Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Help please I have a problem, i have 2 computers wire with this router.. everything was ok, but now the light for the second computer is odd. this second computer cannot connet. when I check the ip is totally different, ej, starts with 168 and I have in the router 192. I restarted the router, shuted down the firewell. The cable is OK because when I coneected directly to the modem, works perfectly. I do not know what to do. Belkin web page does not have enough support. any solutions?
Change private lan in modem or router and then try again. 168 is being automatically assigned by one of those devices
Posted on Dec 09, 2007
I pluged the belkin 54g into the modem were the internet comes from and 1 wire to the computer
hello,
typical setup: make sure everything is switched OFF, then, you will plug one side of the wire to the "WAN" port on your belkin and the other side of the same wire will go in the "LAN" port on the cable/DSL modem/device.
then you would take another wire and this time you will plug one side of the wire in the "LAN" port on your belkin router and the other side of the wire into your desktop/laptop computer.
1.first power on the cable/DSL modem, wait 20 - 30 seconds for the modem to go in ready state. 2. power on the belkin and wait another 15- 20 seconds for it to become ready. 3. finally power up your PC and everything should be good to go.
Note: if router is new and came with setup CD run that in the computer and follow instructions.
let me know if there are any issues.
Hope this helps, please vote.
regards,
Amar Sondhi
Dec 05, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I cannot get my comcast supplied modem to communicate with my netgear wireless router wpn824 v2. I have tried to power cycle and that has not worked. I powered everything down to clean up the cables and...
Hi, Follow the steps below to reset and configure the router:
RESET:
At the back of the router you will find a small tiny hole (which says restore to factory default settings). Press the button with the help of a paper clip and hold it down for 30 seconds. After 30 seconds, please release the button and power off the router for 5 seconds then power the router back.
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 18, 2009 | NetGear RangeMax WPN824 Router
For some odd reason my wifi light on netgar isnt lighting (desktop computer) . but im trying to hook my laptop through it and it wont let me, whats wrong?
Hi, the wireless light will not lit up if it has been disabled on the configuration or the router has been reset in the past. The only way to get the wifi working is by reconfiguring it. Please perform the steps below to reset and reconfigure the router:
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that THERE IS NO DIRECT CONNECTION BETWEEN THE MODEM AND THE COMPUTERS (either using Ethernet cable or USB cable).
RECONFIGURE:
1. Open the browser(Internet Explorer or Mozilla Firefox).
3. Login to the router with the Username as "admin" and Password as "password" (please note that the username and password is case sensitive).
5. Click Apply.
Once online on the main computer connected through the router. Perform the following tasks to configure the wireless connection:
On the router settings page
1. Click on wireless settings from the left menu.
2. Select security options as 'WEP (Wired Equivalent Privacy)'.
3. Set the 'Authentication Type' as 'Automatic'.
4. Set the 'Encryption Strength' as 64-bit.
5. In Key 1 type a 10 digit number.
6. Apply the settings.
Scan for the wireless network on the laptop and connect to your network.
Regards
Anand
Sep 18, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Conect the router?
1. Unplug your DSL modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router.
2. Connect the new cable (provided in the box) to the yellow
port on the Router.
Plug the other end into the modem.
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer.
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer and double-click on the
“Setup Assistant” icon.It will guide you through he rest of the setup.
If you need more help please post back,If this help please rate as a fixya.
May 17, 2009 | Belkin (F5D72304F5D7000) Router
Linksys wireless on my desktop,trying to use another computer in dining room that has a router or rooter dont know what it is, cant get online please help,the wireless rooter is connected to my main...
You do not need 2 routers to connect to the internet infact you need only 1. having 2 conflicts with pcs and causing them not to work.
From the wall you have your cable fro your internet that plugs into your modem, from the modem it plugs into the router by ethernet cable to the uplink slot and then your computers connect to the router. Most routers can connect 4 computers at once. If running them all wirelessly just reboot them and they should connect automatically. If your wiring them plug them into the back by an ethernet cable in the slots 1 for the first PC, 2 for the second so on and so on. You may have to cold boot everything at first meaning shut down all the computers, unplug the router and modem. Then Plug in the modem let it boot up, plug in the router let it boot up then the pcs.
If you need more hook ups if 4 isnt enough yo uneed a switch or access point not another router.
Let me know If this helps and if I can help further.
