Before you open it test the input use analog multimeter for continuity testing,
if the pointer moves forward then turns back quickly your rectifier diode is good but the pointer is steady like this image below
Note:
Make sure this power cord connected to
your monitor before testing.
you have shorted semiconductor inside. check the thermistor, the bridge type diode & relay switch can cause of blown filter capacitor if you did not found these shorted at the primary section of power supply.
The bracket(s) holding the monitor on the stand appear to be bent such that the monitor only points...
(More)
The bracket(s) holding the monitor on the stand appear to be bent such that the monitor only points downward. Is there any way to take the monitor off the stand and replace the brackets?
Problems with ViewSonic VX2255 Monitor
I cannot seem to get the web camera to work? I...
(More)
I cannot seem to get the web camera to work? I downloaded the latest drivers from Windows and Viewsonic. What am I missing? I have even used the side menu to try and enable the camera and it does not seem to work.
