Question about Lands Phones
Lucent DCP Attendant Console 302C
We do not have the manual to this phone and can not figure out how to turn up the hand set volume. The ringer volume is fine but you can barely hear some of the callers on the handset. Any ideas how to turn this up?
  • azuremarie Feb 10, 2008
    I'd like to turn up the handset volume so that callers can hear me. I know how to turn up the handset volume so that I can hear the callers more clearly (numbered wheel on the handset). This is a huge problem because at least half of all callers cannot hear me unless I yell into the handset.
  • Anonymous Apr 17, 2009
    there is no headset volume in the list
  • 3 Answers
For the 302c, you first hit either volume up or down on the upper right of the console, THEN you hit the SELECT button which is to the left of the 2 volume buttons. on the display you will see likely "Ringer volume" so hit SELECT AGAIN, then you will see "HEADSET VOLUME" then you can hit the volume up to adjust the headset volume.
This took me about 10 minutes to figure out, so don't feel bad.
Posted on Dec 30, 2008
  • fscdallas Apr 01, 2011
    This ALMOST worked on our phone, but after ringer volume, there was no handset volume....UGH
I need to turn the ringer OFF on my AT&T 210/Lucent TrimLine.....sounds like a fire alarm...!!!
Search Results
FAQs - AT&T® Telephone Store
https://telephones.att.com/product-support/faqs/symptom/1591/89 Tip 1 of 8. If the phone does not ring at all, you may have the ringer turned off. The handset and base have independent ringer programming. To adjust the handset ringer volume: Step 1: Press MENU/SELECT on the handset when it is not in use. Step 2: Press ?DIR or ?CID to display Ringers, then press MENU/SELECT. Missing: lucent
[PDF]TRIMLINE® Memory Telephone 210 - Amazon S3
s3.amazonaws.com/szmanuals/62619bc8d4792f47b6654ed48c3548a3 AT&T and the globe symbol are registered trademarks of AT&T Corp. licensed to Advanced American .... Ringer Volume. The RINGER volume switch allows you to turn the telephone ringer OFF, or set it to ring at LO or HI volume. You can dial or answer calls normally when the ringer is off. Other telephones in your home will.
How to change the ringer tone on the AT&T Trimline 210 - YouTube
? 2:58
https://www.youtube.com/watch?v=xZxexCm7xtk
Apr 30, 2016 - Uploaded by kmbfanofpacman
I just figured out how that works after the day I got the phone and its pretty cool to be honest.Missing: my ‎lucent
[PDF]AT&T 210 User manual - Multi-Link Inc.
https://multi-link.net/wp-content/uploads/ATT-ATT210-Manual.pdf Make sure the ringer volume switch is not set to OFF. You may have inadvertently turned off the ringer. Press. ,. , , . If there are several other phones on the same ... 11. 12. For Customer Service Or Product. Information, Visit Our Website At www.telephones.att.com. User's manual. Part 2. TRIMLINE. Memory telephone 210. Missing: my ‎lucent
Lucent AT&T Trimline 210 Corded Phone Ring tone - Questions (with ...
www.fixya.com > ... > Lucent > Lucent AT&T Trimline 210 Corded Phone
Lucent AT&T Trimline 210 Corded Phone, ring tone related issues. ... If the ringer volume has been turned off, the handset will not ring ? ... ...ring tone im receieveing the voice ring tone but prefer the volume how can i change my ringtone When the phone is sitting in its normal mode hitting the "flash" button toggles through ...
Apr 07, 2018 | AT&T Lands Phones
How do i unmute the ringer on my vtech dect 6.0 phone
Hi Angie.
The manual for this phone can be viewed here:
http://cdn-media.vtechphones.com/ecp/documents/product_Product/1681/UserManual/6351/ls6425-3_manual_i3.pdf
On Manual Page 20 / pdf page 23, it says that if the ringer is muted for a single call, that it should work again the next time someone calls.
However. page 57 notes that the base ringer volume can be set between 0 and 6, so it's possible your ringer volume is not technically muted, but just turned all the way down.
Manual page 62/pdf 67 has a half-page list of other reasons that the ringer might not ring. (It can also be turned off, and there are different adjustments for both the phone and the base unit.
Hoing this lets you figure it out!
D
Dec 03, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Hi i have a lucent phone partner-6. how do i turn the ringer off
Go to the system attendant and have them perform Centralized programming to change your ringing. It's a simple procedure, but it must be done with a better phone from extension 10 or 11.
Carl
Sep 09, 2010 | AT&T Lucent MLS-12D Phone
I can not find my manuel. How do I turn on the
You can choose from four ringer volume settings on the handset (off, low, medium,
and high). With the phone in standby, use the up arrow or the down on the handset to adjust the
ringer volume.
You can find your manual online in PDF format here:
http://www.uniden.com/pdf/TRU9360om.pdf
Apr 20, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Lucent 854 phone, how do we turn up the ringer?
To Adjust Ringer Volume:
1) Press CONF, then using the dialpad press either 1, 2, 3 or 4 to indicate which line you want to adjust.
2) Press one of the VOLUME buttons to increase or decrease the ringer volume.
To Turn the Ringer Off
1) Press CONF
2) Use the dialpad, press 1, 2, 3, or 4 to indicate which line you want to adjust
3) Press the down VOLUME until you no longer hear a tone.
Feb 28, 2009 | Lucent Lands Phones
Turn ringer on T7316
T7316 Manual
The volume control adjusts the handset, hands free, headset, and ringer volume. Someone may have fiddled with the buttons and turned the ringer down enough that it doesn't sound when a call is incoming.
Feb 12, 2009 | NorStar Meridian M7310 Phone
AUTO ATTENDANT NOT ANSWERING
There is about three to four programs that need to be set up in your phone system in order to do this , the program number my be a little different depending on the partner system you have .
Jan 19, 2009 | Lucent PARTNER18 Corded Phone
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Dec 31, 2007 | Panasonic KX-TG2357 Cordless Phone
Can't turn ringer volume down
You can download a manual for this phone here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000036632.pdf Pages 18-19 explain how to set the ringer volume.
Apr 17, 2007 | IBM Corded Phone IBM412CID
Lands Phones Logo
2,113 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
