Question about MSI AMD ATHLON-64 939 PIN MOTHER BOARD (MBK8TNEO2939) Motherboard
K8 Neo-2 V-2.0
Hooked power supply to jwr-1 leeds at front of box Jfp-1 Reset,hdd led, power led power switch Speakers to Jfp=2 H-drive to ide-1 cd rom to Ide-2 2 gig ram dimm 1 & 2 vidio card agp-slot computer turns on will not play CD unplug from Ide2 cd- runs will not load driveeers or operating system
  • 2,351 Answers
Please connect jPw1 to 4 Pin 12v, this supplies power to CPU. Than enter Bios & find Boot settings. Set the cdrom as boot 1 & hd as boot 2. Check the jumper on the cdrom, as it is the only device on secondary IDE controller it should be set as a master.
It is better to install a fresh copy of windows with a new motherboard. Put your windows CD in the cdrom & the system will boot to it. And your on your way. You can install the drivers for the board after windows has been installed.
Plaease vote..
Posted on Jan 26, 2008
Missing power pack some ribbons
Rut Ro!
1) Three 'ribbon' cables are all you need.
Two IDE 40-pin cables, and One 34-pin Floppy Drive cable.
The wider 40-pin IDE ribbon cables are for the Harddrive, and Optical Drive/s. (CD/DVD drives)
(Actually 40 -> socket holes, and actually only 39 are used)
The narrower 34-pin IDE ribbon cable is for the Floppy drive.
I would like you to look at a Locating Lug, on an IDE flat ribbon cable, (IDE is also referred to as PATA),
Note on the blue rectangular connector, the two ridges at the Top/Middle. This is a Locating Lug. Shapes vary, but the same basic principle is kept.
Note the two IDE motherboard connectors. One Blue, one Black.
Note on the blue IDE connector that there is a cutout on one side.
(Outside edge of motherboard, Middle of side )
This is what the Locating Lug lines up with.
[Note also that IDE1 is silkscreened, on the outside edge of the motherboard, and between the blue IDE connector.
This is where the harddrive cable plugs into.
IDE2 which is right above (Black), is where the optical drive/s cable plugs into ]
IF, there is No Locating Lug on the flat IDE ribbon cable's connector;
The thin Red stripe on the side of the flat ribbon cable, denotes which side Number 1 wire is on.
Looking at your motherboard, with the Processor to the Top, and Ram Memory slots to the Right; Number 1 pin in the two IDE connectors on the motherboard, is on the BOTTOM.
The Red strip on the flat ribbon cable, goes towards the Bottom of the motherboard.
Looking at the back of your IDE harddrive, start at the Right side, go towards the Left;
On the right side are 4 pins. These are for the power cable. To the left of them are jumper pins. To the left of the jumper pins is where the flat ribbon cable plugs in.
The Red strip ALWAYS goes toward the power cable.
Same thing with an optical drive.
With the above Gateway E-4000 motherboard example, the IDE connectors for the Harddrive, and optical drive/s, is at the Top/Middle.
The White connector is for the Optical Drive/s cable. (IDE2)
The Black connector above it is for the Harddrive cable. (IDE1)
The smaller black connector to the Left of the black Harddrive connector, is for the Floppy Drive cable.
The whitish opaque long connector under the black Floppy Drive connector, is where the 20-pin ATX main power cable plugs into,
(Note color of connectors does Not matter)
3) Where the black Processor Fan is. Come to the Bottom/Right corner of it. Go straight across, and stop under the aluminum finned Heatsink, above it. (Heatsink looks like a meat tenderizer)
This whitish square 4-socket hole connector on the motherboard,
is where a 4-pin ATX +12 Volt power cable plugs in,
Note that both it, and the 20-pin ATX main power cable's connector, has a Lock on one side. This lines up with a Lock Tab on the motherboard connector. When the power cables are deemed to be tightly, and properly plugged in, the hooked end of the Lock will be over the Lock Tab.
