Question about Aprilaire 600 Humidifier
Aprilaire 600 only operates in test mode...
The system is installed in automatic mode and operates in "test mode" but will not operate out of "test mode".
Outside temperature is 35-40 degrees and the resistance of the temp. sensor at the humidistadt measures ~27 k Ohm (corresponds to the suggested impedance for this temp.). The humidifier is installed in the supply plenum and the humidistadt is located about 5 feet (farther form furnace) away from the humidifier.
On a side note, I used the manual mode resistor with similar results.
  • 8 more comments
  • Dragon man Dec 07, 2007
    Have you got your problem fixed? I am having the same problem, only work at test mode and show E3 code once have it set. if you have the problem fixed, please email me gadgetct@gmail.com thank you in advance.
  • Anonymous Dec 12, 2007
    I have the same problem. My humidifier works in test mode, but won't work in any other mode.
  • chasjl Dec 29, 2007
    Just completed install. My shows 27K ohms from the temp sensor and 30% HH but will not run the humidifier. Test mode works. I think I'll convert it to manual until I can call Aprilaire on Monday.
    Well, it dosen't work in manual mode either. Only works in test.
  • 34Scarab Dec 30, 2007
    Same Issue, I have a 600A. I have a continue 24v to R & C,
    and 24v to W/G & Cf when heat is called for from the furnace.
    I have 28.5k ohms of resistance in my outdoor temp sensor (35F).
    If the furnace is on and I go to test mode the
    solenoid turns on and the water is applied to the humidifer. If I
    wait 10-15 sec and return the dial out of test mode to a setting of
    7, the humidifer remains on until the call for heat turns
    off. Turning off part seem to be OK. If I repeat the
    process but this time turn the dial CCW, the humidifer will shutdown
    when the dial get around 4, RH of the return is indicating humidity
    level of 40%. I switched to the manual resistor and the same
    results of than the turn off level is at 6 on the dial instead of 4.
    Summary Humidifer seem to know the correct level RH, and it shuts
    down prooerly when the call for heat has end. But it doesn't know
    when to turn on without going in to manual mode. I guess I'll be
    calling Monday also, unless someone has the magic answer. Thanks
  • snuffysmith Dec 31, 2007
    Same as others. Works fine in test mode, shuts off as soon as it is out of test mode. I now find the outside temperature sensor isn't even outside---I traced the wire and found and found the sensor just sitting up above the vent work hanging free as a bird. Is it possible my inside humidity is high enough that the unit just won't kick on? ---Dick G
  • jeffj Jan 05, 2008
    UPDATE: Aprilaire said the humidistats need recalibration so I sent them back to them a couple of weeks ago. Will let you know how it turns out.
  • Raydean Jan 09, 2008
    Same as Jeff. I get a 30% reading only on the humidistat, regardless where the control is set. The test mode does operate the water solenoid.
    I found that the humidifier control circuit board had heated to a point where these were scorch marks on the board above the wire tearmials from the furnace control board. What the hell....is this. 600A
  • Anonymous Dec 07, 2008
    Same problem. The read out indicates 47% and has not changed. The unit never turns on except in the test mode. My furnace guy said that it is working properly because it works in the test mode. I will now ask him to replace it.
  • Anonymous Dec 28, 2008
    My aprilare oly operates in test mode and I just replace the filter. How do I get it to work in normal mode
Thank you, got my problem fixed, after spend $275.00 call the service man to come. it come up to all about wrong wiring.all working and happy:) now.
Posted on Jan 05, 2008
Well I fixed my problem. It was my fault. I was using installation instructions that I printed from the web, they were for a model 600. The model 600A has a different control and wiring. The model 600 required only one 24V power supply to the R & C terminals. I ran the furnace accesssory power (110v) to the supplied transformer and then to the R & C as required by the model 600. But on the 600A this must be run to the W/G & Cf pair and a seperate continuously powered 24V must be connected to the R&C pair. I bought another transformer, wired everything using the correct diagram and it works great. BTW the E3 code indicates an open circuit on the temperature sensor. Maybe you clipped the wire while stapling it to the joists. Good luck.
