Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis top-loader problem
My kenmore oasis top-loader smells. My guess is that water is some how pooling up inside the machine. I do not have any water on the floor and when I wash clothes in the machine everything comes out clean and smells just fine. any idea what's going on?
  • 1 more comment
  • Anonymous Jan 06, 2008
    We're having the exact same problem. The washer stinks. I'm assuming there is water getting in somewhere and getting trapped. The smell seems to be getting worse. Any suggestions?
  • Cubanmist Jan 14, 2008
    Everytime we wash clothes we get a strong odor that kind of smells like rotton eggs. A lot of people in my community are saying that its the water but I disagree. Do any of you have a solution or theory behind this odor?
  • Jane755 Apr 16, 2008
    My Kenmore Elite Oasis stinks too! It stinks when it is running. I already leave the lid open almost all the time it isn't in use. I use HE detergent and have cut back as suggested. It makes half of our home stink when the washers is working.
    Also, where does the lint go? There's no lint catcher and occasionally wads of lint spill out and hang from the back of the wash tub at the top.
    Is this a known problem? What can I do?
  • 370 Answers
Use the Whirlpool affresh tablets. Use all three the first time in hot water on the longest cycle. Then use one a month in hot water ect. and it will keep your washer smelling better.
Posted on Nov 14, 2008
Whirlpool has these tablets out for HE washers to solve this smell problem. They are calle Affresh tablets. Here is a link to the website:
www.affresh.com
Posted on Sep 19, 2008
You might try using the clean washer cycle, works on mine. I use the full amount of bleach allowed. No more smell...now if I can just get that pesky beeping noise to stop...
Posted on Jan 06, 2008
Why is my kenmore elite (top loader) oasis washer HE is displaying a code of HC
The water inlet hoses are probably removed and reconnected in reverse, and then trigger the HC error code to flash indicating the hot and cold water inlet hoses are reversed. Reconnect the water inlet hoses properly and start a cycle then let us know what happens next.
Apr 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My washing machine keeps flashing F1 signal i have a oasis he top loader
CHECK THE VACUUM HOSE FROM THE TUB TO THE CONTROL BOARD. YOU MIGHT WANT TO CHECK INSIDE THE TUB TOO, THERE MIGHT BE SOMETHING STUCK BY THE HOLE THAT THE VACUUM HOSE CONNECT TO AT THE TUB
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THRU IF NEEDED.
Jan 15, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 70 series top loadwasher does not completely drain water
the smell is raly bad because it doesnt drain all the water out , so it sits there. if all else with the machine works well, this means the water level sensor needs replacing
Jul 19, 2009 | Washing Machines
Hotpoint Washing Machine smells mouldy as has mould
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Jul 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Smell coming from inside washing machine. Not musty.
This is a fairly common problem that often arises when the majority of washes are done with cold water.
Do what is called a maintenance wash where you set the machine to run with hot water and maximum fill of water. Add one half cup of baking soda and let it run through it's entire cycle with absolutely no clothes in it.
After it completes its full cycle check for that bad odor. If it is fully gone wonderful. If it is half as bad do a second maintenance wash.
If the maintenance wash doesnt seem to help at alll get back to me and I will make another recommendation.
May 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My 18 month old kenmore elite oasis quiet pak 2 gas dryer smells as if there were a fire in it!!!!  and ironically, when i noticed the smell i also saw water around the base of the kenmore elite oasis top...
Hello plz make sure the gas burner does not have any lint build up on burner assembly inside the machine / plz clean.That usually causes a burnt smell. If there is no error codes on the display and the machines is operating fine you are chasing a ghost. If there is a pump or motor over load an error code should come up on the display.
Dec 11, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 42042 front loader
Buy affresh wsher tablets from whirlpool corp. They keep the wsher from smelling and they clean the washer too. They say they are for front loaders but they work great on top loader too!!!!!!!
Nov 10, 2008 | Kenmore 24032\24036 Top Load Washer
Smelly wash tub, in washer.
Model nums are fine in the store, if it is an oasis or calypso make sure drain hose is not in drain more than 5 inches. If not your pump might be going out or is clogged. A great cleaner developed is called washer magic and it will help the smell with some elbow grease. If not and is a traditional top load check motor and gearcase or even the timer for wear in a old machine.
Aug 23, 2008 | Kenmore 22422 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
231 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
