Question about Compaq Presario 700 470024-192 Notebook
Lcd backlight problem
I have compaq labtop for repair , the problem is the baclight is not working but lcd display is working but not coming in focus there is no backlight
  • shaikh farid Dec 05, 2007
    give me solution of compaq notebook lcd problem backlight problem
  • racb Jan 17, 2009
    lcd backlight is not working.nothing is visible in darkness.but in light i'm able to see very very very partially.i adjusted brightness for nothing
M\b drivers for comp pre c700
Posted on Dec 14, 2007
Compaq pressario cq40 108tu ...display issues
I have come across this problem, the backlight behind the LCD dims without warning and the only way to fix this issue is replace the backlight, a very difficult repair, mine like yours was a Compaq. Most professional will opt to replace the entire screen.
Mar 08, 2012 | HP Presario Computers & Internet
My TV has audio , but no picture
Hello
Just check whether backlight CCFL tubes are light up or not. If not, check the backlight inverter. It should have the falult. There is nor repair to this board. It should be repalced as card basisl. I hereby attaches a picture of it for your reference. This board can be located on the left or right side of the LCD panel, will be fixed vertically.2_15_2012_12_54_34_pm.jpg2_15_2012_12_55_03_pm.jpgBaclight boards will have so many types, and that is why, I attaches some types for your reference.2_15_2012_12_55_39_pm.jpg
Feb 15, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Display not working
Either you have a bad lcd display(or baclighting)problem.The replacement includes both LCD and backlighting.Or Connector flat wire detached from the display.It needs qualified technical attention or DIY disassembly if you are familiar on working with cameras.Check both of the parts I mentioned and most likely you'll get back your camera working again.
Oct 29, 2010 | BenQ DC E610 Digital Camera
How to repair the motherboard of v3000 laptop when no display
fine..it seems that u r a professional..
however it may not b the problem of the system board..
plz do the following checks..
try to connect to an external vdu/monitor using the laptops vga port..if there's display..check the lcd, inverter circuit & ccfl backlight..
if not post me comments..i'll guide u to next step(s)..
if problem persists contact system admin/vendor....
Nov 16, 2009 | HP Compaq Presario v3000z Notebook
Hello dear sir i have an old samsung labtop
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Oct 02, 2009 | Computers & Internet
My lcd screen on my compaq presario c700 stopped working when i fired it up one day
Either bad connection/ribbon cable or screen has tanked. Could also be a display driver but very minimal chance.
Aug 31, 2009 | Compaq Presario C700T Notebook
Where is the backlight switch located on the hp dv5000?
The baclight for an HP laptop is at the bottom of the bezel around the LCD. There are 2 screws covered with rubber caps at the bottom of the LCD. remove the rubber caps and the screw and lift gently. The backlight is a white plastic piece aproximatly 2 inches long. This should be plugged in to a plug with two wires. sometimes they come loose.
Aug 12, 2009 | HP Pavilion dv5000t Notebook
Compaq V3424au that has a blank screen on startup with all lights
You could have a defective LCD screen, If the laptop appears to be booting up and running and the hard disk is spinning and the hard disk LED light is flashing but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 23, 2009 | Compaq Computers & Internet
Screen will not light up
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 04, 2009 | Acer Extensa EX4420-5239 Notebook
Labtop lights up no work
change the battery...
another solution, try to re- install OS
Sep 24, 2007 | Compaq Presario 900 /1500 Series EVO...
Compaq Presario 700 470024-192 Notebook Logo
87 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
