I recently aquired an old Kenmore 10 Portable Sewing Machine - Model #158-1262180 - Series LR 62482. There is no bobbin in the machine, nor any manual - I am unable to thread and my bobbins from my other machines do not work. Can you help with anything? Thanks
I have a kenmore10 model 1249180 ehwn i sew it squeeks i oil it i dont know where the squeek is coming from
Lilliane - truly hope you've found help by now.
If you have a bobbin holder, any shop can match the bobbin to it. (PS, Older is Always better, no matter the brand!) And any manual should be available Online. One friend found one ages ago for a late 1800's machine. Or Sears should give you one, gratis. Good luck, and enjoy!
My Dad taught me to clean and repair sewing machines. No clue why. When it comes to oiling any machine, there are Lots of places that need oil. The ones most overlooked are on the Right hand side of the machine, and they Will cause squeeks. Also the hardest to reach. You need to remove the right end plate, and look for anything that moves. Also look on the top, at the right. Those driving belts really need oil.
Um, it's best not to oil belts. The oil deteriorates rubber.
Well, without oiling the right side of the machine, in all Oiling holes, the belt will 'squeek.'
Kenmore sewing machines relics
I just loosened the tension on the wheel to fill a bobbin. Now the wheel won't tighten. What do I do?
Tension has nothing to do with winding a bobbin. As far as I know. Only loostening the wheel on the right, outside the large wheel, will facilitate filling a bobbin. Getting old, so I don't bother, just let the needle arm rock up and down as I fill a bobbin. To re-tighten the wheel, crank the small wheel toward you. Righty Tighty, Lefty Loosey. Good luck.
Thread 10 stitch model 13500 kenmore sewing machine
i need help threading the machine
i need the basic instructions for threading my kenmore.
Model 158/1783080 Need Manual
Imanana
Kenmore 158.17570 Sewing Machine
All manuals available online. As far as I know, there are only two "thicknesses" of bobbins. Suggest you buy one either thick or thin, and try each.
With any machine, older is better. Only 2 thicknesses exhist - try each.
