Question about SENAO High Power 200mW USB WiFi 802.11bg Adaptor with External Antenna (655216003026) Wireless Adapter
Problem with Senao and Vista
My senao wlan works perfectly on my old computers even an old IBM with USB 1 however on my new Compaq it connects for around 1 or 2 mins and then the connection drops and windows reports no networks found. Unplugging and pluging back in makes it work for another couple of minutes.
If I connect it via a powered hub then it works for a longer period - sometimes an hour or more.
The hub power seems fine as other usb items work fine. Strangly I have a friend who has the same problem and his external usb hub is not powered but by plugging through it the Senao WLAN works as mine does.
I have downloaded all latest drivers , have spent hours on phone and email with HP - updated more drivers and bios - still no go. Have emailed Senao and had no response.
I m going crazy with this as I spend a lot of time on board a boat and need the extended range to access the marina WIFI.
Any Suggestions will be gratefully recieved
I could not read the vista file
Posted on Nov 14, 2008
Port forwarding...
low download speed....
Posted on Jan 14, 2008
Noy finding ip address senao wireless AP
Hi. Here is the manual.
http://www.senao.com/images/www.senao.com_English/NL-2611CB3-PlusDelx-Manual-V1-0.pdf?CATNO0=D&CATNO1=D3&CNT=1
Set your PC to use the static IP 192.168.1.10, netmask 255.255.255.0.
To login to the web manager, go to http://192.168.1.1. Leave the username and password blank. You can now configure the device and assign IP address etc.
Jul 18, 2009 | SENAO NL-2611CB5 PLUS (NL2611CB5PLUS)
Drivers for windows vista 64 bit
i want wireless senao engenius driver vista to HP laptop
Dec 10, 2008 | SENAO High Power 200mW USB WiFi 802.11bg...
CANNOT LOGIN TO MY SENAO DUE TO FILTER PROBLEM
press the reset button n configure it again
Nov 27, 2008 | Computers & Internet
Senao USB wifi 802.11
I am afraid that I have had to make an assumption as to the precise modle that you have but the following link should be correct, it gives you the option to download drivers for the
Senau NUB362 (Ext)
http://www.senao.com/English/Default.aspx?TYPE=test.htm&PT=searchDownload1&sf1=D331&sf2=NUB-362(EXT)&sf3=&tv_TCAT_POS=0&CATNO0=D&IDX=3.2&CNT=1&CATNO1=D3
numerous drivers for different operating systems seem to be avaliable.
if I have chosen the worng type a pull down list is avaliable showing the differnt Senao product drivers avaliable.
Nov 14, 2008 | SENAO High Power 200mW USB WiFi 802.11bg...
I ha senao 358 and only can get transfer call and I can't call out side line
Maybe you have bought clones/fakes of Senao 358 from China.
Original Senao 358 is made in R.O.C Taiwan
Hire you can see original Senao 358 : http://senaoservis.com/senao358.htm
Also on this page you can see more info in text : MAKE SURE IT IS ORIGINAL
Aug 22, 2008 | Lands Phones
I made firmware 1.39 to SENAO ECO3220
hey maick, I have the same proble, but I fix it, try this: 192.168.1.254, for me work fine, after that I reload the new firmware. now is working fine. good luck, jose luis Ogawa
Jan 19, 2008 | EnGenius EOC-3220 (EOC3220)
Problem in SENAO High Power 200mW USB WiFi 802.11bg Adaptor
There are a few things you can do in this case. First, I would check to see if you have your network profile set up correctly. This is done by going in to your wireless properties and checking the profile to see if the encryption password is correct as well as the encryption type and so on. Next, you can go in to the device manager and make sure the wireless adapter is recognized and enabled. If you need help doing these things, let me know.
Aug 07, 2007 | SENAO High Power 200mW USB WiFi 802.11bg...
SENAO wireless adapter not working
I assume you have the unit set to alocate ip addresses automatically in other words the dhcp is set to enabled in the settings. If so it maybe that the address is registering wrong, you can either click start>run> then type ipconfig /flushdns, or uninstal your wireless network card in device manager then restart the pc to automatically install it again as this will set it back to default, but remember to make sure obtain ip address automatically is enabled in the adapters properties on the tcp/ip properties.
Aug 06, 2007 | SENAO High Power 200mW USB WiFi 802.11bg...
SENAO High Power 200mW USB WiFi 802.11bg Adaptor with External Antenna (655216003026) Wireless Adapter Logo
535 people viewed this question
Top SENAO Computers & Internet Experts
Terry Hair
Vernon Taylor
Are you a SENAO Computer and Internet Expert? Answer questions, earn points and help others
