Kenwood CD DP-M6010
Keep getting error E-22. What is this? How to remedy? Stops playing during random play and sometime skips/advances in middle of song.
  • 1 more comment
  • Anonymous Dec 10, 2007
    I´m having the same problem. It looks like a problem with the rubber belt in the Kenwood cd-m6010.
  • Anonymous Dec 15, 2007
    I'm having the same problem. Does anyone know what it is or who can fix?
  • Anonymous Mar 07, 2008
    I was told by the Kenwood Technician that it is a lazor adjustment.
Does not play has e22 on display on my kenwood dp-m6010 disk player
On the kenwood dp m6010 6+1 cd player, the e-22 and e-21 codes are for the laser head movement limit sensors. More than likely the drive belt is broke or stretched.
Jul 27, 2013 | Audio Players & Recorders
I have a DP-R6080 or DP-R5080 5 cd changer player. Its probably 10 years old or so but recently the CD have begun to skip. Its not the CD because the new ones skip and they play fine on a single player...
The trouble lies in the laser pickup assembly, the only option you can try is buy CD cleaning kit and follow the instructions, the kit will remove any dirt that might have collected on the laser lens, If it works you will get more usable time out of the machine. The fact that you got 10 years is much better than the average, overtime the laser gets weaker until it can not track properly, so! if the cleaning fails it is far cheaper to replace than to repair.
Mar 15, 2011 | Kenwood Audio Players & Recorders
My Sony mini hifi component system is going berserk!! 2 problems: 1- CD system skips tracks and on playing on repeat song, the song skips certain times and jumps ahead of the track. 2- Tape system plays...
Your cd player is fubar and in definite need of replacement.
Tape unit seems to have a mind of its won. Try to reset the electronics to factory defaults. If that has no remedy, since it is a sony< best advise is to trash it. Repair cost is prohibitively expensive.
Sep 19, 2017 | Sony MHC-RG222 CD Shelf System
My DP-48 CD Player is erratic. Sometimes it plays and can search, memorise, replay and do all I ask of it. Other times, it cannot even play the first track but keeps revolving over and over. Please...
same thing is happening with mine, its old asf and won't play a CD without skipping the entire way through, I recommend you just reset it by unplugging it for a day with the power button on, that might help reduce any static buildup in the ribbon cables. Anything from over 20 years ago will have many ribbon cables, which build up static causing electrical errors in the unit. I usually just turn it off for a few hours and then it works fine. But if that doesn't work, it's probably the spinning mechanism, since it's so old, the motor probably needs lubricating, if it's rusted or bent, then it is unfix able. I only recommend this if you didn't plan on taking it to a professional AV repair store. I hope you get to read this as I realize your post is from 7 years ago. good luck.
Dec 30, 2010 | Kenwood Audio Players & Recorders
I have a Kenwood music system (quite old ) cd player DP-322 after you load the disc it sometimes just plays 1 track or doesn't play at all if you open the draw and then close it and select random play it...
you need to have the lazer lense cleaned by a pro or buy a lens cleaning cd and load it about 5 times i think youl find it will fix your problem
cheers
sonic boom electronics australia.
Apr 21, 2010 | Audio Players & Recorders
Cd will not play displays E4
Page 22 displays error code descriptions and suggested remedies for your Kenwood KDC-122 CD Player. This is a link to Kenwood site and instruction manual.
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDC2022.pdf
Yes, the KDC-122 is included in this document.
Oct 26, 2009 | Kenwood KDC-122 CD Player
Kenwood dp-28 cd player jumping cd
My CD player starts to jump after a few minutes and also it doesn't recognise certain CD original disks
Mar 19, 2009 | Kenwood Audio Players & Recorders
Durabrand CD player skips while playing.
hi i've had the same problem i though it was the laser or the laser rail until i opened it!! Then i checked the laser, the rail and all the other mechanical it worked fine, until i got to the laser it had a hair right in the middle, don't bother trying the cd cleaner it doesn't work! all i di is take out the laser cleaned it with a cotton suabe and alochol for a bout a minute and now it works beautifaully! also clean the circle thingy that spins and holds the cd! any little particle will make that laser not read the cd right! while ur there tryin cleaning the unit from dust! it's the worst ememy! well hope this helps!
Feb 19, 2008 | Audio Players & Recorders
Kenwood cd player DP-M6010
After retrieving the cds from the unit I replaced it with my iPod. It seemed to me to be the most cost effect method to solve the problem.
Feb 08, 2008 | Audio Players & Recorders
Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Dec 06, 2007 | Kenwood DP-J2070 CD Player
417 people viewed this question
 Grubhead
Grubhead
