Question about RCA RP5420 Clock Radio
I've lost power, how do I reset the time?
I can't locate my manual...I live in Alaska and the time is wrong six months out of the year anyway. how do I reset the time, please?
  • 3 Answers
Move slide switch on back left to "clock" position (all the way right) and then use "up" and "down" buttons to set time. Then slide back to "lock" position.
The controls for day light saving (or not) is located on back extreme left (i.e.. turn the unit around and look on RHS).
Posted on Jan 02, 2008
Where does a bald eagle live?????????????????????
Bald Eagle National Wildlife Federation
Their range extends from the Mexico border through the United States and Canada. Bald eagles are extremely populous in Alaska! If you live in Alaska, along the East and West coasts, the Rocky Mountains and the Mississippi River then you can see bald eagles all year. The rest of the United States only sees bald eagles during the winter and their migration.
Aug 20, 2017 | Miscellaneous
My 32 inch Audiovox flat screen will not turn on????? Was on and working fine 30 minutes prior.
hello, do you mean it's dead if so the fuse inside might have blown
regardsshaun
May 12, 2012 | Audiovox Televison & Video
Need instructions in English-Americans living in
Call thr Customer Service number located in the existing booklet and ask if the manual is available in English.
Aug 06, 2009 | Microwave Ovens
Belt and auto-tensioner
While installing a used belt just to get the truck home, I discovered that the pulley-bushing on the power steering pump was worn. This allows the pulley to move fore and aft, thus throwing the belt occasionally. What I learned from all of this can be catagorized as very basic troubleshooting. If you lose a belt that looks to be in good shape, then before you replace that belt, check all of your pullies and devices(water pump, alternator, power steering pump, AC, etc.). Look for pullies that can move or wiggle. And, look for lose or missing mounting bolts on the various devices. A loose or missing bolt may allow that device to become cocked at a slight angle, instead of remaining straight and true, thus throwing the belt.
Thanks
jklong, Alaska
Jan 17, 2009 | 1986 Ford Bronco
Battery backup?
which model do you have ? the 8000/8001 or 8011 the set is different depending on your type of heating system. This model has a memory chip not a battery that saves your settings. So you could be looking at replacing the unit.
Jan 05, 2008 | Honeywell Programmable Thermostat Heater
Setting the time
At extension 1
press Program (mute light turns on)
press Transfer (mute light flashes)
dial "38"
enter 2 digit year, i.e. "08"
enter 2 digit month, i.e. "05" = May
enter 2 digit day, "01" = first of the month
"31" = last day of the month
enter 1 digit day of the week
1=Sun, 2=Mon, 3=Tue, 4=Wed, 5=Thu, 6=Fri, 7=Sat
enter 2 digit hour in 24-hour format
00=midnight
01=1 AM
13=1 PM etc
enter 2 digit minute from "00" to "59"
press MUTE.
You will hear a single confirmation beep. If not, you did something wrong. Start again from the top.
Nov 29, 2007 | TMC M4810 NON-KSU Corded Telephone
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Dual Time
You can download the manual from the link below: http://world.casio.com/wat/download/en/manual/? You need to input the four digit code from the back of the watch. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 20, 2007 | Casio AWS90D-2AV Wrist Watch
RCA RP5420 Clock Radio Logo
113 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
