Question about Dell E173FP 17" LCD Monitor
Dell 1703FPs TFT Monitor
How can I open the case of the Monitor
  • philtan Dec 07, 2007
    I have to replace my power on micro switch. Cant find how to open the case on this monitor. Can anyone help model is a dell monitor 1703FPs
    Scholar:
  • 53 Answers
You have to pry the back half of the case up away fron the front bazel there iar little plastic lock made into the case after it just snap back to gether ues a butter knife using the flat edgr to lift the rear case up a little till you fine the little lock let go and then slid to the next lock it not to hard to open these
Posted on Jun 10, 2009
USB 2.0 ports not working
Posted on Aug 02, 2008
Had the same problem. You need only the front plastic frame decrease. Between the front side and the bottom Ramen is a small slit, then you can start and then carefully with the help of a Keils of the front frame. Beware! The rear frame is not resolved, this is at the corners with 4 screws on the side framework screw.
Posted on Dec 10, 2007
I've upgraded operating system to Vista and can't find drivers for Dell 1703FPs
Have you tried to download from Dell support site. Support.dell.com
Eventhough it doesn't list Vista as an option it should work. XP 1703FPs
driver should work on Vista.
Jan 23, 2011 | Dell 1703FPs 17" TFT LCD Flat Panel...
I have a Dell 1703FPs monitor. What is the best refresh rate?
Reccommened resolution is
Optimal preset resolution 1280 x 1024 at 60 Hz Highest preset resolution 1280 x 1024 at 75 Hz * Highest addressable resolution 1280 x 1024 at 75 Hzhttp://support.dell.com/support/edocs/monitors/1703fps/en/specs.htm#resolution
Most manufacturers reccommnend 60Hz.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Replacement board: http://www.lcdrepair.us
Dec 02, 2010 | Dell 1703FPs 17" TFT LCD Flat Panel...
It is only a monitor?
Hi
Yes 1703FPs 17" TFT LCD Flat Panel Monitor it is only a monitor
In case I had help you pls vote me
Nov 06, 2010 | Dell 1703FPs 17" TFT LCD Flat Panel...
I have a dell LCD model no 1703FPs monitor, whenever i power the screen its displays for about 4secs and turns black while the light indicator remains green indicating a video signal.
You may have bad backlight inverter board (shorted transistors, transformers, need test lamp to verify), or worst case the lamps assembly (need lamp tester to verify).
You can check and see if the power supply is putting out the 12vdc for the inverter board first and go from there.
http://www.lcdrepair.us/1703fps-inverter.html
http://www.lcdrepair.us/1703fps-power.html
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Sep 03, 2010 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell monitor 1703FPs
you backlights are going off.y ou need to replace the power supply in this monitor very comon problem
Dec 30, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
My dell monitor 1703fps comes on for about 2 seconds
i think if you can service your monitor please see all the filter capacitor i think capacitors leak and need for replacement.
Sep 28, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
How do I get the case open on my Dell Ultra Sharp 1703FPs?
kenm951, You may want to see some vids on YOUTUBE that show disassembly of LCD monitors. Some of the longer ones (8 to 12min) are ok, but audio leaves something to be desired. The big question to you is why would you even want to open up your monitor?????? Bye for now. I'm louie12fix on fixya
May 06, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Powering on
checked your monitor with a qualified proffesional.
Apr 01, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Black screen
Try pressing the 3rd button, as it toggles the Analog or Digital inputs...
Oct 05, 2006 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell E173FP 17" LCD Monitor Logo
576 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
