Question about Orion Televison & Video
TV stuck in standby mode.
my Orion, I do not know the precise type makes a screeching sound for a couple of seconds after which it goes into standby mode. When I try to select another channel to turn it on it makes the same sound again and goes into standby mode. Is this because I do not let it stay in standby mode enough?
    Top Expert:
  • Orion Master
  • 40,357 Answers
No, it isn't.
Posted on Dec 06, 2017
  • 1694 Answers
SOURCE: When I am trying to turn on the tv by remote or pushing the power buttton it goes to stand by mode
Solder bad connections vertical output IC......requires chassis
to be pulled....................T.
Posted on Dec 06, 2007
  • 744 Answers
SOURCE: Dmtech TV is stuck in stanby mode
thank u rate me!!
Posted on Feb 12, 2009
SOURCE: My THOMPSON TV won't turn on!!
Circuit board inside the TV was loose!!
Posted on Feb 17, 2009
  • 1348 Answers
SOURCE: When i on the tv by remote the red standby light
the high voltage or flyback transformer is not working.the sound runs off a separate fixed power supply.if you run your hand across the screen,is there static?that would mean the high voltage is ok but there is another circuit fault
Posted on Jul 08, 2009
  • 1810 Answers
SOURCE: TV will not turn on and standby light flashes four times....
sounds like a bad reley to me time to open up the patient and find the little bastard
Posted on Jul 29, 2009
Lc195emx stuck in standby mode
Hi D
Sounds like the Switch Mode Power Supply is failing to Power Up.
Often Caused by Bad Electrolytic Capacitors inside the Power Supply Circuitry.
Probably a replaceable PCB Module.
Take it in to your dealer or Electronics technician.
Mar 03, 2015 | Televison & Video
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
Why is my black diamond tv stuck in standby mode?
Just have a try by make it a hard reset. Just unplug the TV from AC mains wall socket, and re-plug it back after 20 minutes or so.; This must make it a hard reset. If it too does't help you, the main board of the TV is likely to be faulty. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 13, 2014 | Video Game Consoles & Games
Logik TV stuck in standby
if you don't hear a click its the power over switch. on the power board it is a black box. if you have the back off turn the tv on and then out of stand by and flick the black box it will probably turn on.
Feb 25, 2014 | Televison & Video
My sylvania tv is stuck on standby
This is due to a bad power supply system which consist of an electronical board with capacitors on them that burn out.
Jun 18, 2012 | Sylvania Televison & Video
Standby light flashing several times then goes off 2 seconds and back flashing can not get telly to come on
In order to help you I need to know how many times exactly your "several times" means.
TV is flashing error code repeating it over and over.
You have to count how many blinks AND post here model of your TV (located on the sticker on the back of TV set, should start with letters like "KDL" or similar) if you want to get help.
Otherwise you are making it impossible because there is not enough information to provide you with precise answer.
Dec 01, 2010 | Sony Televison & Video
Orion Code for Uverse
1382, 3213, 1383, 3202
try one of those
Mar 12, 2009 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
My TV is going into standby mode whenever it is turned on
My screen turns black and the TV goes into standby mode (I get an Amber Light) within 3 seconds after turning the TV on.
Dec 16, 2008 | Televison & Video
Tv stuck in standby
Your problem is in the switch mode power supply or the horizontal out circut.
sometimes the small CHOKE that feeds the base of the horz. out transistor has a cold solder joint.
resolder both ends first.
Thanks Guy9
Jun 10, 2008 | Televison & Video
Omni tv t8005nf locked tv
on the omni tv the button with a square and a + sign for a couple of seconds
May 27, 2008 | Apex Digital GT2011S 20" TV
Televison & Video Logo
50 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
