Question about Panasonic PT-47WX42 47" Rear Projection Television
TV won't come on, just blinking red light...
I've read that it could be one of the lamps or a convergeance problem. How can I truly know which one it is so I don't have to spend too much?
Thanks,
Will
  • willdcb Dec 05, 2007
    I believe it blinks two or three times.
  • beejay428 Dec 06, 2007
    I have the same problem, just started happening last night. TV won't turn on. Power light blinks 3 x's and does not turn on.?? Help.
    BJ
    President:
  • 4,402 Answers
Does the light blinks a certain number of times?
Posted on Dec 05, 2007
  • Cary Farah
    Cary Farah Dec 05, 2007
    2 - Low DC
    3 - Convergence
Problem with Sony Grand WEGA KF50WE610 50 in. Rear Projection HDTV-Ready Television. Does this indicate that the lamp is burned out?
if the lamp indicator is blinking and won't turn on which means you will need to replace the lamp.if you don't have an idea how to replace just leave it to the tv technician to fix your tv.
Sep 17, 2012 | Televison & Video
Our tv won't turn on light blinks a couple minuate and then turns read again and lamp light flashes red
A possible bad lamp if not replaced recently or removed and at least examined. What is model number and what have you tried so far?
Apr 19, 2012 | Sony Televison & Video
Hi! I am experiencing the following three
Hi Rafael,
First of all thank you for posting your question here at Fixya.
Please confirm if the brand and model number above is correct.
Blinking of the the LED (yellow and blue) at the front panel indicating that the lamp door cover is not seated properly. This cover will engaged to a micro switch giving the signal to the processor, once it is in open position, the unit will not power up and will experienced that kind of blinking error code. Go back to the lamp door cover and ensure that it is properly seat-in.
3D, 2D, red/green/blue ghost on the picture and letters means that the convergence circuitry gone bad. Symptoms is not connected to the light engine. The faulty parts is the convergence chips(IC). This chips are mounted on the large aluminum heat sink and starts with STKXXXX-XX (X means number). The most common STK chips used on Projection TV's is the STK392-110. You have to replaced them both on the board to resolve the issue(red ghosting). It is necessary also to check the resistance value of the resistors around its circuitry using the multimeter. For more info how to repair a convergence problem, watch the video below.
Jdvillanueva
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Where is lamp door located? I've read on here that my issue (blinking red lights) may be fixed via the lamp door but I dont know where it is...
I'm sorry for the difficulties you're experiencing in locating the lamp door of the TV. The Lamp door is located on the right side of the TV. I'm providing a photo with Lamp door is marked. Please review the below picture.
Thanks for understanding. Please let me know if you require further assistance.
Sep 27, 2011 | Sony KDS-60A2000 60" HDTV
Hi
You have defective power oscillation! in power section and or power oscillation!
Thanks!
Sep 19, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Panasonic PT-53WX42 - When I turn the TV on, the red light comes on but, no sound or picture.
Does the light blink? If it is blinking a 3 code, the IC's need to be replaced. Those three lamps as you called them are not lamps, they are the three picture tubes.
Jan 08, 2008 | Panasonic PT-53WX42 53" Rear Projection...
55HX70
needs convergence ics period
Nov 24, 2006 | Toshiba 55H70 55" Rear Projection...
Panasonic PT-47WX42 47" Rear Projection Television Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