Joe
Apr 19, 2009 | D-Link DI 514 Wireless Router (DI-514)
Linksys WRT160N PROBLEM... PLEASE HELP...
Some time what happer router will start blocking the data , in that case what you have to do is that you need to reconfigure the linksys router . First press the reset button for 30 sec , then remove the power for 30 sec and now your router is ready to reconfigure with your setup disk .
if you dont have the setup disk , i am pasting some router reconfiguration steps and i am sure that will help you out .
Please Double Click on the Internet Explorer and on the Address bar,
type in 192.168.1.1 and Press Enter.
Leave the Username blank and type "admin" in the password.
Step 04:
Configure Wireless Settings:
1. Please click on Wireless tab on the router's setup page.
2. Make sure that the Wireless Network Mode is set to Mixed.
3. Change the Wireless Network Name or the SSID from Linksys into your name.
4. For the Wireless Channel, please change it from 6 to 11.
5. Enable the Wireless SSID Broadcast
6. After that, please click on the Save Settings button.
Apply Security Encryption
1. When the router's setup page appears, please click on the "Wireless" tab.
2. When the Wireless area appears, click on the "Wireless Security" sub tab.
3. When the Wireless Security area appears, Change the Mode to WPA personal.
4. Enter the password of your choice in the WPA shared key (it should be minimum 8 characters) and then save the settings.
Step 05:
1. Under Basic Setup tab and set the "Internet Connection Type" to
Automatic-DHCP. After that, please save the settings.
2. Click on the the MAC Address Clone sub tab.
3. In the “MAC Clone” section, set the option to Enable.
4. Click on the Clone Your PC’s MAC button.
5. After that, please save the settings.
Step 06:
Power Cycle:
1. Unplug the router’s power cable.
2. Unplug the Broadband modem’s power cable.
3. Wait for 30 seconds.
4. Plug in the Broadband modem’s power cable and wait for its
lights to stop blinking.
5. Plug in the router's power cable once the modem’s lights stop
blinking.
6. Finally, Test the Internet connection.
Apr 11, 2009 | Linksys WRT160N Wireless Router
Problems adding new MAC address
Ok... this is an easy fix..first, turn off all the equipment including any laptops with wi-fi. then TURN ON YOUR MAIN ROUTER FIRST. Secondly turn on the cable modem..be sure its connected to the already turned on router. This will establish the router as your address the cable modem will set up as the main mac address. Then go ahead and boot up any other routers, and computers and wifi... That should keep everything connected because the router will delegate all the addresses to everything and the modem should remain "happy" with the router addres..
Let me know if this helps... and if you need anymore help.
Dec 29, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Keeps dissconnecting EVERYTHING
You did not mention which version your router is running (V3, V4, V5).
Iwould blame the connection loss on a flaw in the firmware. Go to thebelkin site and see if there is a new firmware available for you: http://www.belkin.com/support/article/?lid=en&pid=F5D9230-4&aid=8593&scid=222
Looking around I found some people had similar problems: http://cnet.nytimes.com/routers/belkin-wireless-g-plus/4505-3319_7-31489123.html
If this helped, then please leave a comment here, so others might find a solution as well.
Dec 28, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can Connect to internet via cable modem, but cannot connect from Cable Modem to LinkSys WRT54G router to PC to Internet ?
1. Make sure your cable modem is connected to the Internet port of the router.
2. Your computer should connected to one of the 4 ports at the back of the router.
3. Check the lights that are lit. Make sure the you have power(steady green), Internet, WLAN and Ethernet port light.
4. Press and hold the reset button on the router for 15 seconds.
5. After 15 seconds, release the reset on the router and turn it off.
6. Turn the cable modem off, too.
7. Wait for a minute. Turn the modem ON first. Wait for the lights on the modem to be ready.
8. Turn on the router. Make sure you have good lights on the router.
9. Check for Internet connectivity.
Nov 08, 2008 | Computers & Internet
My Belkin Wireless G Plus MIMO Router has intermitint connection with the wired computer
the inter net light should blinks dont worry>
delete all teh temp cookies and files and clear history>and change the ether net cable
change the dns to global like
start-->control panel-->network conn-->right click on local area conn-->click on properties-->and highlight tcp/ip-->click on properties-->and select use the current following dns
type
DNS 1) 4.2.2.1
DNS 2) 4.2.2.2
click ok>and restart the pc and rate me solved if its help full thx
Oct 30, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
851 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
