Question about Xerox DocuMate 252 Path-Through Scanner
Scanner excludes front page
This is driving me crazy!!! When I scan in multiple pages at once, about half of the time the scanner excludes the first page. I can get around it sometimes by scanning the first page alone, then add the others using the add pages button. I can also sometimes get it through by scanning the first page and then stick the second page in right before the first page finishes scanning. How do I get the scanner to scan all papers if I stick all of them in the feeding tray at once? Btw, I am only putting up to 3 pages at once. Thanks for any advice!
    Scholar:
  • 91 Answers
This is not the only solution, but this might help.
Put a blank page in as the first page and see if all of your documents scan completely.
You may need to clean the ADF. Try the following:
Cleaning the Automatic Document Feeder
You may need to clean the ADF feed mechanism if your
documents do not feed easily into the ADF, or several feed in at the
same time.
To clean the ADF:
1. Dampen a soft cloth with some isopropyl rubbing alcohol
(95%).
2. Press the ADF cover release on the top left of the scanner body
to open the Automatic Document Feeder cover.
3. Wipe the feed roller from side to side. Rotate the roller to clean
its entire surface.
4. Wipe the pad from top to bottom. Be careful not to snag the
cloth on the springs on either side of the pad.
5. Close the cover when you’re finished.
NOTE: Please be careful when cleaning the roller. The roller is
designed to rotate in one direction only. As you’re cleaning the
roller, make sure it rotates easily, and continue rotating it in that
direction while wiping it clean. Do NOT force the roller to rotate
in the opposite direction. Forcing the roller to rotate will damage
it, and may cause the scanner to feed pages incorrectly.
Please let me know if this has helped and thank you. Binary Bob
Posted on Dec 10, 2008
SCAN MULTIPLE PAGES
The scanner must have auto feed to be able to scan multi pages at once.
Good luck
Mai
Jun 14, 2018 | The Office Equipment & Supplies
How do i scan multiple pages and sav it to my documents. It seems like i am only able to scan and save one page at a time
Hi
If you have a Top feeder on the scanner, you can scan mutiple pages. Change the setting of the scanned file to pdf file (not JPEG) by going to the scanner icon and change the type of file you want to scan. Scan it as PDF FILE and then it will scan multiple pages. Regards
Jun 16, 2011 | Computers & Internet
Can't scan more than one page under one file
you need to check for updated drivers from the manufacturer's website as the "old" drivers may not be completely compatible with windows 7.
this often happens when changing operating system to a newer OS
Jun 19, 2010 | Epson Perfection V500 Flatbed Scanner
Scan multiple pages
Yes, it is possible, if your scanning application has batch scanning option. However, pls provide the scanner model and scanning application details to provide the exact soltution.
regards,
Tech Satya
Feb 09, 2010 | HP Office Equipment & Supplies
I cannot scan more than one page at a time.
The scanner can only scan one at a time, if you can't scan multiple pages you need to adjust the scanning software and settings, not the printer or scanner.
Aug 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
How do I add multiple pages to one scanned doucment?
Open your Adobe Acrobat (e.g., 9.0 Pro), load your pages into the document feeder (fewer than 30 at a time), then ask Adobe Acrobat to create PDF from scanner (File/Create PDF/From Scanner). Canon MP530 as the scanner and click OK. Works like a charm!
Jul 07, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Jun 12, 2009 | Canon DR-2580C Path-Through Scanner
Scan a Multipage Document into a Single File
My scanner is a Cannon but the basic jist of what your trying to do is universal. You need to open up the software for the scanner and look for an icon that says scan to file. It sounds like you have already done this. If so you are very close in the step I mention to the setting you need to scan multiple pages into one PDF file. Once you find the setting to scan multiple pages be sure to not click "FINISHED" until your last page is scanned in.
LB
Nov 30, 2008 | HP ScanJet 2400 Flatbed Scanner
Number of Pages the fi4120c will scan
Try to get to the separation rubber and clean it.
Nov 04, 2008 | Fujitsu fi-4120C Path-Through Scanner
I'm using a CanoScan LiDE 60 and I have no idea even how to begin. I need to scan in 5 different documents with numerous pages and I was hoping to create a pdf for each. Can you help me get started?
Use the CanoScan Toolbox that shipped with the scanner. If you don't have it, then download it from the Canon Website. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=11446
If you don't have the scanner driver, then download that too.
Once you have Toolbox installed and you open it, there will be a PDF button. The scan to PDF window will open. If you're planning to do a multiple page pdf, then click the dropdown menu next to 'Save as Type:' and select PDF (Multiple Pages). You're now ready to begin, insert your first page into and then click 'Scan'.
Nov 20, 2007 | Canon CanoScan LiDE 25 Flatbed Scanner
Xerox DocuMate 252 Path-Through Scanner Logo
266 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
