HP Officejet Pro L7580 All-In-One InkJet Printer
Problem for HP Officejet Pro L7580 All-In-One InkJet Printer
HP Officejet Solution Center - no "scan settings" no scan options
By rugby40294 on Aug 28, 2009
"scan settings" is not functional, the preference button is not available in HP solution center while all other features work fine, therefore, unable to configure scan options.
Same issue on both of my 6480 and 6310 all-in-one Officejet.
Already installed all software with full features from CD and done all updates. Tried uninstall and reinstall several times, HP image service is running in startup, still problem persists. Anyone out there care to share the fix for this will be greatly appreciated.
Comments:
Aug 29, 2009
- Thanks for your response, and you're right on track with your suggestions, except I already tried it. I've already done full uninstall several times including booting into safe mode to delete all Hewlett Packard entries from the registry, and ran HP utility cleaner to remove HP files, and removed all temp files, etc. ; I did install on another computer, and it works fine; So, I'm thinking maybe it's my computer's OS or System File, but what system file should I be searching for? Note that my computer can see the scanner in the device list, but HP solution center just repeatedly will not display scan setting options. Let me give a little history: This Officejet was working fine after the first install on my computer, then don't know what happened, the scan feature disappeared. So, I tried reinstalling, but so far nothing works. I'm hoping to find a solution without having to restore complete computer from OS CD. Does anyone know what files is associate to the HP "scan" functions to work? I'm open to any ideas. Thanks in advance.
Solution #1
posted on Oct 02, 2009
Somewhat Helpful)
rosalieri
Rank: Apprentice
Rating: 75%, 1 votes
I had the same problem and after spending more than 40 hours on the phone with tech support, it was determined that Adobe Photoshop is not compatible with hp solution center. You can open paint and scan with it.
Was this helpful?
Yes
No
Solution #2
posted on Aug 28, 2009
Somewhat Helpful)
TekSpotCoUK
Rank: Wiz
Rating: 91%, 13 votes
hi rugby40294 Have you tried downloading the latest copy of the full software (including all drivers) from HP website, then installing from that. Obviously, fully uninstall previous drivers and HP centre files. Also, you might consider installing it to an other PC/Laptop and see if you encounter similar issues. regards tekspotDotCoDotUk
Was this helpful?
Yes
No
Popular Solutions for HP Officejet Pro L7580
Questions and Unsolved Problems for HP Officejet Pro L7580
Do you recommend HP Officejet Pro L7580 All-In-One InkJet Printer?
Answer
Answer
my printer will not reset the the yellow cartridge it keeps saying replace empty yellow cartridge
Answer
My printer won't print envelopes from Word - it did before then stopped doing it
Answer
there is a scan option on this but no instructions please help
Answer
my hp officejet pro l7580 will not print. the print heads have a problem. print heads (c9381a)... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , CA
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
