Question about Xerox WorkCentre M-24 Color Copier
Adding xerox workcentre 24 driver to new computer
Adding printer and browsing for all printers does not work, and the driver file does not have an executable... cant seem to find the correct name/address/url to add the computer....
  • Anonymous Dec 15, 2007
    want 2 know dealers phone no address
  • Anonymous Mar 22, 2014
    Adding a printer will not open the driver supplied with the printer.
  • 208 Answers
If you press the machine status button.
Print reports
Common Settings. It will include the printer settings.
IP address, printer name etc. I think that information is on page 3.
But you can print those settings easily.
If you need to change them.
Log into the machine with the login or access button, the either 1111 or 11111, will access the tools you need to set up the network.
Make sure you set the IP for manual, not auto, and also turn OFF the IP filter.
If the printer is set to DCHP and auto, it will change the IP on you every time you POPO.
Posted on Dec 05, 2007
I need Xerox workcentre M18 Drivers
Xerox WorkCentre M118 Drivers
The required drivers can be downloaded from the above link from Xerox Official Support. Select the operating system you have on your PC and download / instal the files.
Hope it helps! Good Luck!
Apr 09, 2011 | Xerox WorkCentre M118 Printer
How to install xerox workcentre M118 for windows 7 64bits
I am one of the technician trained and specialized in different computer  and printer manufacturer.
Here is one of the instruction on how to install your printer to windows 7 64 bit
-run the driver downloaded from the site, then select the location
-Go to Control panel
-choose devices and printers
-add a printer
-add a local printer
for Standard TCP/IP port has already been created on the computer, choose the port from the Use an Existing Port pull-down menu, next, and then skip to step 10.
For the port has not been created on the computer, choose the create new port button, choose standard TCP/IP from the Type of Port pull-down menu, click Next, and then continue with step 8.
-put the IP Address or hostname of the printer
-check if the query for printer is set to automatic, then next
-choose have disk
-choose browse, then select where you save the driver
-choose the required printer model
confirm the name of the printer
-choose do not share, then next
-choose finish
for more information visit:
Contact number:
English 1-800-821-2797
Spanish 1-800-821-7726
Hours of Support - 24 x 7
I hope this will help a lot.
thank you for choosing Fixya
Feb 27, 2011 | Xerox WorkCentre M118 PCL 6
What can i download the xerox workcentre 3119 laser printer driver for window 7
Xerox Workcentre 3119 Windows 7 Drivers
Please visit the above link and download the drivers and Installation guide.
Feb 27, 2011 | Xerox WorkCentre 3119 Laser Printer
Where can I get a driver for a Xerox WorkCentre XD155df (laser printer/copier) for a 64-bit Windows 7 operating system. The Xerox web site says it does not have the driver and doesn't support the product...
you wont get a win 7 64bt driver!! they havent and will not develop one.. You can use the XP 64bt driver and install it manually in win 7 .. :) yeah a neat trick here is how.. download and unzip xp 64 bt driver files to a folder called FX on your desktop
  • plug printer into pc it will say new hardware found,,
  • wait for the wizard to finish and fail..
  • click start, right click computer, click properties then device manager
  • your printer will be there highlighted in yellow,, right click and select update driver,,
  • click searh a specific location and browse to the FX folder on the desktop.. click next and watch the magic..
  • if it says driver not supported (contine / cancel) click continue and accept the warning message..
thats it... Amazingly win 7 accepts vista and xp drivers in this manner..
May 06, 2010 | Xerox WorkCentre XD105F Laser Printer
Try to scan using 1 touch, and after 10 seconds of "connecting" message reads "failed to connect"
You can go into the maintenance area under machine status and change your USB speed, then try replacing your USB cable.
Make sure the Xerox machine is the only bi-directional USB device that is connected to the computer so that signals from other devices are not interfering with the communication between the machine and the computer.
If necessary, disconnect all other bi-directional USB devices (excluding a keyboard and / or a mouse) such as printers, scanners, digital cameras, zip drives or USB flash drives that are connected to the computer via USB and then try to scan again.
NOTE: This solution assumes that the print driver for this product and the operating system you are using has been downloaded and extracted to a known location on the hard drive. If you have not already done so, click on the [Drivers & Downloads] link under the Product Resources section on this window to download the print driver.
  1. Disconnect the USB cable from the WorkCentre.
  2. Remove the print driver from the computer. See the Related Items below for additional information.
  3. Connect the USB cable to the WorkCentre. Windows will recognize the WorkCentre as new hardware and the New Hardware Wizard will be displayed.
  4. The Can Windows connect to Windows Update to search for software window will be displayed. Select [No, not this time].
  5. Select [Install from a list of specific location] from the location options provided.
  6. Select [Search for the best driver in these locations]. Click on the [Include this location in the search] check box to insert a check mark, and then click on [Browse]. Browse to the folder where the driver files have been extracted to. The default location is c:\enxppcl6.
  7. Click on [Next]. A 'Please wait while the wizard installs software' message will be displayed.
  8. When the installation is complete, click on [Finish].
  9. click on the [Start] button, click on [Settings] (if necessary), and then click on [Printers and Faxes]. The Printers and Faxes window will be displayed.
  10. Right-click on the new WorkCentre printer icon, and then click on [Properties].
  11. Click on the [Ports] tab.
  12. Make sure the port selected is a USB port. If another port is selected, such as LPT1, select a USB port and click on [Apply].
Jan 15, 2010 | Xerox WorkCentre M15i Laser Printer
Need Drivers for Xerox XD105F for Vista - Do any exist and where
try this link >
on the right side there is a DOWNLOAD LOCATIONS
for XEROX Printer WorkCentre XD105f 5.01.2300.01: and below is EXTERNAL MIRROR, click this mirror and save the file. Scan the program prior to your installation, file size is about 4MB. Let me know if there is any other i can help. regards. cebuwano
Apr 11, 2009 | Xerox WorkCentre XD105F Laser Printer
Vista printer driver for a Xerox Workcentre Pro 635
try this....
Jan 04, 2009 | Xerox WorkCentre Pro 635 Laser Printer
Reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Apr 03, 2008 | Xerox WorkCentre M-24 Color Copier
Drivers to windows vista no are in plans to devenlopment in xerox
Drivers for this printer can be found HERE: --> ...or HERE: -->
Aug 03, 2007 | Xerox WorkCentre XD120F Laser Printer
Xerox WorkCentre M-24 Color Copier Logo
494 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
