Question about Lands Phones
Akg sr 60
I HAVE A AKG SR 60 WIRELESS MIC THAT THE MUTE LIGHT IS ON. HOW DO I GET THE MUTE OFF?
  • jesus torres Sep 09, 2008
    mute akg sr60
    yes, i have akg sr60 is mute
    Problem Solver:
  • 8 Answers
Help me please akg sr60 , when torn on just mute
Posted on Sep 09, 2008
The mute light on the AKG SR60 turns on when it does not detect a transmitter or the the transmitter is too far out of range or not on the same frequency as the SR60 receiver.
1. Apply power to the SR60 receiver. Leave the transmitter turned off.
2. Using a small flat-blade screw driver, turn the squelch control fully counter-clockwise. The mute light should go off. Slowly turn the squelch control clockwise until the mute light stays on with no flickering.
3. Place a fresh battery(ies) in your transmitter and turn it's power on.
4. The mute light should now be off on the SR60 and the OK light should be lit. If not, verify you have the SR60 set to the same frequency as your transmitter. If you don't know the frequency of your transmitter, you can try each receiver frequency (wait about 5 seconds after changing to the next frequency) until the receiver and transmitter frequency match.
Posted on Jan 13, 2010
Im looking for a used wireless AKG Microphone HT81. We have a SR81 receiver. Do you know where to find one?
I supect your best bet would be Ebay. be sure to check the frequency your receiver operates on and get a mic that matches it.
Sep 01, 2015 | AKG Audio Players & Recorders
I have the AKG wms 40 dual mini mic set with two wireless mics. When mic on ch 2 is in the off position, I get lots of static. Works perfectly fine when on. What do you think is the issue?
Channel 2 mic's receiver needs the Squelch adjusted. The squelch control mutes the receiver so that when the transmitter stops transmitting, erroneous noises are not picked up and amplified.
Jan 23, 2013 | AKG WMS 40 Professional Microphone
AKG 120 to Tascam US-800 connection issues
There is no reason to use such a configuration with the US-800. I advise using a standard XLR mic cable. It's likely phantom power doesn't work over the 1/4" jacks.
Jan 26, 2012 | AKG Perception 120 Microphone
Need a new "guitar bug"(wireless
It looks like you are after the AKG GB 40 guitarbug
They appear to be a discontinued item in a lot of places
This list several place that say they have them, one for $29.95
www.thefind.com/electronics/browse-akg-gb40-guitar-transmitter
Also
fatheadmusic.co.uk/product/2367/akg-gb40-guitar-bug
or
www.proaudiosuppliers.com/akg-gb-40.html
Jan 31, 2011 | Audio Players & Recorders
I have a SR 40 Single WMS 40 Pro and the "bug" that fits into the 1/4 end in my guitar has taken some wear so even tho it's hinged it has loosened up both directions and ocassionally has to be wiggled...
AKG may have replacement parts, but they only keep them around for 7 years, so depending on age/mfr. date....That unit is also out of date with regard to the frequencies used on it. It is actually ******* to use that unit in the USA today, as the feds at the FCC sold off those frequencies to the cell/telco companies a while back.
Oct 05, 2017 | AKG (40008801) Professional Microphone
My akg perception 200 is not responding
Have you tried using a another XLR cable..,or are the other mics phantom powered condensers..ie try to locate if its a mic problem or the cable..2 other points are 1 - XLR leads for phantom mics need to be XLR to XLR male to Female plugs[ends] 2- is that often an XLR to XLR cable will be not soldered or wired right,so that the power [phantom power is not getting to the mic] so ensure you have a proper cable for that job...Sorry i can't be more specific but from reading your problem all these issues come to mind..If you have ruled all these things out,then it could be the capsule or loose joint or component in the mic which means contact AKG,pro audio services or find a DIY mic person to help..G luck!!
Jan 11, 2010 | AKG Perception 200 Microphone
I have broken the Arial on the AKG SR 40. How do I get a replacement
Your antenna is available for $8.82. Contact frank.rodriguez@harmon.com . The part #333-9801-0 give him your info and he will process your order an ship your antenna to you.
Apr 09, 2009 | AKG SR 40/880M Professional Microphone
Extremely weak RF from AKG WMS 60 Hand Held Mic
I don't know what you've tried already to improve the signal level, so i'll list a few things that migt help.
It might help to put new batteries in (with the right voltage) You probably did that already.
There is a GAIN pot on the mic, in the battery compartment under the ring that is screwed onto the mic. When you adjust the GAIN, there will probably be better SN-ratio, but it does'nt change the RF signal
You could also adjust the antennas of the receiver, or try to set a different frequency (depends on which country you live in, in some countries it is illegal to change frequencies) or turn off the SQUELCH on the receiver
If this does'nt help, you could look for a user manual and try to find a solution in it.
There are some other solutions to improve RF signal, but those are quite expensive.
Oct 20, 2008 | Audio Players & Recorders
Lands Phones Logo
1,253 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
