Question about Dell Inspiron 6400 Notebook
Laptop ? Hi! Last night we had a power surge @ home & now it will not boot itself back up when I turn it on. It will go through the process but when the desktop should show nothing appears other than the blue screen & cursor. Can you help me?
  • magixstar Dec 09, 2007
    am having the almost the same problem, however its more like my power light goes up followed by the hdd, caps, nums lock and shift lock then.. its blank nothing is up other then the power button.
    any idea, before i left home i put it on standby by pressing the power button came back couldn't boot up at all..
    Scholar:
  • 112 Answers
First try to boot in the safe mode, by repeatedly pressing the F8 key. If it boots into the safe mode, press the start button, shut down then select restart. If it will not boot normally then, repeat booting in the safe mode and once booted go to programs/accessorys/system tools/restore the select a restore point date that the computer was functioning correctly and restore for that date. If it will not boot the safe mode restart the computer with the system cd disk and restore from it. BPCS
Posted on Dec 06, 2007
Hp dx5150 mt shut itself down won't start
most likely power supply, those power supplies are horrible and the slightest power surge cooks them. a majority of them I get in for repair are p/s issues, a few for mobo issues.
Mar 08, 2014 | HP dx5150 Small Form Factor PC Desktop
Asus m4a87td Power Surge
Cup of coffee says it is the PS.. First item a surge hits and .......A mo bo will perform a test before it boots up and if all signal voltages are not present properly it simply will not boot up. Hope that your cmos did not get corrupted.
Aug 30, 2017 | ASUS M4A87TD EVO Motherboard
Well, ihave an older compac sr1053WM presario, and I had a power failure of and on all last night, but the pc was not in use all night. it was turned off. And i have a very good surge protector. So I tried...
Its a long shot but try unplugging the power lead from the power supply in the back of the tower. Wait 2 minutes then plug it in again and try powering it up. Regards, nicam49
Feb 09, 2011 | Compaq Computers & Internet
Lenovo 3000 N200 laptop not starting up, power light on
Keep pressed the power button of your laptop for about 30 seconds, the machine will power down.
--The above step may not be required as already so many days passed by.
Then plug it into the power adapter.
Switch the laptop on.
Boot in "safe mode" (F8 during boot).
This will fix any driver or some operating system issue during previous failed boot process.
Once it boots completely, do a normal shutdown and reboot your laptop in standard mode (no more F8 this time).
Now your laptop will be ready to use.
Sep 30, 2009 | Lenovo 3000 N200 Notebook
Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Sep 08, 2009 | Acer Aspire 4520-5582 Notebook
My 360 turns on by itself
your power supply got surged just get a new power supply and it should be fine
Jul 18, 2009 | Microsoft Xbox 360 Console
I am no tgetting sound from external speakers
Power down your machine
Unplug everything from it
Open it up
Remove your sound card and put it back in
Reverse the step and boot your machine
If it still doesn't work then you'll need to replace your sound card. You can find really good ones on Amazon for $25 or so.Remember to always turn off your speakers before you plug them into your computer. Since they are probably powered via AC adapter that surge of power could have shorted out your card. Good luck!!
Oct 01, 2008 | Microsoft Windows XP Home Edition
Wont turn on
Laptops are far more prone to be taken out by even minor power surges then anything else in your home, including desktop computers.
If you have any method (multimeter etc) to check the voltage from the power supply you may have been lucky and it took the bullet to save the laptop.
If the power is registering in the correct range, around 18volts, then chances are your laptop has taken the hit and the motherboard is gone.
If this is the case, then before you throw it against the nearest wall, take it to a laptop repair centre. It "may" have been saved by a fuse on the motherboard and therefore protected itself as best it could.
Prices to have it looked at will vary alot, so call around.
May 24, 2008 | HP Pavilion dv4000 Notebook
Problem During Boot-Up
several things it could be but im going to look at the obvious the battery and cord hook up
laptops when plugged into contstant 120 power the battery is supposed to go into stand by mode and shut battery off so power dont leak into battery
if you have low battery with it plugged into 120 the comp will still think the battery is powering the laptop if battery dead then comp shuts down lack of power
other thing is somehow you caught a virus that reboots comp from dos screen mode
the main thing i always ask is what was the last thing that happened before it did what its doing now
example= was there a power surge pop up screens ect.
May 09, 2008 | Toshiba Satellite A75-S231 Notebook
Dell Inspiron 6400 Notebook Logo
125 people viewed this question
Alun Cox
