2013 | Vitamix 5000 Work Top Blender
Leaking blender jar
Oct 30, 2012 | Vitamix Super 5000 Work Top Blender
Burning smell in the container and outside when in use
Seal under blade Assembly, on shaft leaks, allows liquid to enter bearing, which then fails, creates heat and overheats rubber, thus the smell. Bearing and seal must be replaced.
Jul 11, 2012 | Breville BBL600XL. 5-Speed Blender
The blade in my Super 5000 wet container turns very stiffly.Should I take it off and lubricate it? There also seems to be water visible under the bottom of the container.
Stiff or stuck blade problems can be fixed by replacing the two bearings and seal inside the blade assembly. Care must be taken in installing the new bearings as not to damage them. Ideally they should be pressed in, on a press, but they can carefully be tapped in using a sockets to match inner and outer races so your not tapping on the balls.
Mar 20, 2011 | Vitamix 5000 Work Top Blender
Need to know how to remove shaft and blade from lower bell assy as the blade is bent and bearing is bad excessive play in shaft
There is an exploded diagram here which should show how it dismantles
http://parts.robotcoupe.net/mp450.html
Not sure where you are geographically but hope that helps.
You can buy the bearings, I  was going to suggest that it wasn't worth repairing and then I checked the price of a new one!!!!  It is worth repairing I can't believe how expensive they are! Good Luck
Jan 12, 2011 | Robot Coupe MP450 Handheld Blender
Cuisinart model # SPB-6 (tx) leaking when unit is together, seal is in place, still leaking. Unit is not damaged, please advise.
Check if leaking at the bearing for the blade.
If the bearing has worn, dis-assemble and coat shaft with food-safe grease and re-assemble. Also coat the seals with the grease.
Sep 09, 2009 | Cuisinart SPB-6 Smartpower 6 Speed Blender
Osterizer Blender
You can replace the Osterizer "Standard Blade Assembly" (which includes a new rubber gasket) without buying a new and expensive glass jar. See http://www.householdappliance.com/blenderparts.html or one of the other appliance repair parts websites. After 20 years of use, it's time for a new blade and bearing.
Feb 27, 2008 | Blenders
Dynamic MX91 Handheld Blender Logo
413 people viewed this question
Top Dynamic Blenders Experts
eyecam
Marvin
Marvin
Are you a Dynamic Blender Expert? Answer questions, earn points and help others
