Question about Plantronics 510 Voyager Headset - PLN-510 Headset
Using Plantronics 510 headset with my Treo 680
When I go to turn bluetooth on my treo crashes and when it comes back on bluetooth still is not on.
  • Anonymous Dec 25, 2008
    My plantronics bluetooth (a different model, the explorer 220 (19.95 at costco) makes my sprint  treo 755P crash!
  • funky5 Dec 25, 2008
    My plantronics explorer 220 (I have 2 of them, I bought them at Costo) makes my treo 755P (Sprint) crash!
Dude, my plantronucs explorer 220 ($19.95 at Costco) makes my sprint treo 755P crash too!)
Posted on Dec 25, 2008
    Genius:
  • 1,003 Answers
How old is your treo this headset uses bluetooth 2.0
Posted on Jan 14, 2008
Setting up headset with treo
Not sure which Palm Treo you have, but after reading through some of the info on the different sites it states that some bluetooth devices were easily installed and others were not. It may be one of the Treo's that may need an application to download an update. Some of these were released according to the information I read, that did not have DUN installed. Whether this has anything to do with pairing your bluetooth device, I am not sure. I couldn't find a spec page for your application. Usually it is just a simple matter of going to the bluetooth application on your phone and turning on your bluetooth headset. They find each other and you have success. I would recommend talking to Plantronics tech help line at 800-544-4660 x 5538.
Good luck from Headsets Direct!
Sep 12, 2008 | Plantronics Explorer 330 Headset
220 Plantronics stopped working
Look under my name and find the previous 10-20 posts helping others with similar problems on adding/removing the existing connected device. However the Plantronics 220 Express and regular have connection problems with phones if they are far away, and sometimes get corrupt, unfortunately, for a $28.00 headset, its build for $28.00 of use.
Please review my previous posts and see if this can help you at all..
ManOwar
Aug 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
Palm treo
THE phone's Headset Plug is stucked. Try to plug and Un-plug the headset many times for it will release. Best, Play a Music and try this on so when you haer the sound coming from the phone, it means it works
Jul 29, 2008 | Palm Treo 680 Smartphone
I have a Mac laptop, a Palm Treo Wx and am now using a Motorola H700. I need to know how to sync my H700 with my Treo so I can dial via my headset and not need to use the actual cell phone. It has now...
Hi, i'm not sure what the Mac has to do with your Headset. You can register your blue tooth headset with any device that supports bluetooth. In fact, you can use your headset with multiple devices. Even your Mac can use bluetooth to connect to a headset (if you have bluetooth turned on, and not all Macs have factory bluetooth).
To 'register' your headset with the Treo is a two step process.
on the Treo, make sure bluetooth connectivity is turned on, then you should have a menu that allows you to find/enroll a new bluetooth device. Before you tell it to find a bluetooth device, turn on your headset. Now tell the Treo to search for devices. If it doesn't find your headset, then press and hold the button on the side and it will send out signals that your Treo will see. The Treo might give you a password code and ask you to confirm this is the device you want to synch to. Usually '0000', but in any case say yes, so long nobody else is around trying to do the same thing you are within 30'.
That should do it.
I don't think the Treo has voice recognition, which makes dialing on my Nokia a breeze, for true hands-free operation, nothing beats it.
Also note, the Treo has been know to have issues loosing bluetooth connectivity with the headset and not reconnecting with a re-boot.
so long you keep the two devices near each other, this shouldn't be a problem.
stephen
Jul 05, 2008 | Palm Treo 700w Smartphone
Settin up bluetooth
Turn headset off.
Hold down the "phone" button on the headset.
Turn headset on.
Release "phone" button.
LED ring should be alternately flashing red/blue.
Voila.
Jun 21, 2008 | Plantronics Pulsar 590A Wireless Headset
LG HBM-730 Won't Connect to Treo 650
Actually it's a Treo 680. Finally took the battery out of the phone. That seemed to clear everything so that I pair the bluetooth with no problem.
Feb 22, 2008 | LG HBM-730 Wireless Headset
Was working fine until now.
uninstall device and try to reinstall if this doesn't work go to www.n1wireless.com about 30 bucks
Dec 08, 2007 | Motorola Mobility H700 Wireless Headset
It's paired up with treo, but when treo rings, the headset will not work.
there are known compatability issues with palm treo and blackberry phones when trying to use this type of headset .
I recomend a Plantronics brand headset with your phone.
Nov 17, 2007 | Motorola Mobility H700 Wireless Headset
Getting it to work
Pairing This was the second Bluetooth device I?ve used, and I had the headset paired in under 60 seconds once I had deciphered the instructions in the manual. When you press the call control and multifunction control buttons on the headset simultaneously, the M2500 goes into pairing mode. The standard way to get the Treo to pair is to click on the Bluetooth icon and basically follow the prompts: Turn Bluetooth on, make the device ?discoverable,? click on ?set up devices? and then ?Handsfree setup,? and the Treo will find the Plantronics headset. Once you?ve set up one Bluetooth device, you?re a pro. The only thing you need to know is the combination of buttons that puts a device into pairing mode. However, with the Plantronics M2500, I discovered an even easier method. Simply power up the Bluetooth headset while the Treo is on and you will be immediately prompted for the passcode, four zeros, if the devices are not paired. How cool is that? It saves many steps.
Mar 12, 2007 | Plantronics M2500 Consumer Headset
MOBILE PHONE NOKIA
Jan 28, 2007 | Plantronics M2500 Consumer Headset
Plantronics 510 Voyager Headset - PLN-510 Headset Logo
63 people viewed this question
Top Plantronics Radio Communications Experts
skiffy99
skiffy99
Level 1 Expert
shaun taylor
 Grubhead
Grubhead
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
