Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
MDE 9700 AYW Maytag neptune dryer
My dryer stopped working. The lights are on but I have no tumbling. The repaireman came and replaced the drum, rollers, mother board and something else. Closed it up and tried it, nothing. He said he thinks it is unrepairable. He never opend it back up or anything. Of course we are getting the runaround from the warranty company. We are 3 weeks out with 6 in the household. They said it could be 6-8 weeks for a response. My husband is tempted to open it up and see if he forgot to hook something up. He is very handy. He use to fix our old machines.
Thanks, Desparate in NY
  • Anonymous Sep 01, 2008
    I have a Maytag model MDE9700AYW electric dryer. It's been not working for a month now. Had a Maytag "preferred" national service company come out and replaced two parts that weren't broken (took two weeks to get the parts in), still not working - they ordered different parts - came back two weeks later - working but no heat. They said it was my 'outlet'. So, I replaced the outlet. Still runs with no heat. The only part they didn't replace was the heater kit. Wondering if I should call a different service and see what they say? Help! - tired of going to friends to do laundry.
My dyrer just stopped working one day. I've had the heating element checked, both boards and my electrical outlet checked but my dryer still doesn't work. All I get is a troubleshooting code that looks like an upside down F with a 5 behind it. If you have a solution to this problem please let me know Thank You.
Posted on Sep 24, 2008
MAYTAG NEPTUNE MODEL MDE9700AYW HAS ERROR CODE LOOKS LIKE AN UPSIDE DOWN F 5 AND WON'T RUN HELP
Posted on Aug 25, 2008
Why does my Neptune moder number mce8000ayw dryer not tumble?
If the motor runs, but the drum doesn't rotate, check the belt, part # 341241. It's probably broken and off of the drum.
May 14, 2014 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag electric dryer model# MDE 4658 AYW does not dry my clothes (no heat) and the light no longer stays on when the dryer door is open. started happening after i turned all fuses off in the house. can...
I gotta assume you're joking since it looks like you're asking why the dryer isn't working when you've turned all the power off in your house.
If this is the case then the only way your dryer is going to function is if you bought it with the optional Maytag Cold Fusion power supply. Or you could turn the power back on...
Oct 30, 2013 | Maytag Dryers
I need to find out what kind of dryer belt my Neptune takes?? Mde 9700 aym
the link below will take you there show you the price and all you do is select it and check out. Please remember to rate my solution and give testimonial it is how i earn my accomplishments thanks in advance.
copy and paste below link in to browser.
http://www.repairclinic.com/PartDetail/Drive-Belt/W10205415/1937372
Apr 23, 2012 | Maytag Dryers
Drum making harsh squeaking sound when maytag dryer model MDE 9606 in use
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 01, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Dryer won't heat maytag neptune mde 5500 ayw
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer access to the thermal sw
moz-screenshot-4.pngThe thermal limit mounts beside the heater element chamber and is held to it by the same screw that holds down the element.
The kit comes with 2 limits one fer gas the other fer electwic.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 02, 2009 | Maytag Dryers
Maytag Neptune dryer MDE 6700AZW Stops working
try a simple test before you try to gain axcess to the console parts unplug the power cord 1 min plug back in and put in time dry not auto or it will time out quickly without wet cloths see how it does and if this not solve you problem repost with model #
Aug 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My Neptune mde 9700 dryer heats inconsistently. more times than not it take forever to dry a load nomatter what the size
you have either a thermistor at fault of the heating element isnt operating properly
Aug 21, 2009 | Maytag Dryers
MDE 6200 AYW Maytag Atlantis broken baffle
To lift the top and access baffle screws, proceed as follows;
1. Remove door hinge screws from cabinet. Door can remain in place.
2. Remove screws and plastic retainers opposite door hinge
3. Grasp each side of the top front panel and pull forward. Lift to remove panel
4. Remove lid retainer clamps from each front top corner.
5. Lift top to access drum baffle screws.
If you need further assistance, let me know
Regards,
reg501
Jun 30, 2008 | Dryers
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
1,580 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