This type of power cable plugs into the Harddrive, and Optical Drive/s,
(Commonly misnomered as a 'Molex' power cable. Molex was the first company to make the connector, and their manufacturer name stuck. Kind of like referring to an open-end wrench as a Crescent wrench)
4-pin Peripheral power cables may also be used for computer case fans.
(Yellow wires are 12 Volt wires. { DC }
Red wires are 5 Volt wires. { DC }
Black wires are Ground wires.
Do not hook up a 5 Volt fan to a 12 Volt wire )
Intel D845GRG motherboard is Gateway part number 4000828,
The front of your computer is the Front Panel.
The the area of contact pins on the motherboard, that the main wire go to from the Front Panel, is the Front Panel header.
In the list click on Q - Front Panel connector
Motherboard installed in computer case the Front Panel is down in the Bottom/Right corner. It is the second header over from the Right.
The pins across the Top row are numbered EVEN.
Starting on the LEFT side going towards the Right;
Pins 2, 4, 6, 8, 10, 12, 14, and 16.
The pins across the Bottom row are numbered ODD.
Starting on the LEFT side going across to the Right;
Pins 1, 3, 5, 7, 9, 11, 13, and 15.
A) Pins 1 and 3 are for the HarDDRive activity LED (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9, 11, 13, and 15 are not used. Reserved for the factory.
D) Pins 2 and 4 are for the Power On LED (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is No Pin 10
There is No Pin 14
Pins 12 and 16 are N/C. Not Connected.
You can also see in the list where the Front Panel USB ports connect to (P - Front Panel USB connector), and the Front Panel Audio ports, (V - Front Panel Audio jumper )
The Power Supply used is a piece of Cr@p.
160 Watts. This is what it looked like,
Gateway part number 6500704,
(Click on Product View, and on Specifications)
It is approximately 6 Inches Wide, 3-1/2 Inches Tall, and 4-1/2 Inches Long.
When installed there is a green plastic lock, that swings over to lock the Power Supply in.
I would remove that green plastic lock mechanism, and use an ATX Power Supply.
All the same dimensions as above, except it is 5-1/2 inches Long.
ATX power supplies are used in a LOT of desktop computer, and readily available. A VERY common Power Supply.
Guess what else? You won't be stuck with a lowly 160 Watt power supply, or have to pay through the nose to get another piece of junk like it.
The Philips head screws in the back of the computer case, hold the Power Supply in just fine, without that plastic piece of junk, also.
An example of a Power Supply that would work, green plastic Lock removed,
430 Watt Power Supply will Not harm the computer.
Because a computer ONLY uses the power it needs, and NO more.
For additional questions please post in a Comment.
Sep 01, 2012 | Gateway E-4000 PC Desktop
Okay,.......that was DU-MB!
Lemme see,.......oh yeah!
Letters and words! !O_O!
(Wondered where my glasses were!);_ylt=A2KJkCAV3j9QW2cAUAOJzbkF;_ylu=X3oDMTBlMTQ4cGxyBHNlYwNzcgRzbGsDaW1n?
Motherboard photo, and detailed info below it. Scroll down.
Looking at the motherboard installed in the computer case:
1) To the right of the Ram Memory slots, and in the upper right corner, is the 20-pin ATX main power cable connector, on the motherboard.
Whitish connector with two columns of 10 socket holes.
A 20-pin ATX main power cable plugs in here,
Note the Lock on the side of the power cable's connector, (Middle photo, and right photo), and the Tab on the motherboard connector, (Left photo)
When the power cable is plugged in correctly, the hooked end of the Lock on the power cable's connector, will be hooked over the Tab on the motherboard connector.
2) Look at the bottom Left corner of the Processor socket. Note the three cylindrical objects. (Radial Aluminum Electrolytic Capacitors)
Note the whitish square 4-socket hole connector below them.
This is where the 4-pin ATX +12 Volt power cable goes. It also has a Lock, just like the 20-pin ATX main power cable connector,
This is power for your Intel Pentium 4 processor.
