Question about Dryers
Hotpoint Dryer TC71P
When replacing the cut-out kit, how do you know which one is the auto reset and which one is the one shot.
  • Glyn Mahon Dec 07, 2007
    Big help thanks a lot.
  • 139 Answers
When replacing the dryer stats you always replace both because they come in a kit. And to check which one is blow you do a continuity test.. Thats what i alway do....
Posted on Dec 07, 2007
Where will I find the heat reset button on my tcm580 condenser dryer
Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse OR a thermal cut-off fuse, but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
Feb 15, 2017 | Dryers
Hotpoint Dryer - TC71P
The belt may be broke off from the pulleys.
Nov 22, 2015 | Dryers
My hotpoint tc71p is buzzing and not working ?
If the belt is not broken it is the capacitor on the motor that has gone it is more than likely built into the motor .Which will need changing.
Oct 05, 2014 | Hotpoint Dryers
Getting tension on a tension pulley hotpoint tc71p
hi not sure on your model i think its a fixed one with two bolts if slack i would thing wheel has collapsed will need new one about 10 pound easyest way i find to fit is taking drum out
Feb 18, 2013 | Hotpoint Dryers
Tc71p two thermostats and heating elements changed but still no heat
Need to check motor switch built into motor. Make sure there is 240 volts supplied to dryer.
Sep 27, 2012 | Hotpoint Dryers
Hotpoint Aquarius TCM570 - This unit is just over 12mths old!!! The heat function has ceased to work, it still spins etc but there is no heat. I've read on a previous posting relating to the same tumble...
Always disconnect power while working on easy, disconnect the two wires from the fuse, take black electrical tape and tape them together, test dryer if it works then disconnect taped wires and buy fuse install new fuse. Here is a website that should help, Tim:
Nov 27, 2010 | Hotpoint Dryers
here is the first video that might help
You-Tube video "Vx9JMZRRKrg" placeholder (do not delete)
Dec 21, 2009 | Hotpoint Dryers
Drive belt needs replacing on Hotpoint TC71P
how do i get my tension correct on a hotpoint tc71p
Jan 19, 2009 | Maytag PYG2300A Gas Dryer
Hotpoint vtd20 dryer aquarius - cuts out when overheats
You can get spare parts on line by going to,
Re your other prob ,it is probably due to a fault with the heater, disconnect the heater and run the dryer .if it does not cut out then your heater needs replacing.
Dec 10, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint CTD 40
Thermostats do not have a reset
IF the dryer has failed by overheating, the device is called a thermal fuse, it is a one-shot protector, and needs to be replaced.
If the thermal fuse has blown the dryer is likely {expletive deleted} with lint and needs to be cleaned.
STILL require make and model details for replacement instructions
Oct 08, 2008 | Dryers
Dryers Logo
212 people viewed this question
Top Dryers Experts
