Kenmore 795.77573600. The ice / water display and the led light in the dispenser area flashes and makes a clicking sound. All the functions work properly.
Comments:
Sep 14, 2009
- For what it is worth I have replaced the main board and the control display with no resolve.... I am trying the last know PCB in the fridge (6871JB2061) I'll let you know if it fixes it.....
We have a Kenmore 73503 double door refrigerator with bottom freezer compartment. Water will...
(More)
We have a Kenmore 73503 double door refrigerator with bottom freezer compartment. Water will intermittently drain into the freezer compartment and freeze on the bottom. I understand that this should be draining into a pan that is located in the bottom rear of the refrigerator and upon inspection, this pan is completely dry. Using a stiff piece of wire, I probed up into the drain tube checking for an obstruction and it appeared that there was ice blocking the drain tube. I tried without sucess to clear the ice with a hair dryer. Finally, I unplugged the unit and allowed it to defrost completely (it needed a good cleaning anyway). Upon powering the unit up again, it worked for a couple of days before I observed water draining again into the freezer compartment. I'd like to get at the drain tube further up inside the refrigerator but the inner sheet metal (behind the removable cover) appears to be sealed. I cannot seem to find any sort of service manual online either. Why would ice be forming in and blocking the drain line? Does anyone know how to get inside the unit to where I can inspect the beginning of the drain? Thanks!
I can't get it to reset without unplugging and the manual doesn't give me information on what this...
(More)
I can't get it to reset without unplugging and the manual doesn't give me information on what this error means
My Kenmore Elite side by side freezer on bottom refrigerator is not cooling properly. Noticed...
(More)
My Kenmore Elite side by side freezer on bottom refrigerator is not cooling properly. Noticed yesterday that the control board for the temp seems to be out of Whack - keeps blinking, changing temps (it goes through each icon and blinks several times then moves onto the next it goes through all the temps etc. Any idea what's wrong?
