Question about Refrigerators
GE Model# GSS25LGMAWW refrigeratorr
I would like to know the probable cause of food freezing in the refrig section of the refrigerator and a possible solution to the problem
  • 1 more comment
  • Anonymous Jan 06, 2008
    we haved tried everything to stop fridge from freezing all the food. we dont know what more to do.
  • LaurenStarr Feb 02, 2009
    The refrigerator side is freezing food and we have slowly been changing the temp to warmer but are now at the warmest it can go.
  • Anonymous Mar 31, 2009
    Refrigerator freezes food at warmest setting
  • 40 Answers
The dials may not be set right.
Posted on Dec 05, 2007
  • Michael Calligan
    Michael Calligan Dec 25, 2007
    Can you explain why you think that my solution was inappropriate?
MY GE MONO SIDE BY SIDE REFRIG,MDL ZISS480DRSS IS FREEZING THE REFRIG SECTION.THE TEMP READ SAYS IT IS NEARLY 80!I THINK IT MAY BE REACTING TO THE TEMPERATURE DISPLAY AND TRYS TO COOL IT DOWN.HELP!
Here are possible parts that could cause the problem
GE Refrigerator Freezing Food but the most common is the diffuser/damper that got stuck open and cold air from freezer continously coming in to the fresh food side.
Nov 22, 2017 | GE Refrigerators
Side by side ge refrig freezing food in refrigerator side temp control working since when turned to zero clicks off what could this be
Probably the temp control is defective and is defaulting to maximum. I would suggest replacing it to be sure.
Feb 01, 2015 | GE Refrigerators
The food on the refrigrator side is freezing. the water line is not working so i assume its frozen as well.
Hello Tina,
The problem with it freezing in the freshfood section is going to be because the air damper that opens and closes to let cold into the ref. section is stuck open and too much cold air is entering into the ref. compartment. This is a fairly common occurence with the GE refrigs. and by replacing the fresh food air damper which is located in the upper left corner of the fresh food compartment it will open and close properly and not allow too much cold air to enter where upon it freezes everything.
GENE
Sep 30, 2011 | GE PSW26MSR Stainless Steel Side by Side...
Refrig side is freezing food...........model #PSC23MGNA
HI,
This model has a cover inlet located in the bad top section of the refer, this allow shared air from the freezer to enter the refer section, this unit has a damper door and a fan in it. When the damper door breaks it allows air to enter all the time causing the food to freeze in the refer section. Part # WR49X10091, this link will should you what this part looks like and the cost of the part needed to correct this problem. Inside the white plastic shell, is the parts I was describing above. Not a difficult repair but can be time consuming as the unit is built like a puzzle and will need to be disassembled to change.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 26, 2011 | GE PSC23MGN Side by Side Refrigerator
My GE Profile Artica PSI23SCN refrig. temp on the refrig side stays at 27 degrees. I turned up the freezer temp to 6 and the refrig went up to 31. I called arepair guy and he said he had a client with the...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 02, 2011 | GE PSI23SCN Side by Side Refrigerator
Ge electra series side by side refrigerator keeps freezing food in my refrigator
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 17, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrig. is freezing food
Your problem is going to be with your damper if its a side by side, the damper is what will direct the airflow from the freezer section to the fresh food side. Often times the flap will break off or stick open allowing cold air to enter the ref section all the time. This will cause the food to freeze usually towards the top of the unit. Or possibly a bad temperature control causing the unit to run constantly.
MJ
Mar 04, 2010 | Kenmore Refrigerators
Refrigerator side of GE GSS25LGMAWW freezes food. How do I fix it?
Your defrost system is out and this is an easy repair. Just contact us with your brand and model number and we will get the correct part out to you right away.
We also provide part removal/installtion instructions for folks that want to save money by performing the repair on their own.
We hope this answers your question and we look forward to working with you.
Nov 04, 2009 | GE GSS25LGM Side by Side Refrigerator
Why would my refrigator be freezing my food set at the lowest setting it can be set on
If it has a damper at the top left wall , the damper is bad or the refrig control (possibly circuit board) is bad .The damper closes to reduce the air flow to the refrig yet the freezer section can still get colder if needed . The refrig control or circuit board for the fridge control , works the damper . If you feel air coming thru the damper , it is not closing , causing your food to freeze .
Jul 18, 2009 | Amana Refrigerators
GE side by side refrigerator TFX22ZRA control board
The adaptive defrost on your model is controled by the motherboard, but I don't think that is your problem. If the freezer is too cold and the fresh foods is too warm, check the air dampener. It is a small duct door in the very back top left of the fresh foods section.
Jul 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
590 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