3) To the Right of the Ram Memory slots, and located below the whitish 20-pin ATX main power cable connector, are the two IDE connectors. (Turquoise Blue)
One is for an IDE (PATA) harddrive, and one is for an IDE(PATA) optical drive. (CD/DVD drive)
The one on the outside near the edge of the motherboard, has IDE1 next to it.
It is for the Harddrive.
The one closer to the middle of the motherboard is IDE2.
It is for the optical drive. (Or drives { 2 } )
One side of those rectangular connectors has a cutout in the middle.
(Square U-shape cutout)
This is where the Locating Lug, on the flat ribbon IDE cable's connector, goes to.
It aligns Number 1 pin in the connector, with Number 1 wire, in the flat ribbon IDE cable.
IF, there is NO Locating Lug on the flat ribbon IDE cable;
On one side of the flat ribbon IDE cable is a thin RED stripe.
This stripe denotes the side that Number 1 wire is on,
Looking at the rectangular IDE1 and IDE2 connectors, Number 1 pin is at the BOTTOM of those connectors.
(Motherboard installed in computer case)
On an IDE harddrive, Number 1 pin is ALWAYS towards the 4-pin power connector.
Same with an optical drive.
4) Since this is a motherboard, that has a RAID option for using multiple harddrives, I'm guessing the two Yellow rectangular connectors, below the two rectangular Turquoise Blue IDE connectors, is for more IDE harddrives.
5) Below the two Yellow IDE harddrive connectors is a Black rectangular connector.
This has 34 pins, and is for a Floppy Drive, IF a Floppy drive is used.
6) Below the Black Floppy Drive connector on the motherboard, is the Front Panel header.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
What is needed here is a Front Panel header pinout.
Dunno. Photo isn't clear enough.
Looks like a Black rectangular strip of plastic, with 8 pins in a row.
4 pins, 3 spaces, 1 pin, 1 space, 3 pins.
Looking closely, (And you may need a bright light, and a magnifying glass), what are the abbreviations next to the pins, on the outside edge of the motherboard?
HDD = HarDDrive activity LED (Light)
PW = Power On switch
RST = Reset switch
PWLED, or close to that effect = Power On LED.
Post back in a Comment.
IF, it is just a row of single pins going across, I would use an LED light that has two wires on it.
Computer, (Power Supply actually), plugged into power, touch the two wires to the first two pins.
Go on.
When the Power Supply comes on you know you have the Power On switch pins (2)
Now go back through, but do not touch those pins again.
LED light blinks? = HarDDrive activity LED (Light)
LED light stays on? = Power On LED (Light)
Computer restarts? = Restart switch pins
7) To the left of the white long PCI slots, (There are 5 towards the bottom of the motherboard), are two small Black rectangular connectors. Each has 4 pins in it.
The one that has Audio, or CD, or CD-IN, is for the audio cable from the CD/DVD drive.
8) At the Top of the motherboard in-between the Processor socket, and black Ram Memory slots, is an Orangish connector with 3 pins. Should have CPU, or CPU_FAN next to it. This is where the Processor fan plugs in.
9) At the bottom/left, and below the two small black connectors with 4 pins in them, is an Orangish connector with 3 pins.
This should be for the computer case fan.
Additionally you may want to join this website, and ask them for the Front Panel header pinout, for your Abit BD711 motherboard,
Finding information for an ABIT BD711 motherboard, is about as rare as finding hen's teeth.
I, and I'm sure 100's of people, would be in your debt, if you would post the Front panel header pinout for this motherboard.
Hope I have redeemed myself for the S.N.A.F.U. of the question asked in the Comment, lol!
Aug 30, 2012 | Computers & Internet
I'm having trouble with the pin out connections on a syntax motherboard. Where can i find a diagram?
Align the motherboard in your mind, so that we are both looking at it in the same direction;
Processor to the top, Ram Memory slots to the right, the four white PCI slots to the bottom.
