Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Frigidaire signaling water dispenser instead of ice maker
I finally hooked up a water supply to my Frigidaire frige and the water dispenser works fine, but the ice maker doesn't work at all. In fact, after turning the ice maker on a waiting several minutes, the water dispenser automatically shoots a bunch of water out onto my kitchen floor. Somewhat comical,except my floors are wood and I really want the ice dispenser to work.
No water is making it up the ice maker water supply.
Any suggestions?
  • 10 more comments
  • lucore Dec 14, 2007
    we have the same problem with our Frigidaire # FRS26RLECSC.
    The water line is not newly hooked up - everything was working fine until last week.  Now, when the ice maker should be filling (we can hear the water running), water shoots out of the dispenser onto the floor and no ice is being made.  I'm assuming that, for some reason, the flow is being diverted from the maker to the dispenser.
    Any thoughts?
    Please help.
  • Anonymous Dec 24, 2007
    the water hose is shooting water to the freezer but i dont know where the water is going because it is not making any ice
  • Ellell Feb 22, 2012
    Was there ever a solution for this problem? I am having the same problem right now. The suggestion about the solenoid valves being wired wrong is definetly not the solution unless a gremlin crawled into the unit and swapped the wiring. Anything else?
  • Anonymous Mar 14, 2014
    water not getting to ice maker or water resivoir
    Frigidaire Gallery Series side by side ice maker makes ice just fine but wont dispense it all other functions within the door work water, light filter signal any suggestions??
  • Anonymous Mar 18, 2014
    ice maker and water dispenser not working and ice on floor of freezer side
  • Anonymous Mar 19, 2014
    To much water going into ice maker
  • Anonymous Mar 21, 2014
    I replaced power supply module,dispenser solenoid,limit switch
  • Anonymous Mar 23, 2014
    have water no ice
  • Anonymous Mar 24, 2014
    not making ice
  • Anonymous Mar 30, 2014
    Water does not seem to be working in ice maker. Is not making ice
  • Anonymous Mar 31, 2014
    ice maker not working
  • 40 Answers
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Posted on Dec 05, 2007
  • L. LEE ADAMS Oct 13, 2011
    I'm confused; the electrical connections on the water valve are different so that its inpossible to hook them up wrong; so if thus is the case then how is your answer / solution / to this problem correct???
    It's impossible for this solution to be correct. However, I am having the same problem now in 2012. Was there ever a real solution?
My Frigidaire ice maker dispenses water when I use the dispenser on the door. I have been told it may be a DIODE issue. Does the LPHS2687KF0 have a diode?
Good Morning Jim,
I understand the ice maker is dispensing water when you use the dispenser on the door of your Frigidaire refrigerator, model# LPHS2687KF0. I also see that you have a Diode kit and are not sure if it would be this that is needed or a water valve that would be needed. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your refrigerator and determine what is causing the ice maker to dispense water. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire PLHS267ZA Side by Side...
Ice maker quit working
Good Afternoon Kevin,
I understand that your Frigidaire refrigerator, model# FRS26R4A, is not making ice. There are a couple of things you can check. First, check the wire signal arm to make sure it is in the "down" or ON position. The ice maker turns off automatically when the ice container becomes full. To stop the ice maker, lift the wire signal arm until it clicks, and locks in the "up" or OFF position. Second, check to see if the water dispenser is dispensing. You might need to change your water filter. It's recommended you change it every 6-8 months. The other thing if your appliance is not dispensing water is there might be a kink in the hose or maybe the water supply has been cut off. Hope this has been helpful.
-Best Regards-
WP
Mar 27, 2014 | Frigidaire FRS26R4A Side by Side...
HOW TO HOOK UP AND START THE ICE MAKER ON JSI_23
Good Morning Le Morrer,
I see that you are trying to hook up and start the ice maker on your Frigidaire refrigerator, model# FRS3R5EMB.
To connect Water supply Line to ice Maker inlet valve:
1 Disconnect your refrigerator from the electric power source.
2 Place the end of water supply line into sink or bucket. Turn ON water supply and flush supply line until water is clear. Turn OFF water supply at shutoff valve.
3 Remove plastic cap from water valve inlet and discard cap.
4 If you use copper tubing - Slide brass compression nut, then ferrule (sleeve) onto water supply line. Push water supply line into water valve inlet as far as it will go (1/4 inch/6.4mm). Slide ferrule (sleeve) into valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
If you use stainless steel tubing - The nut and ferrule are already assembled on the tubing. Slide compression nut onto valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
5 With steel clamp and screw, secure water supply line (copper tubing only) to rear panel of refrigerator as shown.
6 Coil excess water supply line (copper tubing only) about 2 and 1/2 turns behind refrigerator and arrange coils so they do not vibrate or wear against any other surface.
7 Turn ON the water supply at shutoff valve and tighten any connections that leak.
8 Reconnect your refrigerator to electrical power source.
9 To turn the ice maker on, lower wire signal arm (side mounted) or set the ice maker's ON/Off power switch to the "I" position (rear mounted).
After connecting the water supply, you will need to prime the water supply system.
To Prime The Water Supply System:
1 Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle.
2 Keep the glass in this position until water comes out of the dispenser. There will be noticeable spurts and sputters as the system pushes air out through the system and dispenser nozzle. This is normal. This may take about 1 and 1/2 minutes.
3 Continue dispensing water for about 3 minutes to flush the system of any air and impurities. Empty the glass as needed.
The water dispenser has a built-in device that shuts off the water flow after 3 minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS3R5EMB Side by Side...
I have water going through the water dispenser, but no water going into the ice maker. The infrared light seems to aligned with the receiver.
The water inlet solenoid on the back of frige has two valves that never go out at the same time. Follow the supply line to the solenoid. Turn off water supply, unplug frige and replace part.
Nov 06, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Water and ice not dispensing on Frigidaire side by side
We have a similar fridge were told that it has a resivoir inside that needs to fill with water before it will start to dispense water. Had to stand holding in the actuator for quite a while befrore it started putting out any water. Shoud be the same with the ice maker, but there is an arm inside the freezer that controls how much ice you get it could be turned off.
Jan 24, 2009 | Frigidaire FSC23F7D Side by Side...
Ice maker & water dispenser won't work
I recently found out that the water supply lines are coiled up inside behind the frige on the refrigerator side moving the unit will cause those coiled up lines to shift to the freezer side of the unit, causing a freeze up,take the cardboard lower back off and move those lines further away from the freezer side of the unit, as one of those coiled up lines are to chill the water for the dispenser and the other is supply for the icemaker, this should fix your problem, becareful not to move them too far away from the freezer side as they are meant to chill the water for the dispenser
Jan 16, 2009 | Frigidaire FRS266ZDSB Side by Side...
Water to ice maker isn't filling tray.
what is the inside temperature in the freezer? it has to be below 17 degrees before the ice maker even try's to work
Dec 11, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
1,425 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