Posted on Dec 29, 2007
Call Aprilaire and tell them, this is happining everywhere
Posted on Dec 12, 2007
Replaced water panel and the light keeps blinking to change it agai...model 700
Sorry to read about your problem, I hope this helps you out.
did you hit the reset
Digital Humidifier Control (Model 700): (Automatic or Manual mode) Check system operation and reset Change Water Panel indicator by setting the knob to "Test/Reset". With HVAC blower operating and HVAC calling for heat, humidifier will operate for one minute. DO NOT LEAVE IN TEST MODE AS HUMIDIFIER WILL NOT OPERATE.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 29, 2010 | Aprilaire 700 Humidifier
I replaced the water panel on our aprilaire 600 humidifier. I adjusted the thermostat to call for heat to test it. When the dial (non-digital control panel for the humidifier) is turned to test/reset,...
Thank you for contacting us with regards to your model 600 Humidifier. The Change Water Panel indicator should flash when the control knob is set to the Test/Reset mode. The flashing indicates that the timer has been successfully reset. However, the humidifier should operate for the first 60 seconds of Test mode as long as your furnace is running. If your humidifier does not turn on, contact your installer. The humidifier may require service.
We appreciate the opportunity to be of assistance.
Sincerely,
Brett Phillips
Technical Support
Research Products Corporation
Nov 01, 2010 | Aprilaire 600 Humidifier
Aprilaire 700. It works on fan on mode but not otherwise. It's never on and the humidity reading is always way below the setting. It should turn on automatically to bring the humidity up, right?
It appears your Aprilaire model 700 is wired to only operate when your HVAC fan is operated by your thermostat. Your HVAC installer can wire the humidifier control to operate the humidifier during a heat call, fan call or to turn on the fan when there is a need for humidification. Please contact your HVAC installer to have them change the wiring.
Thank you for giving us the opportunity to be of service
Sincerely,
Brad Uselmann
Technical Support
www.aprilaire.com
Nov 01, 2010 | Aprilaire 700 Humidifier
Solenoid valve won't open
Check for 24v.hum transformer shuold interlock/power up during blower motor hearing speed operation.Make sure its running.also manual mode resistor has to be installed in control panel.a blue plastic tag w/2 ends.
Mar 15, 2010 | Aprilaire 600 Humidifier
Testing a Aprilaire Humidifier 600 Controller
if it works in the test mode then it should be okay but you can get a humidity gauge from radio shack and set in the house to see how high or low its is. the humidifier is only going to give a max of 45% humidity
Nov 27, 2009 | Aprilaire 600 Humidifier
Aprilaire 700 only works in test mode.
connect two wires at humidifier without any wirng connected if works problem is in wiring or humidistat
Oct 28, 2009 | Aprilaire 700 Humidifier
Is there a url that compares all the whole house humidifiers?
go for the Aprilaire 600 but make sure they install the outdoor sensor and set it up for AUTO operation
Oct 01, 2009 | Aprilaire 600 Humidifier
Aprilaire 600: water only runs in "Emergency" Heat mode
When your unit is on normal the outside unit works and the inside only the fan runs. your heat pump does not remove any humidity when it operates so the installation cotractor did not wire it to operate then. you can change the wiring on the humidifier to operate all the time by wiring it to the fan (g) terminal then it should work just turn it all the way to the lowest humidity when you are in cooling mode.
Jan 07, 2009 | Aprilaire 600 Humidifier
J-
I had this problem several years ago. In order for the water to flow, the outside temperature sending unit must indicate to the controller that it is less than 60F. If not, the unit will not operate outside of test mode. Check the temp outside where your sending unit is (could the sun be heating that side of the house?) and ensure that the circuit to the sending unit is working. I had a bad wire splice inside a wire nut stopping the circuit. Took me a long while to figure it out.
If the outside temp and your sending unit circuit is ok, I wish you luck on your troubleshooting.
adx_98
Nov 10, 2008 | Aprilaire 600 Humidifier
No water at all
does the solenoid click when in test mode, if not check power to panel/solenoid.
If it does check that restrictor is not blocked
Jan 19, 2008 | Aprilaire 600 Humidifier
Aprilaire 600 Humidifier Logo
2,312 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