The plastic front of a desktop computer is the Front Panel.
The area of pins on the motherboard, that the cables (Wires) from the Front Panel go to, is the Front Panel header.
The Front Panel header for the Syntax SVM266A is below the IDE 2 connector. It is labeled Panel 2
(Harddrive plugs into the IDE 1 connector, optical drive/s plug into the IDE 2 connector)
Panel 2 is mounted horizontally. It is parallel to the IDE 2 connector.
There are 4 pins across the Top row, and 5 pins across the Bottom row.
The pins are numbered. Even across the Top, Odd across the Bottom.
1) Starting from the Left side going towards the Right, for the Top row;
Pins 2, 4, 6, and 8. There is no Pin 10, just a blank spot.
2) Starting from the Left side going towards the Right, for the Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive wire.
If the Power On LED light is dim, switch the wires around.
B) Pins 6 and 8 are for the Power On switch.
C) There is no Pin 10
D) Pins 1 and 3 are for the Harddrive activity LED light. (HDD LED)
Pin 1 is for the positive wire.
If the HDD LED light is dim when operating, switch the wires around.
E) Pins 5 and 7 are for a Reset switch, IF a reset switch is used.
As for a motherboard manual,
Scroll the page down to about 3/4ths the way down, until you come to the bold heading -
Click on Manual.
This is a PDF file. It may take up to 30 seconds before the first page comes up, and additional time for the file to fully download.
Oct 16, 2011 | Syntax SVM266A (SYSVM266A) Motherboard
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
How to connect jfp 1
go to for MSI guide , it should show you your motherboards front panel intel connection guide , it should be like this
Jun 08, 2010 | MSI G31M3-L V2 Motherboard
How to connect power switch on msi ms6787
At the bottom right hand corner of the mobo you'll find there is a set of pins marked JFP 1 and the power switch pins are marked clearly so are the HDD Led, reset, Power Led etc. Plug in your wires which are also marked, corresponding to the marked pins.
Sep 23, 2009 | MSI P4MAM-V SND/LAN/VIDEO (6787060)...
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
Lookig for a manual for an fic au13 motherboard
Front Panel Block Cable Connections
1 3 5 7 9
2 4 6 8
1] HDD-LED (+)
2] Dual Power-LED* (+)
3] HDD-LED (+)
4] Dual Power-LED* (-)
5] Reset Switch
6] Power Switch
7] Reset Switch
8] Power Switch
9] Dual Power-LED* (**)
* Single Color Power-LED 2 or 3 pins:
1 2 3
1]Power-LED (+)
2] GND
3] GND
** Dual Power-LED:
if useing dual power LED,
Green: pin2
Yellow: pin4
otherwise, Pin2 is positive (+) Pin4 is negative (-
For future Reference you can download your manual directly from the manufacturer's website HERE
Or directly from HERE
May 30, 2009 | FIC AU13 Chameleon Motherboard
I tried several different cards but no luck. Cards work ok on other computers.
5V Stand-By Indicator LED
The power supply will always supply a 5V standby voltage to your
motherboard so that it can power on via for example Wake On Lan
technology. This LED shows that your power supply is supplying
this standby voltage to your motherboard.n :D
You may need to replace your power supply, if the LED is flashing, it's not supplying the power the motherboard needs.
1 2 3 4 5 6 7 8 9
10 11 12 13 14 15 16 17 18
1] Power Led (+)
2] --
3] Power Led (-)
4] --
5] --
6] Speaker (+)
7] --
8] --
9] Speaker (-)
10] Reset switch
11] Reset switch
12] N/A
13] Power Switch
14] Power Switch
15] ACPI Led (+)
16] ACPI Led (-)
17] HDD Led (+)
18] HDD Led (-)
For future reference you can download your motherboard manual here:
(PDF) Soyo K7VKP2
May 09, 2009 | Computers & Internet
MSI AMD ATHLON-64 939 PIN MOTHER BOARD (MBK8TNEO2939) Motherboard Logo
216 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
