Question about HP Compaq Presario R4000 Notebook
Display WOW u will never solve this Display went bad  (Vertical stripe appeared)  Compaq fixed it,,,  Next a hot spot (Very Hot) appeared in lower RH corner causing a black aura type spot.  Out of warrenty now  so i used it as a desktop with a external mouse keyboard and monitor.  This worked fine for a few months now the external monitor shuts off after windows starts on the R4000,,,,, Fn F4 does nothing,,  trying to use the original restore disk dont work as it still blacks out.  The monitor is fine as i reconnected it to a regular desktop and it checks out ok.
  • 1 more comment
  • prozaciswack Dec 21, 2007
    Interesting, I have a similar vertical stripe in mine (in the furthest right 4th of the screen about 100px wide) but it is about a year out of warranty. I wonder if this is a wide enough problem that they would still fix mine.
    Not sure about the display dying though...not something I've experienced yet.
  • belgiumrom Jan 31, 2008
    yes, same issue, i thought this was related to screen itself....
    there is also some overheating at times but maybe is not related.
    no steps really yet, i'm in the googling phase
  • cleopatra007 Feb 04, 2008
    I have a similar problem. the display sometimes completely shuts off and at other times, displays weird colors. frazzled green instead of black and sometimes, pink instead of white.
    whe i attach an extenal monitor, it seems to work fine. let me know if you guys have found solutions to this issue. Even temporary suggestions are welcome at this point.
    Genius:
  • 1,601 Answers
Sounds like your builtin graphics controller went bad.
Posted on Dec 21, 2007
Compaq presario cq40 working on but display not off hot solve it? please help me
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Aug 13, 2011 | HP Compaq 6735s Notebook
After turning screen ix initially blank although backlight is on. Gradually vertical stripes appear of varying width and colour. Eventually lines change to horizontal bars howing sections of the correct...
Your display is faulty. Check out ebay for a replacement. Changing the display is straight forward. If you get your display we can instruct you on replacing it.
Hope that helps.
Nov 09, 2010 | HP Compaq nx6325 Notebook
Display problem
Hi, I had a similar problem and fixed it. Open the calculator and you will see that the ribbon connecting the LCD to the PCB has white and black stripes. The black stripes are the actual conductors. The white pieces are isolation between the conductors and serve the purpose of glueing the ribbon to the PCB.
Take a small flate screwdriver, its thickness has to be that of the white stripes. Heat up the end of the screwdriver with a hot air gun/lighter/hair blowdryer or whatever. Dont make it too hot. It should only be hot enough to melt the glue holding the ribbon to the PCB. Press the screwdriver on a white stripe and move the screwdriver up and down the white line which is on the PCB. Do this for each white stripe individually. Reheat the screwdirver if necessary, since there are a lot of tracks/stripes to cover.
It may be useful to use two screwdrivers: one to heat the glue of a white section and a second to cool/set the glue so that the ribbon is held in place, instead of coming loose because the glue is too hot. I did it only with one mildly hot screwdriver. It shouldn't be so hot that it actually burns you. You can test the temperature by pressing it against a hot melt glue stick (those used in a glue gun), if it melts the glue (but not too quick) it is hot enough.
It is unlikely that the ribbon came loose from the LCD, but if the previous didn't work you can try doing it on the LCD aswell.
Jun 17, 2010 | Sharp EL-334AB Calculator
My compaq display suddenly appeared a vertical black stripe dividing screen in two. Is there any solution for this issue?
restart your laptop if this problem occurs and check out for your graphics driver.
if problem persists, you have got some hardware problem..
Jan 27, 2010 | HP Compaq Presario C500t Notebook
Vertical black stripe on screen
Hi my name is Roety,
I can help you with your issue ,
The black strip is either a bad panel or part of the lower buffer board is bad. There are ribbon cables that run from the panel to the buffer it may just be a loose ribbon connector
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 29, 2009 | Gateway GTW-P42M303 42 in. Plasma...
Lcd screen getting broken!
you need to replace the LCD panel. go to the HP site and look for a replacement part.
Jun 02, 2009 | HP Compaq nc6320 Notebook
Epson C1100 - Vertical faint stripes on colour photos
see if this solution fixes the problem.
Also clean the print head using instructions in the manual
http://www.fixya.com/support/t241840-smudges_color_printing_black_ok
Mar 04, 2008 | Epson Aculaser C1100 Printer
Green Vertical Stripe on Toshiba Satellite A80
This sounds like something has messed up your crystals in your display, and while I do not know that much about laptop displays this sounds like it can only be fixed by a technician or by replacement.
Jan 23, 2008 | Computers & Internet
Computers & Internet Logo
174 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
